Old 08-31-2013, 03:47 PM   #426
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
I would go into the local forum or into the tuning thread where you signed up to get tuned and ask
Thanks
Ron
Old 08-31-2013, 04:28 PM   #427
microsnook
Member#: 313952
2006 STi
SGM DOM 3xt-r
Ok Thanks
microsnook is offline   Reply With Quote
Old 09-02-2013, 07:47 AM   #428
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
This is a ton to read
breezeby is offline   Reply With Quote
Old 09-04-2013, 11:19 AM   #429
SubaruWrxSTR
Member#: 199039
11 Sti Closed Deck
15 wrx CVT
great info
SubaruWrxSTR is offline   Reply With Quote
Old 03-17-2014, 02:26 PM   #430
jsubaru04
Member#: 302458
Anybody knows what gap I should be running on one step colder plugs on an Sti I'm getting tune by Mikey next month
jsubaru04 is offline   Reply With Quote
Old 03-17-2014, 02:39 PM   #431
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Did you read the thread at all? What type of turbo, what type of fuel?...Ron pretty much spells it out for you in post #5.
wgr73 is offline   Reply With Quote
Old 03-17-2014, 02:47 PM   #432
Phatron
Member#: 36033
CEO PhatBottiTuning
Why my thread no sticky yet?
Old 03-17-2014, 02:59 PM   #433
8thWonder
Member#: 230366
2005 STi
it's motor buildin' time!
+1 for sticky status
8thWonder is offline   Reply With Quote
Old 03-17-2014, 03:03 PM   #434
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Makes no sense, this is one of the most informative threads on NASIOC.
Old 03-17-2014, 05:04 PM   #435
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I don't get it. This is a great thread and I vote for sticky status!
Old 03-17-2014, 07:33 PM   #436
Phatron
Member#: 36033
CEO PhatBottiTuning
Alan you should post your updated turbo info in here....or at least link the thread.
Old 03-17-2014, 07:46 PM   #437
manitou
Member#: 193757
2006 XTI Limited
Good idea! I'll let Xluben know and I'll link it here. How's your dyno cell? Done and making tunes I hope! BTW, which Mustang did you install?
Old 03-18-2014, 11:15 AM   #438
manitou
Member#: 193757
2006 XTI Limited
Ron, Here is a link to the Turbo Spec Comparison Table (Wheel Sizes, Max Airflow, Bearings, Etc.) thread that Xluben and I put together. http://forums.nasioc.com/forums/show....php?t=2559017
It should make a good addition to this Tuning FAQ & Misc Info thread in helping people with their turbo choices. Xluben is going to do an update to the thread sometime soon and add a couple more turbos that have been getting some attention!
Mods: Please sticky this thread!
Old 03-20-2014, 11:03 AM   #439
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Hey Ron,
Is it possible to "squeeze by" with the factory Map sensor on the bugeye if I decide to do Cobb SD and not go past 21-ish psi?
Subian is offline   Reply With Quote
Old 03-20-2014, 02:50 PM   #440
Phatron
Member#: 36033
CEO PhatBottiTuning
The issue with higher boost on the stock map is either inadvertently disabling the overboost fuel cut by setting the limit too high or constantly hitting overboost fuel cut in cold temps and high gears.
You can run 21psi in 3rd....but in cold temps and 4th/5th gear you may hit 23psi. It depends on your boost control (mbc v ebcs) and how the wgdc is setup.
Old 03-20-2014, 03:23 PM   #441
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Hallman mbc/ewg, shouldn't fluctuate much...
Old 04-14-2014, 12:36 AM   #442
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Do you have any experiences or thoughts on the 71hta and a 205?
Zee Biker is offline   Reply With Quote
Old 05-12-2014, 01:34 PM   #443
tomtom84
Member#: 167794
08 STI 6266 e85 DD
91 miata and 71 porsche
This still needs to be a sticky.
bump
tomtom84 is offline   Reply With Quote
Old 11-06-2014, 11:53 AM   #444
tomtom84
Member#: 167794
08 STI 6266 e85 DD
moving back to the top.
Old 01-06-2015, 04:19 PM   #445
uglybetty
Member#: 381907
2005 forester STI
So much good info.
uglybetty is offline   Reply With Quote
Old 01-18-2015, 12:40 AM   #446
Rubber_Dubber
Member#: 334547
2007 WRX STi
Trying to decide between a dom 1.5xtr and 2.5xtr. Will be tuned on e85 with supporting mods including built motor. My main concerns are the difference in spool in both 8cm and 10cm options, and the real world power difference between the two turbos considering the 2.5xtr is only rated at 10 more hp than the 1.5. Power goals are low 400whp on e85.
Mods:
Built motor (pistons, rods, bearings)
Heads not built
Grimmspeed EBCS
4-bar MAP sensor
ID2000 injectors
DW300 pump
Full catless TBE
Cobb AP v3
GM IAT for speed density tune
TGV deletes
Samco OEM size turbo inlet
Process West TMIC w/3 sprayers
Any experience or advice on camparisons between the 1.5 and 2.5 will be helpfull, especially spool characteristics. Please note heads are not built, so I will not be able to enjoy a high reving engine. Car is a daily, but where I live we dont have bad traffic and nice roads, so driveabilty isn't really a concern to me.
I have done research on the 1.5 and 2.5 and cannot really find much on the 2.5. I am well aware of the 1.5 spooling faster, yet I have heard the 2.5 is near the same spool as the 1.5 from some sources, while other sources have claimed the 2.5 has a lot of lag. So, what's the real deal difference between these two turbos?
Rubber_Dubber is offline   Reply With Quote
Old 01-18-2015, 01:09 AM   #447
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Default PhatBotti Tuning - Tuning FAQ & Misc Info
A Dom 1.5xtr will make your goals on E85 easily. Get the 8cm housing, it'll spool faster and make almost the same power as the 10cm
Old 01-18-2015, 02:15 AM   #448
Rubber_Dubber
Member#: 334547
2007 WRX STi
Any comparison to the 2.5 regarding spool?
Old 01-19-2015, 12:00 AM   #449
Phatron
Member#: 36033
CEO PhatBottiTuning
I would get the 2.5xtr 10cm
There is virtually no diff in spool between the 8 and 10cm.
The 1.5xtr is basically a 2.5xtr made for a 2L. If you a have a 2.5L get the 2.5
Old 05-22-2015, 09:35 AM   #450
danger1138
Member#: 279525
04 rex luger!
I was reading the beginning of this thread and read info regarding spark plug indexing. I was curious as to why not index spark plugs so that the ground strap is at the 6 o'clock position as opposed to the 12 o'clock position. That way the ground strap is not in the way of the oncoming air from the intake valves. Wouldn't you want the electrode to be unobstructed from oncoming air charge and not have ground strap in the way?
danger1138 is offline   Reply With Quote
PhatBotti Tuning (merged thread) BoostinChick Vendor Reviews 108 04-24-2016 06:49 PM
PhatBotti Tuned - 205k Mile 02 WRX Wagon - 12.4 @ 111 benit0 Proven Power Bragging 14 11-04-2011 09:06 AM
Brake Fluid FAQ & Pedal Feel Info (the reference post) 8Complex Brakes, Steering & Suspension 37 06-06-2008 08:47 AM
PDX Tuning Dyno Day - Final Schedule & Payment Info - Standby folks read as well! Geoff Texas Impreza Club Forum -- TXIC 108 05-04-2006 07:26 PM
MWSOC/INR Event: July 7th Merrillville autoX - Full Event & Caravan Info 8Complex Mid West Subaru Owners Club Forum -- MWSOC 55 07-08-2001 11:08 PM
