Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 11-24-2011, 10:00 PM   #1
Member Sales Rating: (7)
Member#: 185401
2004 Forester XT
Default NJ jgart's "infamous" 04 FXT
John Gartland
Westmont, NJ (SNJ right outside of philly)
2004 Forester XT
Java Black Pearl
5-speed manual
78,XXX miles
PM or email for quickest response [email protected]
VIN: JF1SG69694G726490
Featured on Stance:Nation and Just Stance
so i hate to be doing this, but ive come to a crossroads where its keep building my car, or put a down payment down for a house, so my wagon is up for sale. kbb is about 12,500, and the car has around 5 or 6k invested in it, so my asking price is $15,500
a little background on the car:
Bought it in September of 09 bone stock as the 2nd owner from a couple in Philly with 44k on the clock. after being an idiot and speeding and doing all the dumb things with my honda before this, i decided to keep the build moderate so i wouldnt get into too much trouble hahha. that being said, i baby this car aside from the occasional rip on the highway, and playing with some twisty turns. the car was autocrossed for half a season, so about 5 or 6 days. i started building the suspension a lot when i was doing that, and decided to go into the "stanced" world. fast forward to now, and i want a home so shes up for sale :/ also, the car is lifted an inch and a half now from normal for the winter
Ive been a tech at a subaru dealership for the past two years, and maintain the car more than subaru specifies, mainly because i get bored at work, but also because i wanted the car as reliable as possible since it has been my daily. oil changes have been done with subaru brand 5w30 synthetic every 2500-3000 miles. other service information is listed below in Misc..
time for the fun stuff!
2007 STi VF-43 turbo
Grimmspeed external up pipe/dump tube (external wastegate; ceramic coated black)
Grimmspeed internal wastegate block off plate
Walbro 255lph fuel pump, stock injectors
SS Autochrome front mount intercooler
Grimmspeed manual boost controller
Kartboy light weight crank pulley
eBay oil catch can (modified with filter)
Mishimoto Subaru Forester XT Turbo Aluminum Performance Radiator
Mishimoto Subaru WRX and STI Aluminum Fan Shroud
Protuned by John Shafer at Akuma Motorsports LLC (260whp, 265wtq)
Kartboy short throw shifter with full bushing kit
Turnin Concepts trans crossmember bushings
OEM stock clutch
50/50 mix of Motul 75/90 gear 300 and Redline Shockproof (smurfsblood) in the stock 5mt trans
75w90 gear 300 rear diff fluid
3" bellmouth ERZ downpipe with wideband bung
3" custom welded cat-back exhaust to a Magnaflow muffler
SPT short ram intake
2006 STi bypass valve
NGK iridium one step colder spark plugs
Importology Forester front lip
5% tint on the rear 5 windows
N/A Forester hood primer grey (painting soon)
Forester sports rear wing
Stock grill painted black
OEM Forester splash guards
'Garage XTI' XTi badge on rear gate
2007 STi rear diffuser under bumper
OEM hood deflector
rolled and pulled fenders, flared rears
Wheels & Tires
18x10 +30 Rota SVN-R's in Titanium Chrome with 245/35/18 Yokohama S-Drives
2005 STi seats
2006 STi steering wheel NO CRUISE CONTROL
Pioneer AVH-P23000DVD double din touch screen headunit
AEM Wideband AFR gauge custom mounted in front of shifter
Prosport boost gauge
2009 Legacy key (single key/fob instead of separate two)
Kartboy brushed aluminum shift knob or bnib MOMO shift knob
Aftermarket sunroof
Little-Trees Cotton Candy air fresheners (worth mentioning hahah)
2004 STi Brembo front calipers and rotors
Hawk HPS front brake pads
OEM SPT Stainless steel brake lines, both front and rear
Megan Racing coilovers: 6k front/8k rear (dampening at hardest setting)
Whiteline 24mm front and rear sway bars
Kartboy front and rear end links
05 STi rear swaybar mounts
2005 STi rear lateral links
Kartboy rear subframe lockdown bolts
Kartboy rear differential outrigger bushings
Whiteline roll center adjust kit
Front strut tower brace
Whiteline steering rack bushings
extra parts included:
stock front heated seats
stock DP with good cat
subaru all weather floor mats
subaru 'STi' black floor mats
primer Certi-fit scoopless hood
Other MIsc info:
done at 70,000 miles
Plugs (NGK iridium one step colder)
coolant flush
brake flush
clutch fluid flush
power steering flush
pcv valve
drive belts
subaru Top Engine Clean service to clean valves and throttle body
BG fuel system service to clean injectors and lines
Brembo swap - new pads/rotors
Done at 60,000
trans drained and filled, 2qts Redline lightweight shockproof, 2qts motul gear300 75w90
rear diff drained and filled motul gear300 75w90
replaced clutch, pressure plate, flywheel and bearings with new OEM parts
replaced both rear wheel bearings, OEM parts
OEM replacement battery (same as 550cca interstate)
replaced rear pads and rotors
thanks for looking guys!
jgartland is offline   Reply With Quote
Old 11-24-2011, 10:26 PM   #2
Will mod for Guinness
Member Sales Rating: (78)
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
need the vin please.
singincanary is offline   Reply With Quote
Old 11-24-2011, 10:57 PM   #3
Member#: 185401
2004 Forester XT
fixed, sorry bruce!
Old 11-25-2011, 04:39 PM   #4
Member Sales Rating: (35)
Member#: 150986
06 #001 LSB STi
damn you werent kidding! you better start saving money cause when you buy that house youll have soo many more unexpected bills! and they better start paying you more
06njsti is offline   Reply With Quote
Old 11-25-2011, 07:53 PM   #5
Member Sales Rating: (43)
Member#: 164319
2012 STi / 08LGT
Ewwww so nice!!!!!! Wish I had the cash for this glws.
Jose99 is offline   Reply With Quote
Old 11-25-2011, 08:04 PM   #6
Member#: 262030
BraveSTi is offline   Reply With Quote
Old 11-25-2011, 08:18 PM   #7
Member Sales Rating: (46)
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
Fail. let me know if you need to return anything to stock...cask on top.
maxpowr is offline   Reply With Quote
Old 11-28-2011, 10:10 AM   #8
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
Sell me stuff +Cash!
Kupkake is offline   Reply With Quote
Old 12-01-2011, 10:24 PM   #9
Member#: 185401
2004 Forester XT
no jeff! TTT hahahaha
04 FXT 5speed into 04 FXT 4EAT w/o wiring swap blkOnblk Transmission (AT/MT) & Driveline 4 02-23-2012 01:18 PM
FS : NJ: 04 FXT vf43 EWG 78k, price drop $14,000 obo jgartland Private Vehicle 'For Sale' Classifieds 78 02-10-2012 11:57 AM
FS : (NC/SC) 04 STi Steering Wheel, STi Lamco Boost Gauge, 04 STi & 04 FXT Column Covers sagelwwa Interior/Dressup/Audio & Security 10 08-16-2011 05:19 AM
WTB : 04 FXT -> STi stuff: VF39, STi BOV, STi scoop, FXT exhaust JLee50 Private 'Wanted' Classifieds 7 11-16-2010 06:41 AM
04 WRX STI Wheels on an 04 FXT chrisww2 Tire & Wheel 1 01-14-2006 08:03 PM
