Welcome to the North American Subaru Impreza Owners Club Saturday January 24, 2015
Old 11-30-2011, 11:43 PM   #1
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Default EJ20K vacuum line?
So,
I want to install a boost gauge on my completely stock EJ20K.
Looking at the intake seems like I have 3 options to put the "T":
1-) The line thast goes to the boost controller?
2-) The line that goes to the BPV (much wider hose than the hose that comes with the gauge and it would be too big for the "T" as well)
3-) Don't know where this hose goes to?
What would you guys recommend? Where will the reading be much mor accurate and avoid any issue on my car?
wrxstijdm is online now   Reply With Quote
Old 12-01-2011, 07:54 AM   #2
pmugabi
Member#: 280926
Isn't no. 1 the line that goes to the MAP sensor? Anyway, the line you want to use is the one that goes to the MAP sensor.
The line to the stock boost controller should come off the turbo outlet nipple which never sees any vacuum.
pmugabi is offline   Reply With Quote
Old 12-01-2011, 10:17 AM   #3
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
So #1 goes to the MAP sensor? If so, then should I "t" the line from that one?
Old 12-01-2011, 10:18 AM   #4
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Aditionally, what you guys think about this gauge in particular?
http://www.glowshiftdirect.com/Blue-...ost-Gauge.aspx
Old 12-02-2011, 04:46 AM   #5
scrappydoo
Member#: 23630
97 v4 STi RA
Feather White, 02 WRX MBP
Mine is tee'd on #1.
scrappydoo is offline   Reply With Quote
Old 12-02-2011, 09:59 AM   #6
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Ok and I assume is working perfectly there?
Old 12-02-2011, 05:49 PM   #7
scrappydoo
Member#: 23630
97 v4 STi RA
Ya it's working fine. Mine is a defi gauge if you're curious.
Old 12-03-2011, 10:42 AM   #8
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Sounds like you've got the plumbing sorted out. As for the Glow Shift gauges you get what you pay for. I provided feedback under the product review forums on these gauges. I bought these for my '93 GF8 Lemons/Chumpcar and they were junk. They are inexpensive for a reason.
beaviscih is offline   Reply With Quote
Old 12-05-2011, 10:38 AM   #9
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
i would (and have had to) replace all the hoses .. chances are when you remove it it will be so tough that it will snap and you won't be able to get the T in
EJ20K Vacuum Switch under Intake Manifold EVAP Question x777 Pre-2002 Factory Turbo Powertrain 2 06-26-2011 02:12 PM
oem boost line vacuum line jasono718 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-27-2010 10:51 AM
EJ20K vacuum diagram SJwrx Pre-2002 Factory Turbo Powertrain 2 02-24-2010 07:30 PM
WTB: Restrictor pill for factory turbo vacuum lines & factory turbo vacuum lines roninsoldier83 Private 'Wanted' Classifieds 4 10-01-2007 10:14 PM
What vacuum line filter is this? OBSS Normally Aspirated Powertrain 0 04-18-2001 04:01 PM
