Old 11-30-2011, 12:31 AM   #1
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Default OBD2 Port Pin out?
Im looking for a pin out guide for the bottom of the APV2. Id like to know what pins on the bottom of the AP are used to communicate with the car. Since the car only needs 4 but the AP has 9.
Token-Negro is offline   Reply With Quote
Old 11-30-2011, 11:09 AM   #2
Cobb Tuning
Member#: 4803
There are more than 4 pins because the AccessPORT is used with different vehicles, so, for a given vehicle, some of the pins will be unused. You can use a multimeter to determine which pins in the cable are used.
Bill
Old 11-30-2011, 12:13 PM   #3
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Nevermind the response
Last edited by Token-Negro; 11-30-2011 at 12:15 PM. Reason: Headed to the garage to get volt meter.
Old 11-30-2011, 12:23 PM   #4
Maxwell Power
Member#: 190729
Why don't you just cut the cable and use it to wire up to the obd2 port?
Maxwell Power is offline   Reply With Quote
Old 12-26-2011, 10:57 PM   #5
wutdadilyo
Member#: 53967
2011 WRX Premium
Satin White Pearl
Hey Bill from Cobb Tuning,
Are there only supposed to be a total of 9 pins on the AP-SUB-003 unit? In the instruction manual it says there is supposed to be 10
- Juni
wutdadilyo is offline   Reply With Quote
Old 12-28-2011, 11:31 AM   #6
Cobb Tuning
Member#: 4803
- Juni
There are 9 pins plus 1 blank position on the AP.
Bill
Old 12-29-2011, 02:54 PM   #7
jnmarshall
Member#: 40500
16 Forester XT
Bill
Odd. Mine has all 10. Part's supplier difference maybe?
jnmarshall is offline   Reply With Quote
Old 12-29-2011, 07:52 PM   #8
Cobb Tuning
Member#: 4803
The very early "V2" hardware had a full 10-pin connector. It is functionally the same (the 10th pin is "dead" and not used) but allowed for the cable to be plugged in backwards (180 degrees from correct), which many users mistakenly had happen. We revised the connector slightly by dropping to 9 pins and making the blank pin keyed to a blank spot in the cable -- this way, the cable can only be plugged in the correct way. Hope this helps clear up any questions!
Cheers
Lance
OBD2 16 pin connector repair. wrxsubiemod Engine Management & Tuning 2 10-04-2011 08:31 PM
Hardwire OBD2 port? STIlin' AccessPort 3 05-05-2007 06:50 PM
Anyway to tell if AVCS is working through OBD2 port or PSi3 SECS unit? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-07-2006 10:20 AM
16 pin connector pin out ebbrewing Car Audio, Video & Security 5 02-13-2005 11:41 PM
Relocating OBD2 port.. cronic Engine Management & Tuning 6 09-06-2003 05:50 PM
