Old 07-11-2013, 02:02 AM   #26
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
If you're running gasoline, AFR is to lambda as feet are to meters.
Simple math gets you from one to the other.
If you work with e85, AFR becomes a misnomer, but as long as you think of 14.7 as stoich, who cares? Again, simple math gets you from unit-of-measurement one to the other.
32-bit Subaru ECUs actually use lambda internally. RomRaider and EcuFlash just convert to gas AFR because that's what most users expect. If you're moderately good with math you can tweak the definition XML to show lambda instead if you want.
Old 11-19-2013, 12:28 PM   #27
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Still can't get my homemade cable to work with Romraider, upgraded to the newer release that supposedly has the bugs fixed with the PLX dropping data.
Thanks
Subian is offline   Reply With Quote
HELP!! Autometer A/F guage not compatible with 2002 WRX wide band O2 sensor?? aznfoos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-09-2004 09:28 PM
DIY Wide Band O2 Sensor Bob O Mid Atlantic Impreza Club -- MAIC 0 12-14-2002 05:43 PM
Solutions to Wide Band o2 Sensor Problem... Needed jfalcon001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-29-2002 05:01 PM
('93-'01) Wide band O2 sensor voltage range jeffg Impreza Forum 5 06-05-2001 02:26 PM
New Info about my00 wide band o2 sensor??? skidplatez Normally Aspirated Powertrain 3 11-03-2000 11:08 PM
