Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 11-27-2011, 07:51 PM   #1
subiewrx001
Member#: 193591
04 WRX VF34
water/meth, spt intake
Default How to fix IACV!!
For me the IACV on my wrx was stuck. So I took it off the TB then cleaned it with no change in rpm. I then took a screwdriver that fit in the 5 star screws that hold the motor onto the valve(plastic peice attached to the metal piece with two screws) remove the two screws and get some new ones(4mx25mm). Take the motor off and try to spin the metal piece sticking out of the part that bolts to the TB, it should spin freely. If it doesnt then it is simply stuck so I used carb cleaner they recommend electronic cleaner spray along the top edge inside. Then spin it and make sure it spins some what smoothly. Make sure the end sticking out is facing down and put the motor back on using the new 4mx25mm screws. Plug it into the wire harness but leave it unbolted its hard to do alone but have someone turn the key to the on position and it will turn slightly inside which means its working. DO THIS BEFORE BUYING A NEW IACV. If this doesnt workk then the motor burned up trying to spin it. Good luck!!
subiewrx001 is offline   Reply With Quote
Old 11-27-2011, 08:17 PM   #2
Gonz#75
Member#: 101841
1998 2.5RS
mostly black
That's funny, I just had to do this to my Toyota. It sure saves a couple of hundred bucks.
Gonz#75 is offline   Reply With Quote
How to How to fix a broken STI lip, what is the oem MADE OFF V8 GTFO Lesbic WGN Interior & Exterior Modification 45 04-08-2014 03:27 PM
How to fix IACV!! subiewrx001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-27-2011 07:48 PM
How to really know if you are being underpaid? (and how to fix it?) drkwtsn Off-Topic 11 04-18-2007 11:22 PM
anyone know how to fix the MRT header CE light? scootr Normally Aspirated Powertrain 4 06-15-2001 07:34 AM
How to fix small impact dimples? Keshav General Forum Archive 12 07-24-2000 07:52 PM
