#1 |
Member Sales Rating: (1)
Member#: 133196
Vehicle:2006 Black 92x aero external gated 18G |
I’m parting out all of my cars. If there is anything you want let me know and I’ll get back to you. The car is still together so i will have to pull the parts for pictures. PM Me and i will get back to you with pictures as soon as i can. all prices are obo
I’m parting out a 2006 Saab 9-2x Aero/2006 Subaru WRX Wagon. The motor seized a cam gear and destroyed the heads everything else was ok. Aftermarket Parts for sale: $450 CP Pistons for EJ25 (new) $250 Eagle H beam Rods for EJ25 (new) $400 Full Turbo back exhaust (invidia downpipe to Tanabe Medallion Touring exhaust) (30k dp, 25k exhaust) $200 Subaru uppipe with tial 44 flange and dumptube (10k) $500 Deadbolt Zilla 18g turbo with Subaru flange (20k) $80 Whiteline Front Sway Bar (new) $75 Whiteline Rear sway bar (25k) $900 WBR500 Front Mount Intercooler $150 Cobb Accessport for 06 subaru (needs new dongle)(and may still be married to the car) $80 Samco turbo inlet $80 Ingalls adjustable Pitch stop $100 Sti Pink Wagon Springs (26k) $50 Stainless Steel Brake lines (10k) $95 Subaru Kartboy Short Shifter $35 Subaru Kartboy shifter bushings $400 2004 Sti DBA 5000 2 piece rotors (new) (red hat)(drilled & Slotted) $350 2005 WRX DBA 5000 2 piece rotors (new) (black hat) (blanks) $150 2005 WRX DBA 4000 rear rotors (new) $50 Walbro 255 fuel pump Stock Parts $500 Stock 2006 Saab 9-2x Aero/WRX EJ255 Block (36k) $75 Stock 2006 Saab 9-2x Aero/WRX EJ255 Crankshaft (36k) $1500 2006 Wrx 5speed trans (36k miles) $150 Stock turbo back exhaust (5k) $50 Stock rear sway bar (10k) $50 Stock front sway bar (36k) $75 Stock 06 WRX Wagon Springs (10k miles) $50 Stock 06 WRW Wagon rear cargo cover $70 Stock 2006 WRX uppipe (26k) $75 Stock 2006 WRX Exhaust manifolds (36k) $75 Stock 2006 WRX intake manifold (36k) $300 Stock 2006 Saab 9-2x headlights (1 factory Hid, 1 factory Non-HID) $300 Stock 2006 Saab 9-2x Obsidian Black Pearl Aero Hood $300 Stock 2006 Saab 9-2x Aero Factory 16” enkei wheels (some curb rash) $175 Stock 2006 Saab 9-2x Aero Gauge cluster (36k) $125 Stock 2006 Saab 9-2x Aero/ 2005 Subaru Front brake calipers $75 Stock 2006 Saab 9-2x Aero/ 2005 Subaru Rear brake calipers $500 Stock 2006 Saab 9-2x Aero Black and Gray two-tone seats cloth (front & Rear) $75 Stock 2006 Saab 9-2x Aero Gray Headliner $250 Stock 2006 Saab 9-2x Aero Black interior panels $100 Stock 2006 Saab 9-2x Aero black & gray door panels $125 Stock 2006 Saab 9-2x Aero black dash $200 Stock 2006 Saab 9-2x Aero Chassis Wiring Harness $150 Stock 2006 Saab 9-2x Aero Taillights $150 Stock 2006 Saab 9-2x Aero Rear Bumper $75 Stock 2006 Saab 9-2x Aero Front Bumper (needs repair) $125 Stock 2006 Saab 9-2x Aero Roof Rail Deletes $125 each or $225 for both Stock 2006 Saab 9-2x Aero Front fenders $150 Stock 2006 Saab 9-2x Aero Black Carpet $150 Stock 2006 Saab 9-2x Aero/WRX manual pedal set $125 Stock 2006 Saab 9-2x Aero/WRX Wagon brake lines $150 Stock 2006 Saab 9-2x Aero/ WRX wagon gas tank $100 Stock 2006 Saab 9-2x Aero Fog Lights $30 2006 Saab 9-2x Aero front grille painted satin black $125 Stock 2006 Saab 9-2x Aero Stock Rear Spoiler $200 Stock 2006 Saab 9-2x Aero/WRX R160 Rear diff $75 Stock 2006 Saab 9-2x Aero/WRX Wagon Rear Trailing arms $75 Stock 2006 Saab 9-2x Aero/WRX Wagon Driveshaft $50 each or $150 for all 4 Stock 2006 Saab 9-2x Aero/WRX Wagon Axles $75 Stock 2006 Saab 9-2x Aero/WRX Wagon Struts $75 Stock 2006 Saab 9-2x Aero/WRX AC Compressor $150 Stock 2006 Saab 9-2x Aero/WRX Blower assembly $50 Stock 2006 Saab 9-2x Aero/WRX Wagon Gas door $150 Stock 2006 Saab 9-2x Aero/WRX Wagon Seat Belts $125 Stock 2006 Saab 9-2x Aero Steering wheel with airbags $50 Stock 2006 Saab 9-2x Aero/WRX glove box black $250 Stock 2006 Saab 9-2x Aero/WRX Manual ECU (may still be married to COBB Accessport) $200 Stock 2006 Saab 9-2x Aero/WRX radiator w/fans $450 Stock 2004 Sti Front Brembos (one stripped and partially smoothed, one factory gold finish)(Fresh rebuild) Lost of miscellaneous other 2006 Saab 9-2x Aero/WRX Wagon parts minus motor parts I also have a some parts from a couple other cars if you want a price on these just pm and i'll let you know. 1980 Corvette Parts Aftermarket Parts: VB&P Adjustable upper control arms (80-82 corvette) (new only Mounted) VB&P 420# composite rear spring (80-82 mount) (new) VB&P Offset trailing arms (80-82) (new mounted only) VB&P Race Smart Struts w/ Brackets (80-82) QA-1 Double adjustable front coilover setup (80-82 corvette w/ Small Block) Poly Body Mount Bushings Stainless Steel Trailing Arm Shims Stock Parts: Stock 80 corvette front lower control arms w/ new bushings Stock 80 Corvette front spindles Stock 80 Corvette front sway bar Stock 80 Corvette Rear end (Batwing)(new seals) Stock 80 Corvette Frame (straight) (no rust) (currently painted aluminum) Stock 80 Corvette Rear Bumper (Fair) Stock 80 Corvette Front Bumper (Fair) Stock 80 Corvette Front Turn Signals Stock 80 Corvette Headlights Stock 80 Corvette Headlight covers Stock 80 Corvette Headlight bezels Stock 80 Corvette Hood Stock 80 Corvette Gas Tank Stock Tinted glass T-tops (weather-stripping?) Stock 80 Corvette Rear Glass Stock 80 Corvette Taillights Stock 80 Corvette Door Glass Stock 80 Corvette Doors Stock 80 Corvette Windshield Stock 80 Corvette Halfshafts with new U-joints Stock 80 Corvette Composite rear spring Stock 80 Corvette Front Upper Control Arms (new bushings can be installed) Partial Front end rebuild kit Some Miscellaneous interior parts E30 BMW Parts Aftermarket Parts: E30 Reiger Front Lip w/splitter OEM Parts: E30 318is 5 speed transmission E30 Front Bumper E30 Front Valance (Good) E30 Front Valance (Repairable) E30 Front Bumper Corner Mouldings 89 Nissan 240sx Parts 89 Nissan 240sx KA24E motor (overheated has some accessories)(junk) 89 Nissan 240sx Stock Open Diff 89 Nissan 240sx Stock rear axles 89 Nissan 240sx Stock Rear Upper Control Arms I also have 1 16” camaro wheel from 1994 Z28
#3 |
Member#: 133196
at this point I still owe a little money on it so I'm waiting until i pay it off to decide. I'd like to sell it but I'm unsure at this point, the body needs a new passenger quarter panel everything else besides the front bumper is good on it. As of right now all it needs is a motor but I really don't want to put more money into it and I'm looking to buy a house, so i'm parting it out. Are you interested in the shell?
#4 |
Member Sales Rating: (33)
Member#: 170415
NESIC
Vehicle:2002 Hardware store bumper clips, that is all |
I could be for the right price. Do you have any pictures? Basicly i'd be interested in a saab shell with all exterior body parts, no engine, no tranny, no interior, Rolling would be nice for movability but non rolling would be fine as well and keeping the wire harness with ecu. Also what size cp pistons?
#7 |
Member#: 286306
Vehicle:2005 9-2x Aero |
I'll take the cargo cover if it is in good shape. Any way you can get me a photo of it when you get a chance? I can send you payment immediately if its good for me.
Thanks Last edited by Myror; 12-06-2011 at 11:15 AM. Reason: typo |
#11 |
Member#: 54585
Vehicle:2013 WRX WRB |
I'm looking for a few odd things
1) I need one of the license plate light clear lens that covers the bulbs above the license plate and is secured on with two screws. 2) I need the two screws and washers that bolt the rear seat down. I need these small items shipped to 48197. Thank you |
#16 |
Member Sales Rating: (2)
Member#: 152458
Vehicle:2007 Impreza 2.5i OBP w/ Fail |
How much for the front driver's side door? PM me pics if you have them with description of of the condition if possible!
| Thread Tools | |
| Display Modes | |
| 2006 Saab 9-2x Aero (2.5L) or 2006 WRX wagon? | Mencius01 | General Community | 26 | 04-08-2011 10:51 PM |
| FS : OH: 2005 Saab 9.2x aero (WRX) with bad engine | JimBlake | Private Vehicle 'For Sale' Classifieds | 19 | 08-07-2010 10:32 AM |
| Impreza/Saab 9-2x Complete Factory Audio from 9-2x Aero (6 disc, speakers, tweeters). | miscreant | Private 'For Sale' Classifieds | 0 | 08-19-2005 02:08 PM |
| Saab 9.2X Aero brand new under 20G | Rodan | Texas Impreza Club Forum -- TXIC | 83 | 06-09-2005 11:51 PM |
| Saab 9.2X aero in winchester | WorldRallyRedneck | Mid Atlantic Impreza Club -- MAIC | 1 | 08-15-2004 11:30 AM |
