Old 11-27-2011, 06:35 PM   #1
Hobz
Member#: 153246
'00 2.5RS
Default '09 Sti steering rack into '06 crossmember?
I have heard of '07 steering racks into '04 crossmembers, but my '09 sti steering rack appears to be different, especially around the steering column input shaft and the plumbing around it. It looks like I can make room by enlarging the hole that the shaft goes through in the crossmember, but I wanted to see if anyone else had tried already.
Hobz is offline   Reply With Quote
Old 01-05-2012, 08:05 PM   #2
Hobz
Member#: 153246
'00 2.5RS
After quite a bit of work, I have determined it is possible to make it fit in theory, but unfortunately the length of the inner tie rods are too long, and where they screw into the rack they use M18 threads instead of M16 which all the shorter inner tie rods use (only the later models of sti uses M18), so I can't shorten the assembly enough to fit my RS.
This might work on an Sti which has a wider track, but there wouldn't really be any benefit to it.
So, now I'm looking for a '04-'06 rack :P
Old 01-06-2012, 11:55 AM   #3
R & H Garage
Member#: 139767
You're going to run into a similar issue with the 04-06 Rack. (the 04' sti rack has the quicker steering ratio, but uses the older style 93-04 mounts). Any 02+ Sedan is going to have longer inner steering rods than your RS. To remedy the issue you'll need to swap in Sedan drive axles, STI control arms and Sedan front struts.
R & H Garage is offline   Reply With Quote
Old 01-07-2012, 10:58 PM   #4
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
I'm running an '04 STi rack with narrow track GC control arms and WRX wagon axles in my BD Legacy, and there is plenty of adjustment in the outer tie rod ends to get the toe where it needs to be.
Dan Cech is offline   Reply With Quote
Old 01-07-2012, 11:10 PM   #5
Hobz
Member#: 153246
'00 2.5RS
Dan Cech is correct from what I've read. The '09 is wider yet than the '06 and younger sti's and so it uses unique, extra long inner tie rods, with unique M20 threads where it screws into the rack. People haven't had problems bolting in the '04 sti rack into 2.5RSs, because even though the sti had a wider track, it could still be adjusted in.
The '09 rack, set to it's narrowest, is still 1.5" longer end to end than my 2.5RS rack.
Old 01-08-2012, 04:09 PM   #6
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
Yep, so as you posted earlier you just need an 04-06 STi rack, which will be a direct bolt-in for the RS.
I did this writeup on what I think is the easiest and cleanest way to make the STi rack mate up to the RS steering column splines. Cliff notes: swap the rack end of the steering linkages, no cutting or welding required.
08 STi steering rack into RS? Pinned Brakes, Steering & Suspension 21 07-21-2011 11:25 PM
06 STi steering rack into an 02 WRX? Arnie Subaru Conversions 0 12-23-2009 06:26 PM
07 STi steering rack into 06 wagon rubrduk Brakes, Steering & Suspension 19 08-22-2008 07:15 PM
04 Sti steering rack into an 02 WRX Don Arm Brakes, Steering & Suspension 2 01-31-2007 02:32 PM
How to swap 2004 STi steering rack into 2002 WRX wagon colby Subaru Conversions 2 12-27-2004 10:39 AM
