Old 11-25-2011, 07:58 AM   #1
Flavah
Member#: 220801
1994 WRX RA
Default Turbo going bad?
When I am under the hood, rev the engine and let go, I get a very fast tatatatattatat sound for half a second as the engine starts to wind down. It is not loud enough to hear it when the hood is closed. Is this a sign the turbo is on is last leg? The car is a 94 RA with 130,000km (80,779 miles) on it. It has a KMAX ECU tuned for 1.0bar, APEXi Power Intake filter, APEXi resonator delete (in the intake track), a STi TMIC, and HKS Silent Power exhaust for engine mods.
Flavah is offline   Reply With Quote
Old 11-25-2011, 01:07 PM   #2
Xenonic
Member#: 263681
1995 STI RA
Feather white
Might not want to drive it anymore until you find out what that is. I had that same sound as you, turned out it was a spun bearing.
Xenonic is offline   Reply With Quote
Old 11-25-2011, 06:36 PM   #3
Flavah
Member#: 220801
1994 WRX RA
The sound is coming from the turbo area which is why I did not even consider a bearing. If this is the case, I am done with Subaru's!
Old 11-26-2011, 10:38 PM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Get a long screwdriver or something long that you can put on the turbo and different parts of the motor/head. While touching the motor with "long thing" put the other end to your ear and listen. Move to a few different spots and try and isolate where the sound is coming from........then get back to us.
dangerousatom is offline   Reply With Quote
Old 11-26-2011, 10:49 PM   #5
Xenonic
Member#: 263681
1995 STI RA
Feather white
To do a quick check if you have a bearing failure you can do an oil change and cut open you old oil filter and hope you dont see metal sparkles in the filter. It's a good check to do to take a load off your mind that your motor will not need some serious repairs. Here's a picture of what my oil pan looked like after a really badly spun rod bearing.
turbo going bad?? shootsbrah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-28-2008 09:17 PM
Boost Leak or Turbo Going Bad? Help! Drav Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-30-2007 09:09 PM
Turbo going bad? wrxugly Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-28-2006 11:57 PM
Turbo going bad? mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-02-2004 03:41 PM
Stock Turbo Going Bad? Lowball Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-16-2003 01:32 PM
