Old 11-29-2011, 12:47 AM   #1
kleedzine
Member#: 273531
02 frankenSTI
white
Default closed loop switch ON
Hello,
I am playing with CL/OL fueling and delay using ATR
And I set some trial value, get logging done.
I add closed loop sw. to the data log list set. to see when and how it is switching between CL and OL.
then, when the switch value goes from OFF to ON, DAM value changes to 0 from 1. and acting like Dynamic advance value. Also, I get nan after WGDC value.
I'm linking the logging. So, plz review the log.
https://docs.google.com/spreadsheet/...jhUbjAzZGt4ZFE
kleedzine is offline   Reply With Quote
Old 11-29-2011, 09:51 AM   #2
Cobb Tuning
Member#: 4803
Originally Posted by kleedzine View Post
Hello,
That is odd. This is an 09 WRX? What is your AccessPORT firmware version ("AccessPORT" -> "About")? Is this the original .csv file that came from the AccessPORT or was it opened and saved in spreadsheet software at some point?
Bill
Old 11-29-2011, 11:07 AM   #3
kleedzine
Member#: 273531
02 frankenSTI
white
It is copied and pasted from original file and saved as exel work book format. I will check the firmware version later.
thanks Bill
Old 11-29-2011, 11:29 AM   #4
Cobb Tuning
Member#: 4803
thanks Bill
Can you post up the original, untouched .csv from the AP at cobbforums.com?
Thanks,
Bill
Old 11-29-2011, 11:40 AM   #5
kleedzine
Member#: 273531
02 frankenSTI
white
Ok, I will post on the web later. but it will be a bit long logging.
Old 11-29-2011, 11:43 AM   #6
Cobb Tuning
Member#: 4803
Not a problem.
Bill
07 2.5i. switching back n forth open/closed loop. subadub07 Normally Aspirated Powertrain 4 11-27-2009 09:52 AM
Question on open loop/closed loop fuel delay imprezzing Newbies & FAQs 2 09-19-2006 01:33 PM
Closed loop - open loop switching Ahzlon Normally Aspirated Powertrain 5 04-22-2004 04:14 PM
open loop closed loo9 switch? fedrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-08-2004 01:13 PM
at wat RPM does MAP cars switch open/closed loop? wistful Normally Aspirated Powertrain 4 10-14-2001 03:06 PM
