Old 11-28-2011, 11:03 AM   #1
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
Default weird metallic rattle noise from engine under load
1995 impreza with EJ20G swap.. so ive been getting this weird noise under load.. starts happening just before getting into boost. it sounds like a metallic rattling/flapping sound, kind of like an exhaust leak would sound. at first i thought it was just that, so i changed out all the exhast gaskets. I thought maybe the uppipe was cracked, cause it seemed to move a little. so i sent off the manifold to grimmspeed to pnp and ordered their uppipe as well. so even after all that the noise is still there. I checked the intake piping, and its all good, no cracks or leaks. its got me stumped
gtu89rx7 is offline   Reply With Quote
Old 11-28-2011, 01:42 PM   #2
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Engine knock?
wrxstijdm is offline   Reply With Quote
Old 11-28-2011, 02:40 PM   #3
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Heat shield?
EdHilario is offline   Reply With Quote
Old 11-28-2011, 08:49 PM   #4
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
i removed all the heat shields when i replaced the gaskets. every exhaust gasket has been replaced with new. im running a full 3" exhaust, nothing that can rattle that i know of?
Old 11-30-2011, 04:49 PM   #5
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Except things rattling from the vibration from the exhaust. Also there sometimes a rattle if your not using all of your exhaust hangers.
There is rattle from things not entirely bolted down during the engine swap such as the metal tube running along the firewall on some early ej20g's used to supply vacuum to the brake booster.
Check for loose anything. Rattle means somethings loose. comming into contact allowed to vibrate.
TommyAtomic is offline   Reply With Quote
Old 12-01-2011, 08:19 AM   #6
njtank
Member#: 271657
2005 Legacy GT
I have the same issue only mines an 05 WRX so no swaps. Has me going crazy.
njtank is offline   Reply With Quote
Old 12-01-2011, 06:19 PM   #7
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
what have you tried so far? i think it may be a blown intake to engine gasket.. going to change that next and look for anything else while its apart. also getting a code 42 idle switch, so maybe it is a vacuum/boost leak
Old 12-01-2011, 09:07 PM   #8
njtank
Member#: 271657
2005 Legacy GT
I'm pretty sure mine is a bad gasket between the downpipe and catback.
Old 12-05-2011, 02:19 AM   #9
njtank
Member#: 271657
2005 Legacy GT
Have you lost any boost or have you had to much vacuum through this whole rattle crap ?
Old 12-05-2011, 09:14 AM   #10
gtu89rx7
Member#: 108029
2000 2.5RS
Rally car
its about -20 in at idle, and boosts up to about 13 psi no problems. i have not changed the intake manifold gasket yet
Old 12-05-2011, 09:55 AM   #11
njtank
Member#: 271657
2005 Legacy GT
Haven't even thought of that. I'm gonna have a leak test done later this week ill keep you informed.
Old 12-05-2011, 03:31 PM   #12
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
you can test for leaks by letting the car idle and squirting bits of carb/brake cleaner around in the engine bay at hoses and gaskets and mating points, and if the car changes idle or stumbles at all, you know you have a leak there
elislider is offline   Reply With Quote
rattling noise from engine RR Normally Aspirated Powertrain 12 01-12-2010 02:16 AM
Strange metalic rattle sound from engine ronan1975 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-28-2008 11:33 PM
rattling noise from engine bay 06subieWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 08-29-2007 06:37 PM
help. rattleing noise from engine bay. sammyswrxsti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-20-2007 11:18 PM
clicking rattling noise from engine VideoGameWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-06-2006 12:27 PM
