Old 11-24-2011, 03:49 PM   #1
Marcos Peguero
Member#: 114653
Default 96 STI type RA
I have a 96 Sti type Ra.
I whant to know if its OBD1 or 2, to know if I can reprogram the ECU.
Thanks
Marcos Peguero is offline   Reply With Quote
Old 11-24-2011, 05:09 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
neither and no you cannot
it will do ssm but the obd-1 is incomplete
even the modern jdms don't pass obd-2 ready checks
Old 11-24-2011, 08:16 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
You can chip the ECU but can't flash it.
Old 11-25-2011, 05:44 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes search for Rob's 550 tune
Marnix is offline   Reply With Quote
Old 11-25-2011, 06:38 PM   #5
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I'm running a hydra.
sizzflair is offline   Reply With Quote
Old 12-08-2011, 10:39 PM   #6
CanSTi
Member#: 182226
1997 STi RA
I have a 96' STi RA as well and was under the impression that Rob's tune will not work on the EJ20K that comes in these cars. Someone correct me if im worng.
CanSTi is offline   Reply With Quote
Old 12-09-2011, 05:48 AM   #7
NICO TURBINE
Member#: 15445
1986 Leone STi EJ22T
JDM White
last picture in the tread if you have a four plug !! scrap your oem ecu ! http://forums.nasioc.com/forums/show...light=autronic
NICO TURBINE is offline   Reply With Quote
Old 12-09-2011, 07:46 AM   #8
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Not to jack, but does all this mean that my 95 has the same ECU and therefore cannot be tuned?
Millhouse_5 is offline   Reply With Quote
Old 12-09-2011, 04:25 PM   #9
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
all v1-2 Impreza EJ20G (with individual coilpacks and angle-entry turbo) will have the 4-plug ECU and will qualify for a "Rob tune". The EJ20K is v3-4 and has 1 coilpack and straight-entry turbo
elislider is offline   Reply With Quote
Old 12-09-2011, 10:34 PM   #10
sneaky
Member#: 200316
Millhouse you have a V1-2.
sneaky is offline   Reply With Quote
Sti Type RA gearset vs. JDM Sti Type Ra gearset russtafari Transmission (AT/MT) & Driveline 4 08-23-2008 12:04 AM
Help with understeer Sti type RA 96 Marcos Peguero Brakes, Steering & Suspension 9 07-02-2006 08:57 PM
FMIC in my sti type RA 96 Marcos Peguero Pre-2002 Factory Turbo Powertrain 25 05-30-2006 08:16 AM
NEED!!! STi Type RA or STi gearbox ASAP! RS22b Tri-State Area Forum 10 06-10-2003 05:25 PM
What about the STi Type RA (or Type C?)? akuhner STi Forum Archive 12 01-07-2003 12:53 AM
