Old 11-01-2011, 10:03 PM   #1
gonzo1
Member#: 243589
2005 Impreza WRX
Default whats the right reading
I just wanted to ask what should the right "-" reading be on the boost gauge. Mine when idling is usually average -8.5 to -9.5. Is that normal? Thanks guys
gonzo1 is offline   Reply With Quote
Old 11-02-2011, 10:02 AM   #2
Cobb Tuning
Member#: 4803
At idle, the engine is under vacuum and the reading shown by your boost gauge will be depedent on RPM, throttle position, and barometric pressure. So, there really is no right or wrong reading (within reason). If you are trying to determine if you have any intake leaks, the best way to do that is via logging if you have an AccessPORT v2 by looking at your long-term fuel trims (A/F Learning 1) after a good amount of cruise-type driving.
Bill
Old 11-02-2011, 11:03 AM   #3
gonzo1
Member#: 243589
2005 Impreza WRX
Ok that sounds great, thanks, i do have a V2. So after I go for a cruise, what am I looking for??
Old 11-02-2011, 12:27 PM   #4
Cobb Tuning
Member#: 4803
The cruise-type driving is only if you've recently reflashed a map, installed the AP, reset the ECU (via AP), or disconnected the car's battery. Doing that would clear the learning and you would need a decent amount of cruise-type driving for it to re-populate correctly. But, if it has been more than a week of driving since any of those operations, you can view the four current long-term fuel trims via the "Monitor" -> "Live Data" function on the AP. You want to look at A/F Learning 1 A, B, C, D. Generally, each of these should be within +/- 5%. If they are outside +/- 8%, then you likely have a fueling issue which could be any of a number of things.
We also have a data logging video that you might want to check out:
Bill
Old 11-03-2011, 10:11 AM   #5
gonzo1
Member#: 243589
2005 Impreza WRX
Thanks!!! This is great help.
Old 11-10-2011, 07:41 AM   #6
gonzo1
Member#: 243589
2005 Impreza WRX
Ok, did and took a pic off screen,looks ok, but you let me know for sure please. Thanks guys
Old 11-10-2011, 07:42 AM   #7
gonzo1
Member#: 243589
2005 Impreza WRX
Old 11-10-2011, 09:07 AM   #8
Cobb Tuning
Member#: 4803
You'll want to post the actual log. You can do this by uploading it to google docs, set the permissions to public, and then put a link to the log in this thread.
Bill
Old 11-10-2011, 10:13 AM   #9
gonzo1
Member#: 243589
2005 Impreza WRX
Ok, I learn something new everyday. Here, hope I did it right
https://docs.google.com/spreadsheet/...1BYTW1vUU5iSFE
Old 11-10-2011, 10:31 AM   #10
Cobb Tuning
Member#: 4803
You did it right.
What car is this (05 WRX)? What mods do you have? What map are running?
Bill
Old 11-10-2011, 11:03 AM   #11
gonzo1
Member#: 243589
2005 Impreza WRX
Nice and sorry should of mentioned. I have a 05 WRX, mods running: VF43, 07 Sti injectors, larger TMIC, Perrin short ram intake, Perrin turbo intake hose, grimmspeed mbc, Turbosmart dual port bov, catless up pipe, Cobb down pipe, Invidia 3" exhaust. Im using temp. your shelf map of VF39, sti pinks on 93oct. It feels ok and I will be getting it pro-tuned at P&L hoping next week depending when Junior gets in. Also I will be removing the Mbc and adding Grimmspeed EBCS before the pro-tune. So does it look ok?
Old 11-10-2011, 12:26 PM   #12
Cobb Tuning
Member#: 4803
You're overboosting at least compared to what we are running in our stage 3 map (because of MBC). I would stay out of boost as much as possible until you get tuned.
Bill
Old 11-10-2011, 03:51 PM   #13
gonzo1
Member#: 243589
2005 Impreza WRX
I figured that. But other numbers look ok? And still waiting on a call from p&l
Old 11-10-2011, 04:27 PM   #14
Cobb Tuning
Member#: 4803
Looks fine - just stay out of boost as much as you can until your tune or switch back to the factory bcs with this map.
Bill
Old 12-08-2011, 04:43 PM   #15
gonzo1
Member#: 243589
2005 Impreza WRX
Ok, I'm back. I got a pro-tune and these are my results. How does it look now? Thank you
https://docs.google.com/spreadsheet/...GhRWVNyaDBBYVE
Old 12-08-2011, 05:08 PM   #16
Cobb Tuning
Member#: 4803
You'll want to check with the protuner - it difficult to see what they intended as it relates to boost especially if you are still running the MBC.
Bill
Old 12-08-2011, 05:14 PM   #17
gonzo1
Member#: 243589
2005 Impreza WRX
Pro-Tuner Junior at P&L said I should be boosting around 18psi and I'm running a Grimmspeed EBCS. Does it not look well and should get tuner to reconfigure it? Hope not Thank you
Old 12-08-2011, 09:33 PM   #18
bzbuzz
Member#: 116052
2011 STI ( Sold )
if you got your car protuned with a good tuner, your tuner has a responsiblity to support all your concerns/questions after tune. thats what you paid for. no reason to ask around internet.
bzbuzz is offline   Reply With Quote
Old 12-08-2011, 09:49 PM   #19
gonzo1
Member#: 243589
2005 Impreza WRX
I have talked to P&L . Is taken care of. Just wanted an opinion from someone else. Nothing wrong with that. Nuff said!
Should I Refinance Not Sure Whats The Right Move?? Destroy Off-Topic 6 10-07-2010 08:30 AM
Scic Whats The Right Thing To Do Here xt-b Southern California Impreza Club Forum -- SCIC 74 09-28-2008 02:24 PM
What is the right oil pressure reading MikalsWRX Service & Maintenance 3 01-15-2007 10:06 PM
Read the headline ... then look at the ad on the right. SkirtBoy Off-Topic 5 03-04-2004 10:03 AM
Whats the right exhaust for me? virus67 Newbies & FAQs 8 01-08-2002 09:12 PM
