Welcome to the North American Subaru Impreza Owners Club Thursday August 28, 2014
Old 08-09-2002, 10:39 AM   #1
RS_NW
Member#: 2301
Question WRX Front Rotor Conversion and Legacy Rear Rotor Conversion on a 01RS?
I wanted to see if anyone has done this mod yet. I've been reading on the front rotors all you need is a different bracket to make the rotor fit. I am unclear as to how to get the rear rotors of the legacy to fit. A local guy with a WRX made the legacy mod work for his car, now I want it to work for mine. Ideas suggestions and parts that I will need. I want to use x-drilled on all four as well.
RS_NW is offline   Reply With Quote
Old 08-09-2002, 11:36 AM   #2
AWDrivin
Member#: 1687
99 2.5RS
Look at http://www.northursalia.com for some good info on this.
AWDrivin is offline   Reply With Quote
Old 08-09-2002, 11:44 AM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Actually I dont think...
Brian has this upgrade on his site yet. He has the upgrade to the vented rear rotor off the Legacy turbos. Same diameter as stock(266mm) just vented. (edit: I think) youre looking for the 2000+ Legacy 290mm solid rear rotor upgrade. Here are two other threads discussing this with part numbers:
http://forums.nasioc.com/forums/show...hreadid=214926
http://forums.nasioc.com/forums/show...hreadid=213360
subysouth
subysouth is offline   Reply With Quote
Old 08-09-2002, 02:44 PM   #4
RS_NW
Member#: 2301
You guys are awesome.
Old 08-09-2002, 09:34 PM   #5
Basshead
Member#: 112
2011 Jetta TDI
i was planing on it...but then found out the dba kangaroo paws don't fit our caliper thickness requirements..so i've bought more things to go fast.. All you need is the brackets and new rotors man!..
Basshead is offline   Reply With Quote
EBC slotted/dimpled front rotors and H6 rear rotors with brackets 69subaru360 Suspension/Brakes/Handling 5 10-17-2009 09:45 PM
Rear Pair WRX Brembo Blank Rotors and Legacy rear calipers Superorb Suspension/Brakes/Handling 0 06-12-2009 12:39 PM
FS PA: Cusco front sway and H6 rear rotors Furious George Tri-State Area Private Classifieds 5 02-15-2009 07:37 AM
WTB: WRX Front Control Arm and Right Rear Lateral Link eatadolfin Private 'Wanted' Classifieds 7 07-28-2006 11:12 AM
For sale: Stock wrx front sway bar and stock rear speaker. mgc9876 Private 'For Sale' Classifieds 2 08-02-2005 04:29 PM
