Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 11-28-2011, 10:21 PM   #1
wrxwagon0518
Member#: 301671
2005 wrx
Default ny inspection test?
i have a catless invidia tbe catless would i pass inspection or would i have to swap to my stock exhaust
wrxwagon0518 is offline   Reply With Quote
Old 11-28-2011, 10:34 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
no. if they do emissions testing, you won't pass. you need your stock downpipe at a minimum.
Old 11-29-2011, 09:56 AM   #3
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
in new york it depends where you go
if you bring it to a mom and pop shop, they'll pass you no question as long as there are no cel's and all your saftey features/equipment is in working order
if you bring it to a place like mavis, they might not, they do under car visual inspections and they'll give you quite a hard time over the fact that you're running catless, but if you tell them that the uppipe still has a cat on it they should be okay with that, especially if they don't know jack about subaru's
other wise have no check engine lights on for about 100 miles or so before your inspection and you should be alright, if it makes you feel better just slap the stock heatshield over the downpipe and have it like that just for the inspection
brew02wrx is offline   Reply With Quote
Old 11-30-2011, 05:53 AM   #4
davidmount
Member#: 173026
2003 WRX
Check local regs, CA CEL on, aftermarket downpipe, uppipe, etc instant visual fail. Mom and pop's are hard to find out here - love the weather, can't stand CARB.
davidmount is offline   Reply With Quote
Old 11-30-2011, 09:52 AM   #5
LIChuck
Member#: 266122
2007 WRX Limited
UGM
New York state requires cats, that's the law. If an inspection station passes it without a cat, they are breaking the law.
LIChuck is offline   Reply With Quote
Old 11-30-2011, 11:46 AM   #6
wrxwagon0518
Member#: 301671
2005 wrx
Would I pass if I have a cat on the downpipe?
Old 11-30-2011, 11:58 AM   #7
tobe2be
Member#: 296578
2004 Wagon
JBP
There needs to be something in the exhaust that "looks" like a cat in order for it to pass. Thats all i can say.
tobe2be is offline   Reply With Quote
Old 11-30-2011, 05:45 PM   #8
guroove
Member#: 129833
2005 Forester XT
Obsidian Black Pearl
This.
Wrong.
This is why he is posting in the Tri-State forum.
I have no cats, but I have a fake 3rd cat. I don't even know if they cared to look for it when I got inspected. I think the fact that my muffler looks factory-ish, and isn't loud as hell helped.
Also, if you get it tested anywhere within the 5 boroughs of NYC, you should pass as long as it passes the computer portion of the inspection, and it isn't glaringly obvious that your car is modified. The inspector will also do the usual safety checks.
guroove is offline   Reply With Quote
Old 11-30-2011, 06:43 PM   #9
tobe2be
Member#: 296578
2004 Wagon
JBP
I use to do inspection and it was required to look for a cat. Exhaust noise will not make you fail unless its caused by an exhaust leak.
Old 11-30-2011, 10:20 PM   #10
wrxwagon0518
Member#: 301671
2005 wrx
what if i get the invidia downpipe with the cat on it?
Old 12-01-2011, 12:11 AM   #11
guroove
Member#: 129833
2005 Forester XT
Should be fine.
Old 12-01-2011, 12:52 AM   #12
jasper24
Member#: 261930
04 wrx
That is what I have with a catless uppipe and I pass.
jasper24 is offline   Reply With Quote
Old 12-01-2011, 09:53 AM   #13
wrxwagon0518
Member#: 301671
2005 wrx
Thank you for all the help
Old 12-01-2011, 10:45 PM   #14
wrxwagon0518
Member#: 301671
2005 wrx
one more thing that someone just told me told if i run catless with a tune from the cobb accessport i would pass the inspection is this true?
Old 12-02-2011, 12:16 AM   #15
tobe2be
Member#: 296578
2004 Wagon
JBP
nys does not do probed emissions so no ses light with monitors completed it should pass emissions portion.
Old 12-02-2011, 01:14 PM   #16
guroove
Member#: 129833
2005 Forester XT
Like I said before, I am running a catless setup. I have something that looks like a cat. I have passed. If you go catless, you should have something that looks like a cat or you may not pass.
Honestly, the smell alone is worth getting a cat for. If I get a catted 3rd pipe, I'll sell you my fake cat pipe.
Ny Inspection. SilWrx02 Tri-State Area Forum 2 09-19-2005 05:42 PM
NY Inspection and OBD2 sfjohnson Tri-State Area Forum 11 07-27-2005 11:40 AM
Failed NY inspection TheLegacy Tri-State Area Forum 25 07-21-2005 09:47 AM
02 WRX w/catted up pipe + Catlesss TBE pass in NY inspection? NOOB HELP Blown95ImpalaSS Tri-State Area Forum 9 06-20-2005 03:18 AM
'02 WRX w/ 1 Cat Passes NY Inspection! bedabi Tri-State Area Forum 2 04-18-2003 05:22 PM
