Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 01-11-2012, 08:53 AM   #26
bluemax189
Member#: 137405
2011 WRX
20g
sadly i have the v1 on my hatch. the inlet to the muffler is totatlly different in the v2, much more straight through than mine. Im assuming this is where the extra bit of volume might come from.
doing a quick search on google shows you these:
V1
and the V2
bluemax189 is offline   Reply With Quote
Old 01-18-2012, 07:31 PM   #27
acozzubbo
Member#: 307158
2012 STI Limited
how hard was it to install the downpipe? was it a pain to do
acozzubbo is offline   Reply With Quote
Old 01-18-2012, 09:50 PM   #28
Overland04
Member#: 293311
2011 Impreza
Leguna Seca Blue
The hardest part was definitely the bolts around the turbo. 2 of them are really easy ans straight forward, three of them are a little harder.
A good assortment of 14mm wrenches, sockets, 4"+6" extensions, 1/2" drive ratchet and breaker bars... Or an impact gun.
I first tried to do it without taking the intercooler off and quickly realized that the 5 minutes to take it off could have been the best move for the entire install.
If you get hung up, feel free to ask anything!
Overland04 is offline   Reply With Quote
Old 02-12-2012, 05:46 PM   #29
Fahrenheit
Member#: 262306
2011 WRX 5-Door SWP
I also just got the Q300 and experience the same noise issues. It feels like pressure is building inside the car and the only thing that helps is to crack a window or the sunroof. It actually hurts my ears after a long drive.
Does anyone think lining the trunk floor with Dynamat or similar material will help?
Fahrenheit is offline   Reply With Quote
Old 02-12-2012, 07:44 PM   #30
BigRob74
Member#: 305107
2012 wrx
360/386 E85
sounds good!
BigRob74 is offline   Reply With Quote
Old 02-12-2012, 08:04 PM   #31
jpatt006
Member#: 289470
2011 WRX stage 2+
I don't know about dynamat, but I picked up some ensolite and it helped a lot. If you aren't familiar with it, it's almost like a thin foam with adhesive. I lined the whole bottom of my trunk with it.
I may do dynamat too, either that or cut up my old egg crate mattress pad from college haha.
jpatt006 is offline   Reply With Quote
Old 02-25-2012, 02:01 AM   #32
nighthawk06si
Member#: 267490
2011 WRX Hatch S2+SF
i don't meant to jack the OP's thread or anything but i figured you guys would know the answer to this pretty noob question, it should be pretty obvious but which way do you guys have that Invidia sticker facing on the resonator on the v2 q300?
Im getting crazy rattling/metal on metal noises under the car from the resonator hitting against the frame and I switched out to kartboy standard hangers already, it stopped the noise for a couple days but it came back and now it's getting worse by the day.
thanks.
nighthawk06si is offline   Reply With Quote
Old 02-25-2012, 09:04 AM   #33
sizemic1
Member#: 270669
2011 WRX Sedan
Stg 2 Phatbotti e-tuned
Wrap the resonator with exhaust wrap and the problem will solved. Worked for me. I also wrapped the flex coupler.
sizemic1 is offline   Reply With Quote
Old 02-25-2012, 11:02 AM   #34
Overland04
Member#: 293311
2011 Impreza
Leguna Seca Blue
thanks.
No worries about hopping in on the thread. I actually like questions in the thread instead of a PM, that way all members get to see possible answers.
You may have tried this already but when I was lining up the exhaust, I ended up hanging the entire exhaust but left all the bolts really loose and aligned it from where the closest point of contact was. There is actually a lot of play in the exhaust if needed.
Also, do you have an Invidia Down pipe? i have a feeling that if you have the stock DP, the exhaust is actually back an inch or two farther then it would with a aftermarket DP. It should still fit perfectly fine but might need some more time with alignment.
There is no way to put the mid-pipe on wrong, the rear section would would be facing sideways if it was. I test fit mine on the ground just to be safe but you must have it on correctly in order for anything to line up.
Good luck mate,
- Jason
Old 02-25-2012, 05:34 PM   #35
nighthawk06si
Member#: 267490
Good luck mate,
- Jason
Yeah, that's exactly how I did it, i re-aligned with everything on but the bolts still loose again when i switched it out for the kartboy hangers. And I do have the Invidia catted downpipe.
I figured it was on right or else yeah, nothing would really line up. But the flex joint in the midpipe is angled downward and i felt that it should be angled upward cause why would invidia not use that space under the heatshield and lower the ground clearance by setting it up like that so I figured I ask the guys on here who have it which way the Invidia sticker on the resonator is facing to get an idea and to reconfirm that it is on correctly.
Old 02-27-2012, 10:23 AM   #36
bluepearlrex12
Member#: 310184
2012 WRX
Blue Pearl
sounds awesome. I will be installing this CB tomorrow, hope it sounds as good as yours. probably won't cause I don't have a down pipe.
bluepearlrex12 is offline   Reply With Quote
Old 02-27-2012, 12:23 PM   #37
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
I don't mean to "jack" this thread, but it's related -- I've got a buddy that will sell me a Perrin Dual tip 3" (Single pipe) exhaust for my 05 STI for like 400. I'm planning on keeping my ProSport 3" belmouth dp.
I'm looking for a deep raspy sounding exhaust, without going broke. Do you guys think i'm better off with the Invidia, or should I go for the Perrin exhaust?? I've looked all over for videos of the Perrin exhaust, but haven't found too much; he says it's loud.
Cheers!
BeastianSTI is offline   Reply With Quote
Old 02-27-2012, 12:50 PM   #38
Dmochowski
Member#: 306478
2012 WRX limited
305whp/360tq TSM tuned
someone replied to this so i thought it was new and i read that the AP was 10% off lol i was excited too bad this post is 2 months old and its not on sale anymore!
Dmochowski is offline   Reply With Quote
Old 02-27-2012, 02:12 PM   #39
turbodreamz22
Member#: 197689
What camera did u use for the video!!!!
turbodreamz22 is offline   Reply With Quote
Old 02-27-2012, 02:28 PM   #40
Overland04
Member#: 293311
2011 Impreza
Leguna Seca Blue
Hmmmm, I just checked on the sticker and it is facing up. They might put the sticker on different so the best way to explain is that the flex pipe is definitely sitting down or "U" shaped. I actually never noticed how low this exhaust sits... Woah!
Old 02-27-2012, 02:35 PM   #41
Overland04
Member#: 293311
2011 Impreza
Leguna Seca Blue
Cheers!
I've heard a couple Perrin exhausts on the new wrx/sti body style and they are overall a lot louder. The Invidia is actually a super smooth strong sounding exhaust. It's has a loud tone at certain RPM inside the car but even outside at that same tone it's a smooth clean tone.
I feel the Perrin is just loud in general, has a nice gurgle but overall kind of sloppy. I had the same issues with the COBB, I wanted it so bad but its just nothing close to the sound of the invidia.
Old 02-27-2012, 03:05 PM   #42
Overland04
Member#: 293311
2011 Impreza
Leguna Seca Blue
sorry man...
I actually bought the AP for the full price and before I received it they went on the 10% sale. I ended up calling Rally Sport Direct and they made me buy a new AP at the lower price and return the first AP for a full refund.
Hey Man, I shot it mostly with the Canon 5D Mark II and a whole bunch of lenses. It was edited on Final Cut Pro 7.
Thanks for watching!!
Old 02-27-2012, 03:58 PM   #43
PearlRex11
Member#: 284420
2011 WRX Sedan
I have the sedan but I agree that nothing comes close to the q300 sound. Sounds mean but also refined at the same time.will be keeping mine forever.
PearlRex11 is offline   Reply With Quote
Old 02-28-2012, 08:52 PM   #44
grassrooted13
Member#: 308235
i wish i had money for this...
grassrooted13 is offline   Reply With Quote
Old 02-28-2012, 09:42 PM   #45
BigRob74
Member#: 305107
2012 wrx
360/386 E85
so is the consensus on this setup is that its only loud in the 5door?
Old 02-29-2012, 06:16 AM   #46
nighthawk06si
Member#: 267490
Yeah i never thought bout it that way, just thought they'd prob put it in the same spot on every unit. thanks for taking time and double checking on it for me Jason! And yeah, this exhaust is low! lol
Old 02-29-2012, 08:44 AM   #47
Overland04
Member#: 293311
2011 Impreza
Leguna Seca Blue
From what i've been gathering over the past couple months is yeah, the hatch tends to be worse with the droning inside the cabin. I don't know if it's been proven with an actual decibel meter but over the past week I was in a 2009 WRX 4dr and it seemed quieter at the 2500RPM under load drone.
It's totally subjective though. I love the sound but sometimes passengers think it's annoying.
Old 02-29-2012, 09:16 AM   #48
grex11
Member#: 291019
2011 wrx
I have a 2011 5 doorWRX with 25k miles on the Invidia Q300 TBE, I think it is louder now. I love the sound, inside or out.
grex11 is offline   Reply With Quote
Old 02-29-2012, 05:38 PM   #49
PearlRex11
Member#: 284420
2011 WRX Sedan
I know it is subjective but I can positively say that it must be night and day between the too. I know what drone is, and the 2011 sedan q300 doesn't drone at all. I don't think anyone would even slightly consider it droning. I was on the fence actually when I first installed it because it was almost too quiet, and I don't like loud exhausts at all. Now that its broken in I love it and its perfect for me. I don't think even the pickiest would think the sedan drones honestly.
Old 03-01-2012, 01:50 AM   #50
Celery GT-5
Member#: 98210
2015 WRX Premium 6MT
this thread makes me glad that I'm sticking with the stock catback for stage 2. very nice/helpful pics
Celery GT-5 is offline   Reply With Quote
FS: 05 STi APV1 x2, Invidia DP, Tanabe Exhaust, 2.5in Midpipe, APS CAI, TurboXS MBC Nossy Engine/Power/Exhaust 14 12-12-2008 02:25 AM
FS: 05 STi APV1 x2, Invidia DP, Tanabe Exhaust, 2.5in Midpipe, APS CAI, TurboXS MBC Nossy SCIC Private Classifieds 13 12-12-2008 02:25 AM
HKS DP & Exhaust installed... Nactos Newbies & FAQs 7 12-15-2006 08:35 PM
FS: [NY] Invidia DP, JIC titanium catback, aps bov with pics ScreaminFast Private 'For Sale' Classifieds 22 03-02-2005 11:43 AM
Invidia dp + Kakimoto exhaust... does it work WRX-pilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-17-2003 08:29 PM
