Old 01-03-2012, 12:44 AM   #1
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Default Root Cause DTC P2227 Code
Has anyone been able to track down the root cause of a P2227 Barometric Pressure Circuit Range/Performance? The car has an AEM Map sensor, and AEM IAT sensor but other then that all oem sensors.
Token-Negro is offline   Reply With Quote
Old 01-05-2012, 03:54 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Barometric pressure might mean ambient atmospheric pressure, rather than manifold pressure. Anyone know for sure?
Old 10-16-2012, 11:02 AM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
OP, did you have an issue related to this? Did you find out the cause?
TyranosaurusWRX is offline   Reply With Quote
Old 12-23-2012, 07:04 PM   #4
Nyratoncito
Member#: 288702
I have this same code P2227 Barometric Pressure Circuit Range/Performance. How can I go about fixing this. I have looked everywhere and had no right answer. Thank you
Nyratoncito is offline   Reply With Quote
Old 12-23-2012, 07:17 PM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
what year
Nuke209 is offline   Reply With Quote
Old 12-24-2012, 09:03 AM   #6
jkopinga
Member#: 220799
2006 Impreza WRX
WRC Blue
The newer cars have the BAP sensor integrated in the LH side Secondary Air valve. Upon starting the car it compared the values of the MAP sensor and the BAP sensor in that Secondary Air valve.
Did you get rid of these air valves? If not, use a LOGGER to check what values you are seeing from the BAP sensor as well as the MAP sensor and you might be able to answer your own question.
Jasper.
jkopinga is offline   Reply With Quote
Old 12-24-2012, 09:38 AM   #7
quazimoto
Member#: 70395
The older vehicles (like the 2.0L's) had the unit integrated into the ECU. It is a separate sensor from the MAP sensor.
Old 08-01-2015, 02:38 AM   #8
RAWRMON
Member#: 346180
2006 STI Sedan
i'm having the same code on my 06 STI and I've reset and it just comes back... before I got her she was converted to FMIC.. where do I look for BAP sensor? pic would be excellent
RAWRMON is offline   Reply With Quote
Old 04-24-2016, 04:09 PM   #9
Willabie
Member#: 410322
I also have a 2006 STI and i'm getting the p2227 code. I have reset it and it comes back the next time i start the car. It seems to run just fine but i hate the light flashing away. does anyone know how to fix it?
Willabie is offline   Reply With Quote
dtc 23 code ?????????? moorebl Transmission (AT/MT) & Driveline 0 07-11-2008 05:28 PM
Religion is, to a large extent, the root cause of all evil. SkirtBoy Off-Topic 50 03-14-2006 06:24 PM
root cause of hesitation problem found and fixed! davidm_sh Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 10-05-2005 01:02 PM
Causes of CEL codes P0122 and P1133 nytoy Normally Aspirated Powertrain 5 12-27-2004 01:12 PM
Weak/Bent Shift Forks - Could this be the root cause of some problems? ITWRX4ME Transmission (AT/MT) & Driveline 3 06-17-2003 06:33 AM
