Old 12-02-2015, 04:00 PM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Default In the middle of the fuel tank swap, need help (pics)
I thought I did my homework, but I guess I was wrong
I am swapping JDM STI fuel tank intead of the old stock 99RS one
emissions aside, there is one difference I am concerned about - the new tank is missing a hose that I believe is meant for air to escape, RS has an extra one - I hope someone can shine some light over this
ok, here are both tanks, RS main air vent goes from the middle of the tank from the white valve, the new STI tank doesn't have that white valve and has the main air vent next to the filler neck (circled both)
closer up - STI tank
RS tank
this hose the goes over here
and into here
this lead me to believe that RS tank has two air vents, and the STI has just one which is located not as high
am I getting everything right? Can I just disregard this hose on the new tank?
Hyper is offline   Reply With Quote
Old 12-04-2015, 08:00 PM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
bump for help, I am stuck
Old 12-10-2015, 08:31 AM   #3
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
Did you get this figured out? I replaced RS tank with WRX one a while ago. Its a little fuzzy now, but I remember that I had to take some censor from RS tank along with some lines and transfer it onto the WRX tank because they were slightly different.
Also this diagram along with the factory service manual diagrams were a big help in putting it all back together.
Let me know if you are still stuck, maybe I can dig into memory a little harder.
Alex
Osgood30 is offline   Reply With Quote
Old 12-10-2015, 03:28 PM   #4
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
thanks alex,
I think I figured it out, will find out for sure when everything else is put back together
Old 05-25-2016, 08:35 AM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
something is definitely wrong
somehow everytime I put fuel in, fuel gets into the main vent tank line which goes into the charcoal canister - the cut line which has a 90* bend next to the tank fill line
or is it NOT the vent line afterall?
