Old 11-30-2011, 02:24 PM   #1
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Default USDM parts for JDM powersteering?
What USDM year/Model of power steering pump and steering rack match a JDM '93 Impreza wrx wagon? GF8 chassis, EJ20G engine. Not a motorswap.
I have to replace a steering rack boot that is somehow shredded and I also have a powersteering pump that is now leaking massively. With the boot I could probably do ok with a universal fit steering rack boot of some kind. With the pump something a bit more specific may be required.
TommyAtomic is offline   Reply With Quote
Old 12-01-2011, 01:35 AM   #2
olivertwisto
Member#: 224318
1998 WRX
snow white
The racks are different, and not just because of RHD, either. I don't know about the pump, but I do know they changed with the introduction of the phase 2 motors in 97. I think you will need one that predates that shift. If you visit the jdmvip forum, someone has kindly shared the parts lookup guide. Link is below, but you may need to be a member to see it. Good luck.
http://forums.jdmvip.com/Subaru_FAST...Impreza-1794-t
I have a spare used rack I would sell, but you would need to pay shipping from Japan!
olivertwisto is offline   Reply With Quote
Old 12-01-2011, 09:35 AM   #3
suberdave
Member#: 101865
88 GL-10 STi
im prety sure the pump is the same as a USDM EJ18 pump. just has different resavour on it. however i think i may have a JDM one, but will have to check.
as for the race i may have one also. i will have to check.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 12-01-2011, 04:55 PM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I need a new low pressure line if you guys manage to come up with a source for these things.
linsavy is offline   Reply With Quote
Old 12-02-2011, 01:38 PM   #5
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
-=Suberdave=-
Awesome. Let me know what you find out. I tried installing the subaru FAST parts catalog with the my93 parts from a link on jdmvip. I think I'm finding some useful stuff that I will try to cross ref against the genuine subaru parts website.
Old 12-02-2011, 01:57 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
96 legacy outback with EJ25 for the pump and lines.
Legacy postal wagon 90-99 rack will work. Any difference is internal they bolt in.
Any 90-up subaru for the boot, they are all the same.
Old 12-05-2011, 09:41 AM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
my 93 1.8 pump had a different flange/needle on the end than my ej20g (from a legacy)
match the pump to the hoses. i would try the postal legacy route
Old 08-28-2012, 10:10 AM   #8
9MX
Member#: 330514
wrong posting sorry
9MX is offline   Reply With Quote
Old 08-29-2012, 06:13 PM   #9
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Well, since this thread is bumped, I'll ask a question:
Can a regular 98 RS power steering pump work for a V4 STi-RA?
Smoke is offline   Reply With Quote
Old 08-29-2012, 08:06 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
Probably, see if the pressure hose fitting is the same.
Old 09-01-2012, 12:40 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
its not
Old 09-01-2012, 03:43 PM   #12
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Then swap the fitting between the pumps
Old 01-02-2013, 10:28 AM   #13
Jarrod164
Member#: 253937
1995 WRX
Mega bump/looking for more info!
So I thought my reservoir was leaking but I could have a completely crapped out pump now on my 95 WRX. I took the reservoir off the top and found that a 99 pump has the same o-ring size. But this thread is claiming the fittings are different? Everything looks to line up properly, but are we talking about the line that threads into the side being different? And for the last post saying to swap the fittings, does that mean that it's possible to remove that part on the side of the pump and replace it?
That threaded portion showing in the image:
Jarrod164 is offline   Reply With Quote
Old 01-03-2013, 12:39 PM   #14
Jarrod164
Member#: 253937
1995 WRX
Well the power steering pump was leaking I guess on the bottom... replaced it all with my 93 impreza pump and reservoir. It all lines up! Seems to be ok so far. Hope this helps someone in the future.
And I took a look at the lines from my 99rs parts and it actually has this metal ring around a banjo bolt that has a different size that the earlier pumps so it will not fit! Unless you can take that nut off that it bolts into. I think it's like 21mm so maybe I'll give that a shot sometime. Perhaps that's what was meant by changing the fittings
Jdm Parts For Jdm People!!! illegal2.2 Legacy Specific Parts 14 02-16-2007 09:41 PM
WTT: SGM sti wing for wrx/wingless and USDM seats for jdm norexyet Tri-State Area Private Classifieds 5 08-03-2006 11:23 PM
WTB 2004 USDM parts, V7 JDM STI parts, exhaust hangers kula55 Canada Region Private Classifieds 0 04-04-2006 04:37 AM
WTT: USDM Headlights for JDM Headlights civilone Vancouver Impreza Club Forum -- VIC 5 02-26-2006 07:21 AM
Any specialists can confirm the difference of parts for JDM V7 / V8 and USDM STI? V6 Subaru Conversions 3 05-21-2005 11:49 AM
