Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 11-23-2011, 07:23 PM   #1
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Cobb Stage 2 Protune
Default Safe Boost PSI?
2011 wrx 92 octane fuel (ethanol free) 100% stock except Cobb stage 1 91 OTS flash. Target boost is 15 +\- .08. 45 deg F out and basically at sea level. I hit 16.1 at 6500 rpm. I am a dd wrx guy who does very occasional wot to 85 mph or so.
Want to keep my engine happy
Am I in a safe range?
Thanks.
EricInHoodRiver is offline   Reply With Quote
Old 11-24-2011, 09:09 PM   #2
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
you will see + or - 1 or 2 psi. the post important thing to keep an eye on are af ratios and knock. the cobb maps are very conservative. im running almost 22 psi on my 08 wrx(vf52 swap) and have never had any issues. i suggest torqued performance maps. the guy is great at what he does and has excellent support. check out 3gwrx.com for some more info.
424wrx is online now   Reply With Quote
Old 11-25-2011, 10:36 AM   #3
Cobb Tuning
Member#: 4803
Thanks.
Generally you want to be within 1 psi of your boost target, but a little beyond that in higher gears is OK. Best thing to do is to get a 3rd gear wide open throttle log, if you can do safely. Check out our data logging video below. Then upload your log on google docs (make sure to set the permissions to public) and post up the link here. We can then see how your boost control is doing.
Bill
Old 11-25-2011, 03:02 PM   #4
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Excellent. I will do a log and post up when I can find a safe time and place to do so. I assume car will be at 80ish mph at 6500 rpm? I drove around today with AP on fine knock correction and AP stayed at 0 which I assum means nothing as I was mostly in town. I did hit 50 mpg in 2nd at 5500 rpm and still 0, which I assume is good. Is there an online resource of information to read about what the different AP meters are, why it's important and ideal readings on each of the tests? I know so little and am trying to learn more
Thanks
Old 11-25-2011, 05:10 PM   #5
Cobb Tuning
Member#: 4803
Thanks
The video explains some of the key monitors. If you can't safely do a 3rd gear run, you can get by with a 2nd gear run.
Bill
Old 11-25-2011, 08:46 PM   #6
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Did 3 logs: 92 octane gas at 42 degrees, sea level. All stock 2011 wrx hatch with Cobb OTS 91 Octane map.
i have a big Yakima Skybox 16 on the roof if that matters. 3rd gear 2500-6500 rpm.
https://docs.google.com/spreadsheet/...DRmYUl2Q1lSekE
https://docs.google.com/spreadsheet/...0pmRUxFa05MckE
https://docs.google.com/spreadsheet/...DRzVlhNWG4xTGc
Any analysis greatly appreciated. My bias is safety. The car is PLENTY fast for me at Stage 1. Stage 1 is much, much smoother than stock, so providing it's safe, I would like to keep both it, and my beloved wrx for many years to come.
Old 11-25-2011, 09:08 PM   #7
Cobb Tuning
Member#: 4803
Logs look good. You are more on the higher side of your boost target (slightly) than you are on the lower side. You can give the low wastegate (LWG) version of the map a try if you like. You can download it from the cobbtuning site. I don't think that is necessary, but you can certainly try it.
Bill
Old 11-25-2011, 11:38 PM   #8
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Thanks Bill! I do wot so Infrequently that I am not worried about being on the higher end of average. I might try lwg map for kicks, though. The video mentioned that an ideal AF Learning # is 0, and target is +\- 8. What is the significance of a steady -3.91?
Old 11-26-2011, 09:46 AM   #9
Cobb Tuning
Member#: 4803
Your long-term fuel trims will rarely be zero (except after a reflash/reset when the trims are reset to zero). You just generally want to be within +/- 5%, with outside of +/- 8% indicating a possible problem.
Bill
tuner/professional: turbo boost psi/cylinder psi 2.5 longevity questions modaddict Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 09-21-2005 09:36 AM
boost psi Louie Newbies & FAQs 8 10-27-2003 03:59 PM
TurboXS stage 2 Boost PSI question Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-27-2002 09:44 PM
boost psi per gear?? subineer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-23-2002 09:26 PM
Safe Boost Pressure / Boost Controller and Chip SleeperWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-09-2001 03:27 PM
