Old 12-19-2011, 03:23 PM   #51
wtyree
Member#: 29879
2002 WRX Wagon
subscribed
wtyree is offline   Reply With Quote
Old 12-20-2011, 09:43 AM   #52
civicmag
Member#: 301970
x2 subed
civicmag is offline   Reply With Quote
Old 12-20-2011, 10:27 AM   #53
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by Patrick Olsen View Post
With that said, it doesn't sound like your idea of "great torque" is the same as mine. But that's neither here nor there when it comes to this thread.
let me guess, you like that big domestic kick in the pants and resembles a mountain peak...not too different from most EJ257's
I blame your ctsv
and that EZ30R will probably leave you upset then...
Old 12-21-2011, 04:15 AM   #54
jzk25
Member#: 179120
More stuff.
TH400 adaptor.
1GZ vs 2JZ Bellhousing.
Bellhousing clearance in tunnel.
Vipec V88.
jzk25 is offline   Reply With Quote
Old 12-21-2011, 04:33 AM   #55
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Great engine choice. The flat torque and awesome throttle response should make this a real fun car to drive. Why not 3.9 final drive?
Originally Posted by Homemade WRX View Post
Any jackass can make a lump of tq down low but best of luck keeping it up through race revs.
I thought this image was relevant. Here is the dyno of a 99 Outback with a ton of miles
That is an incredible torque "curve" and its why NA Subarus feel so nice. At the same time my DOHC Vtec Del Sol feels like a pig at low rpms...
Old 12-26-2011, 03:02 AM   #56
jzk25
Member#: 179120
Did a bit today to work off Xmas dinner.
Fitted the T400. Had to trim the original gearbox xmember mount to clear the box but fits fine otherwise.
Made a crossmember that clamps to the chassis rails.
Crush tubes welded into the chassis rail.
Finished the engine Xmember.
Old 12-29-2011, 04:02 AM   #57
jzk25
Member#: 179120
Got some stuff done today.
Wastegates go here.
Log manifolds, won't somebody think of the children!!
Old 12-30-2011, 08:26 AM   #58
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Nice! Will be looking forward to new updates in the New Year!
Marnix is offline   Reply With Quote
Old 12-30-2011, 08:34 AM   #59
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Subscribing for awesomness
Psychoreo is online now   Reply With Quote
Old 12-30-2011, 01:18 PM   #60
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
You should shoehorn a Subaru flat12 in, just to be cool =]
I bet it sounds "interesting" at 13k rpm
NitroTrike is offline   Reply With Quote
Old 12-30-2011, 01:33 PM   #61
Tinywagon
Member#: 157566
2002 WRX wagon
HO-LEE CRAP! that's a bad ass piece of running gear! I'm with the others on this board, I didn't even know that this engine existed. is there aftermarket support? or does it all need to be custom built?
Tinywagon is offline   Reply With Quote
Old 12-30-2011, 05:10 PM   #62
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
IIRC that was subarus attempt at an F1 engine. theres probably less in existance than you could count on one hand and seeing how hard it is to fit an EG33 or any of the normal flat 6's into an impreza, an engine twice the size would be nearly impossible. that thing looks like its 5 or 6 feet long!
Anyone have any clips of the subaru flat 12 running?
Loomin is offline   Reply With Quote
Old 12-30-2011, 05:20 PM   #63
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
Old 12-30-2011, 09:13 PM   #64
Tinywagon
Member#: 157566
2002 WRX wagon
your pic links seem to be broken.
Old 12-30-2011, 09:35 PM   #65
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
3.5 liter flat 12 w/650hp sounds like a maintenance pig haha. Definitely not the kind of engine that should be mass produced. It's also not nearly 2 x the size of the EG33.
geronimo81 is offline   Reply With Quote
Old 12-31-2011, 12:29 AM   #66
jzk25
Member#: 179120
A bit more work done between Xmas activities.
Wastegates mounted. Passenger side turbo is all mounted and plumbed ready to go. Drivers side is a bit trickier due to the oil filter housing.
Rear underside.
Front underside.
Overhead view.
Bandwidth fail. Hopefully it resets tomorrow.
Old 12-31-2011, 07:13 PM   #67
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Your pic doesn't work man.
YZ86 is offline   Reply With Quote
Old 12-31-2011, 10:00 PM   #68
jzk25
Member#: 179120
Maxxed out photobucket, works now.
Old 01-01-2012, 01:33 AM   #69
nattywrx
Member#: 271998
Phatbotti tuned 16GXT E85
Wow, I had no idea there were going to be turbo's added to this engine!! This is going to be a very interesting/awesome car.
nattywrx is offline   Reply With Quote
Old 01-01-2012, 02:53 AM   #70
jzk25
Member#: 179120
You can see the pics on FB if you like our page. http://www.facebook.com/pages/A-M-Au...16487288393362
Old 01-01-2012, 11:21 AM   #71
iana
Member#: 252934
The whole 480nm v12 thing in a subaru was not any good prior right.
iana is offline   Reply With Quote
Old 01-01-2012, 06:50 PM   #72
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
This car is nuts! I LOVE IT!!!
Seraphinwolf is offline   Reply With Quote
Old 01-01-2012, 11:12 PM   #73
jzk25
Member#: 179120
Intercooler and piping.
Old 01-02-2012, 02:25 AM   #74
LiCelsior
Member#: 182551
2004 STi
insane build.
LiCelsior is offline   Reply With Quote
Old 01-02-2012, 11:56 PM   #75
jzk25
Member#: 179120
Just a bit of fiddling around today. Had to make an adaptor to fit a different oil filter as the original filter was enormous and fouled on the compressor cover.
I turned up some bits in the lathe and then tigged them together to rduce the thread on one end from 30mm to 24mm.
Awaiting exhaust parts to get that welded up tomorrow.
Feeler: 99 Legacy Sedan for Wagons subiman2005 NWIC Private Classifieds 9 07-08-2011 12:13 AM
WTB : Roof Rack for 99 legacy Sedan BD blackheat68 Private 'Wanted' Classifieds 0 08-30-2010 11:34 AM
(PGH, PA) 99 Legacy Sedan Part Out dmg Legacy Specific Parts 5 07-27-2009 01:04 AM
99 Legacy Sedan with STI Rear Spoiler 4WDFun Interior & Exterior Modification 8 06-07-2009 02:55 PM
anyone know any body kits for a 99 legacy sedan?? blazinlaser4g63 Interior & Exterior Modification 4 01-16-2003 09:28 AM
