Old 01-03-2012, 01:38 AM   #76
Slow Steve
Member#: 304346
Crazy build, VERY cool
Slow Steve is offline   Reply With Quote
Old 01-03-2012, 06:37 PM   #77
Loomin
Member#: 118113
98 Brights!
damn! looks like its almost done! you dont mess around do you?
Loomin is offline   Reply With Quote
Old 01-03-2012, 07:05 PM   #78
Gixhost
Member#: 180111
* 2004.114.3 STi
Crazy!
Gixhost is offline   Reply With Quote
Old 01-04-2012, 03:05 AM   #79
jzk25
Member#: 179120
Did half the exhaust today. Would have got more done but had to remanufacture an alloy race sump for a buick V6 powered holden speedway car.
Dash is also out as I had to reroute the heater pipes and pull some unused wiring back through the firewall. Pro Ratchet is in position.
jzk25 is offline   Reply With Quote
Old 01-04-2012, 09:00 PM   #80
jzk25
Member#: 179120
Mostly finished the exhaust. The rear section is only tacked until the diff goes in.
Ground clearance.
Old 01-04-2012, 09:57 PM   #81
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
This is awesome, I love how it's so stealth looking.
Keep up the good work!
Ben
Old 01-05-2012, 11:31 AM   #82
Psychoreo
Member#: 79643
04 EJ207 Swapped
Mikey tuned 271whp/287wtq
Bananas
Psychoreo is offline   Reply With Quote
Old 01-06-2012, 01:33 AM   #83
jzk25
Member#: 179120
Everything but the oil cap fits under the bonnet.
Old 01-06-2012, 02:38 AM   #84
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Have you considered lowering the subframe? The Outback has spacers between chassis rails and subframe and an extended steering shaft between steering column and rack.
Marnix is offline   Reply With Quote
Old 01-06-2012, 03:23 AM   #85
iana
Member#: 252934
Please look closer at pics.
iana is offline   Reply With Quote
Old 01-06-2012, 04:42 AM   #86
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
I see. Well, maybe he should consider lowering it even more
Old 01-06-2012, 04:24 PM   #87
jzk25
Member#: 179120
Just needs 15mm out of the oil filler neck. It's really no big deal compared to the other challenges this swap has presented.
Old 01-06-2012, 04:40 PM   #88
BenGSX
Member#: 210061
I can't stop eyeing that single core Subaru Radiator..
BenGSX is offline   Reply With Quote
Old 01-06-2012, 08:34 PM   #89
jzk25
Member#: 179120
It's getting a 50mm alloy radiator and electric water pump controlled by the ecu via a solid state relay.
Old 01-07-2012, 09:46 AM   #90
tonymontana1204
Member#: 275899
2013 BRZ
Lightning Red
Subscribed, I want to hear this thing start up.
tonymontana1204 is offline   Reply With Quote
Old 01-07-2012, 11:25 AM   #91
Slow Steve
Member#: 304346
This build is insane... I LOVE IT!
Old 01-07-2012, 11:38 AM   #92
Psychoreo
Member#: 79643
04 EJ207 Swapped
So what're you going to do about the oil filler neck?
Old 01-07-2012, 11:43 AM   #93
Zulu-
Member#: 232213
Amazing, can't wait to hear it.
Zulu- is offline   Reply With Quote
Old 01-07-2012, 11:59 AM   #94
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Chop it down and reweld.
Sweet build.
abrumlev is offline   Reply With Quote
Old 01-07-2012, 02:19 PM   #95
Tinywagon
Member#: 157566
2002 WRX wagon
are you going to move the air filters farther out, for fear of heatsoak? or are they going to stay that close to the block?
Tinywagon is offline   Reply With Quote
Old 01-07-2012, 04:50 PM   #96
jzk25
Member#: 179120
I do not fear heatsoak.
Old 01-07-2012, 09:18 PM   #97
jzk25
Member#: 179120
Did some more to the manifolds yesterday. Set up the bellcrank and 3 cables for the throttles.
The muppet that owns the car chopped up a spare subframe to allow the massive R230 diff to fit. Fits well, needs mounting plates welded in now. Then axles and driveshaft.
Old 01-08-2012, 09:50 AM   #98
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I hope you have lots of kids you can pass those skills to.
Very fine craftmanship.....a thing of the past, for the most part.
Good luck with the rest of it!
S.
n2xlr8n is offline   Reply With Quote
Old 01-08-2012, 03:17 PM   #99
charliew
Member#: 125304
subscribed, but the last picts don't come up, maybe tomorrow. My broadband is pretty slow. Interesting build.
My experience with 700r4's with a 350hp 400ftlb ramjet in a k5 blazer is not very reliable but the motor also shredded a 10 bolt ls carrier. I have a 63 4wd jeep truck with a 350 sbc using a 400th tranny and it has lasted forever.
charliew is offline   Reply With Quote
Old 01-08-2012, 07:51 PM   #100
iana
Member#: 252934
700r4? Did you not look at the fact its a TH400 with the entire bellhousing cut off to suit a Toyota A340 round bellhousing, which looks about 10 thousand times stronger. The box is freshly rebuilt...this will have 700ft/lb....
FT : Feeler: 99 Legacy Sedan for Wagons subiman2005 NWIC Private Classifieds 9 07-08-2011 12:13 AM
WTB : Roof Rack for 99 legacy Sedan BD blackheat68 Private 'Wanted' Classifieds 0 08-30-2010 11:34 AM
(PGH, PA) 99 Legacy Sedan Part Out dmg Legacy Specific Parts 5 07-27-2009 01:04 AM
99 Legacy Sedan with STI Rear Spoiler 4WDFun Interior & Exterior Modification 8 06-07-2009 02:55 PM
anyone know any body kits for a 99 legacy sedan?? blazinlaser4g63 Interior & Exterior Modification 4 01-16-2003 09:28 AM
Message Board Statistics All times are GMT -4. The time now is 07:00 AM.
