Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 11-30-2011, 10:31 AM   #1
Edo Performance
Vendor Sales Rating: (54)
Member#: 70537
OMGHi2U Tomioka Racing - downpipes, headers, and Tuboros + Twinscroll Kit!!!
FREE SHIPPING AND NO SALES TAX ON ALL TOMIOKA RACING ORDERS!!
TR High Flow Downpipe
for Subaru Impreza STi 2002-2007, 2008-up
PRODUCT DESCRIPTION
Tomioka Racing Subaru High Flow Downpipe for WRX/STI is a high quality 3-inch down pipe at an affordable price. The downpipe features ported flanges for a quicker and faster exhaust air flow compared to the standard OEM downpipe. Each downpipe is constructed from SUS304 grade stainless steel that gives it shine and durability that will last for years to come. Installation is a snap! The downpipe will fit like your OEM downpipe and comes with all the necessary hardware and gasket. The downpipe even comes with two EGT sensor bung in case you are running a gauge set-up on your car. If you're looking for the best bang for your buck down pipe look no further!
Subaru Impreza WRX / STi 2002~2007 Catless $280
Subaru Impreza WRX / STi 2008-up -
Catless $280
Catted $480
Catted $480
SPECIFICATIONS
• Material: Stainless Steel SUS304
• Pipe Diameter: 3 inches
CONTENTS
• 3" Downpipe x 1
• Bolts & Nuts x 7
• Gaskets x 2
________________________________
Call, AIM, or PM any Questions
Mention this thread to receive this special pricing!
Call Toll Free (714) 602-5741
__________________
[B][COLOR="Red"]U[/COLOR].[COLOR="White"]S[/COLOR].[COLOR="RoyalBlue"]A[/COLOR]. [/B][COLOR="Black"]Master Distributor for:[/COLOR]
[B][COLOR="Blue"]Cusco[/COLOR], [COLOR="Magenta"]Tomioka Racing[/COLOR],[COLOR="SeaGreen"] Zero Sports[/COLOR], [COLOR="Red"]Motul[/COLOR][/B]
[COLOR="Black"]Phone:(714)602-5741[/COLOR]
[COLOR="Blue"][B][U]Follow us on:[/U][/B][/COLOR]
[/URL]
Edo Performance is offline   Reply With Quote
Old 11-30-2011, 10:32 AM   #2
Edo Performance
Member#: 70537
OMGHi2U Tomioka Racing Exhaust Manifold
for Subaru Impreza WRX/STi 2002-2007, 2008-up
PRODUCT DESCRIPTION
Stainless steel, lost wax finish with 4-1 connectors smooth inner surface for better flow. Stable connection and air leakage avoided by the 3 bolts flange design up-pipe. A 45mm size pipe enable better flow of exhaust.
Unequal Length Exhaust Manifold w/ Up-pipe: $650
Equal Length Exhaust Manifold w/ Up-pipe: $680
Twin scroll Equal Length Exhaust Manifold w/ Up-pipe: $680
SPECIFICATIONS
Pipe Diameter
Pipe diameter: I/D - 45mm
Manifold: O/D: 42.7mm, Thickness – 2.0mm
Up-pipe Spec: O/D – 60.5mm, Thickness – 2.0mm
Flange Thickness: 12mm
CONTENTS
• Exhaust manifold
• Up pipe
• Turbo gaskets
• 50' x 2" exhaust wrap
• Hardware kits
__________________
[/URL]
Old 11-30-2011, 10:32 AM   #3
Edo Performance
Member#: 70537
OMGHi2U
TDO06-20g Turbo
PRODUCT DESCRIPTION
The TR TD06-20G turbo is designed for the newer models of Subaru with fly-by throttle turbo design. This turbo is made for high-end power while maintaining the bolt on design as much as possible. This turbo can handle 420 HP for all your racing needs. Upgraded engine internals is strongly recommended for this turbo.
Subaru Impreza WRX 2002~2007 $1250
Subaru Impreza STi 2004+ $1250
(Flange Style) Subaru Impreza WRX 2008+ $1250
(Flange Style) Subaru Legacy GT 2005+ $1250
SPECIFICATIONS
Bearing: Journal
Flange: Standard Subaru 5 Bolt
Compressor Diameter: Inlet 58 mm/ Outlet 67 mm
Turbine Diameter: Inlet 52 mm/ Outlet 68 mm
Air Flow Rate: 700 CFM
Turbo Boost: .8 BAR / 12 Psi
Power Output: 420 HP
Turbine Housing: 8 cmē
CONTENTS
• Turbocharger
• Actuator
• Oil Pipe
• Water Pipe
• Gaskets
• Hardware kits
TDO06-20g Turbo w/ 3inch inlet
PRODUCT DESCRIPTION
Looking to put out some high end power? Take a look at the TR TD06-20G Turbo, this turbo features a 3-inch inlet allowing higher air flow than the standard 2.4-inch inlet on the factory size turbo. This turbo comes with a heavy duty internal wastegate ready to make high end power! Please note in order to install this turbo you will have to get a 2.4 to 3 in reducer inlet coupler and install TGV deletes to clear the manifold.
SPECIFICATIONS
Bearing: Journal
Compressor Diameter: Inlet 59 mm/ Outlet 76 mm
Turbine Diameter: Inlet 54 mm/ Outlet 61 mm
Air Flow Rate: 750 CFM
Power Output: 460 HP
CONTENTS
• Turbocharger
• Actuator
• Oil Pipe
• Water Pipe
• Gaskets
• Hardware kits
TDO05-20g Turbo
PRODUCT DESCRIPTION
If you are looking for a street/track turbo look no further, the TR TD05-20G turbo makes a excellent street and track turbo. This turbo is capable of up to 400WHP and maintain a street drivability when you are off the track. With a larger wheel blades then the TR TD05-18G this turbo can handle mid to high end horsepower without increasing the lag time on the turbo when compared to stock. The turbo comes with all fitting and gaskets, ready to bolt on out of the box.
Subaru Impreza WRX 2002~2007 $1150
Subaru Impreza STi 2004+ $1150
(Flange Style) Subaru Impreza WRX 2008+ $1150
(Flange Style) Subaru Legacy GT 2005+ $1150
SPECIFICATIONS
Bearing: Journal
Compressor Diameter: Inlet 52.5 mm/ Outlet 68 mm
Turbine Diameter: Inlet 49.2 mm/ Outlet 56 mm
Air Flow Rate: 640 CFM
Turbo Boost: 1 BAR / 14.7 Psi
Power Output: 400 HP
CONTENTS
• Turbocharger
• Actuator
• Oil Pipe
• Water Pipe
• Gaskets
• Hardware kits
TDO05-18g Turbo
PRODUCT DESCRIPTION
The TR TD05-18G Turbo is the one of the best turbo upgrade for your street car. The turbo characteristic is very similar of factory VF42 Turbo but with an increased spool rate and capacity to handle upwards of 350WHP so it makes a great addition to your engine if you are planning to keep your car daily driver friendly. The turbo comes with all fitting and gaskets, ready to bolt on out of the box.
Subaru Impreza WRX 2002~2007 $900
Subaru Impreza STi 2004+ $900
(Flange Style) Subaru Impreza WRX 2008+$900
(Flange Style) Subaru Legacy GT 2005+$900
SPECIFICATIONS
Bearing: Journal
Compressor Diameter: Inlet 50.3 mm/ Outlet 68 mm
Air Flow Rate: 600 CFM
Power Output: 350 HP
Turbine Housing: 7 cmē
CONTENTS
• Turbocharger
• Actuator
• Oil Pipe
• Water Pipe
• Gaskets
• Hardware kits
__________________
[/URL]
Old 11-30-2011, 11:37 AM   #4
Edo Performance
Member#: 70537
OMGHi2U
TD05-20g Twinscroll Turbo Kit
PRODUCT DESCRIPTION
Tomioka Racing Twin Scroll Turbo line is catered to the die-hard Subaru fans! The twin scroll turbo is an efficient and economical way to replace or upgrade your current turbo set up on your Subaru. Featuring USDM length twin-scroll downpipe and also boast more power than the standard VF series turbo with similar spool time.
$2400
SPECIFICATIONS
Bearing: Journal
Compressor Diameter: Inlet 58 mm/ Outlet 51 mm
Turbine Diameter: Inlet 68 mm/ Outlet 56 mm
CONTENTS
• Twin Scroll Turbo
• Twin Scroll Manifold
• 3-Bolt Up-pipe
• Twin Scroll USDM Downpipe
• Bracket
__________________
[/URL]
Old 12-05-2011, 11:14 PM   #5
Edo Performance
Member#: 70537
Twin Scroll RESULTS!!
348whp 395wtq
+110 wHP +140 wTQ over stock
The car is a 2006 WRX:
- Twin scroll turbo
- Twin scroll Header
- Twin scroll down pipe
- 2.5 inch cat back exhaust
- TGV Delete
- 1000cc injectors
- Upgraded Fuel rail
- Front Mount intercooler
- Fuel Pump 400 LPH
- Front Mount Intercooler
- Forged pistons
- Short Ram Air Intake
- Tomioka Turbo Inlet Hose
- Tomioka AOS
- E85 Fuel
__________________
[/URL]
Old 01-11-2012, 11:01 AM   #6
Edo Performance
Member#: 70537
bump bump for having this in stock!
__________________
[/URL]
Old 01-11-2012, 12:00 PM   #7
n2xlr8n
Member Sales Rating: (26)
Member#: 18960
02 WRX MBP
It lives! ; )
Will you sell just the TS downpipe? Is it 3" outlet flange that will mate to USDM midpipes/catbacks?
Thanks for your time.
n2xlr8n is offline   Reply With Quote
Old 01-11-2012, 12:30 PM   #8
Edo Performance
Member#: 70537
You have PM
__________________
[/URL]
Old 01-11-2012, 12:30 PM   #9
Edo Performance
Member#: 70537
All PM replied !
__________________
[/URL]
Old 01-15-2012, 09:51 AM   #10
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Originally Posted by Edo Performance View Post
You have PM
I lost your quote, somehow. Can you send it again?
-I need the Tomioka TS downpipe for 2002 WRX to fit a TXS midpipe
-I need to ensure that it has two O2 bungs at the front turbo flange
-Do you have it in stock?
Thanks for your time!
S.
Old 01-15-2012, 11:32 AM   #11
Edo Performance
Member#: 70537
the Tomioka Downpipe will have 1 02 bungs at the front and one at the rear like shown in the following
http://www.tomiokaracing.com/index.p...or-subaru.html
we have this in stock.
we will pm you the price.
Thanks
Edo
__________________
[/URL]
Old 01-15-2012, 12:13 PM   #12
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Well, I'll just have to add one Any chance a spare could sneak it's way into the box?
You have paypal.
Thank you for your time!
Thanks
Edo
Old 01-15-2012, 04:55 PM   #13
Edo Performance
Member#: 70537
payment received. bump for a TR twinscroll downpipe going to a subaru owner!
__________________
[/URL]
Old 01-16-2012, 01:25 PM   #14
Edo Performance
Member#: 70537
all orders shipping today ! Bump
__________________
[/URL]
Old 01-17-2012, 03:44 AM   #15
p8ntball1126
Member Sales Rating: (2)
Member#: 251473
2005 WRX
How much can you guys do for the Equal Length Exhaust Manifold w/ Up-pipe with installation?
p8ntball1126 is offline   Reply With Quote
Old 01-19-2012, 12:02 AM   #16
Edo Performance
Member#: 70537
pm responded!
__________________
[/URL]
Old 01-20-2012, 04:32 PM   #17
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Thanks for your prompt resolution!
S.
Old 01-21-2012, 03:38 AM   #18
Edo Performance
Member#: 70537
we have gotten in touch with you. hope everything is ok
__________________
[/URL]
Old 01-24-2012, 08:07 PM   #19
Edo Performance
Member#: 70537
Default Twinscroll Turbo Kit for WRX 08+ Available Now !
08-11 Subaru WRX Twin Scroll Turbo Kit $2400
Includes twin scroll turbo, Twin scroll downpipe, twins scroll header and twin scroll up-pipe!
Only want the twin scroll down-pipe? No problem!
Twin Scroll Downpipe
Available for 02-07 WRX/STi and 08-11 STi Hatchback. All in USDM length! $450
__________________
[/URL]
Old 01-30-2012, 11:28 PM   #20
fizzyl
Member Sales Rating: (8)
Member#: 103490
06 STi
Is there a difference between the Tomioka EL headers and the Tomei EL headers? Can you do the same price for the Tomei shipped to Santa Barbara? Thanks!
fizzyl is offline   Reply With Quote
Old 01-31-2012, 12:33 AM   #21
Edo Performance
Member#: 70537
PM sent
__________________
[/URL]
Old 03-26-2012, 06:01 PM   #22
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Are you guys still in business? I have some issues with the TS downpipe.
Old 03-26-2012, 06:03 PM   #23
Edo Performance
Member#: 70537
Yes we are. Please send us PM.
__________________
[/URL]
@@!@---Black Friday - Downpipes, Headers and TURBOS!! DOWNPIPES! z0MG Edo Performance Engine/Power/Exhaust 0 11-25-2011 02:14 AM
FS : Exedy Racing - Stage 4 Twin Metallic Clutch Kit FM022SD, new and priced to sell Greg555 Drivetrain 9 02-04-2011 10:58 AM
intake, downpipe, header and no tune... what is the stock ecu going to do? All4bSpinnin Engine Management & Tuning 14 11-02-2006 09:54 PM
