Old 12-03-2011, 05:58 PM   #1
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
Default Connected test cables while engine on
Now the car won't start. Turns over but doesn't start. AP not connecting to ecu. Help.
TheEugeneKam is offline   Reply With Quote
Old 12-03-2011, 06:01 PM   #2
infinite012
Member#: 74392
2013 BRZ
Disconnect the test cables.
infinite012 is online now   Reply With Quote
Old 12-03-2011, 06:18 PM   #3
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
I believe your car will not start when in test mode, or if the white plug is plugged in too.
DSRX2005 is online now   Reply With Quote
Old 12-03-2011, 06:22 PM   #4
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
I did disconnect them still no start
Old 12-03-2011, 06:28 PM   #5
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Everything is unplugged? Hm thats odd. Did you interrupt the map download somehow?
Old 12-03-2011, 06:36 PM   #6
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
No I just had ap connected to the car with the car engine run ign. Then I accidentally connected up the test cables with engine still on and it shut off. Now AP is not reading ecu and the car doesn't start. When I connect test cables again, chec engine doesn't flash like it should.
Old 12-03-2011, 06:51 PM   #7
Its_Stevoh
Member#: 209765
2004 wrb wrx sedan
Unplug the battery and sit on the brakes, plug it back in and try again
Its_Stevoh is offline   Reply With Quote
Old 12-03-2011, 07:04 PM   #8
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
Tried that tool nothing. I unplugged id the brake and left it now for 30 min disconnected. Nothing.
Old 12-03-2011, 08:31 PM   #9
subiebui
Member#: 120839
2012 WRX STI Sedan
may have fried the ecu D:
subiebui is offline   Reply With Quote
Old 12-03-2011, 08:58 PM   #10
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Am I a bad person for loling at this?
i_c_the_light is offline   Reply With Quote
Old 12-03-2011, 09:28 PM   #11
TheEugeneKam
Member#: 299335
2007 WRX Limited
Urban Grey Metallic
Yes ^^ lol.
This SUCKS!!! It looks like no one else has made this mistake, my head, its full of ****!
AT - turn engine on while rolling blinker5 Transmission (AT/MT) & Driveline 15 03-13-2008 09:18 PM
so where do i connect tactrix cable? stevey323 Newbies & FAQs 3 03-10-2007 07:00 PM
Buzzing from engine while engine is off and cold.... C.J. Newbies & FAQs 5 02-15-2007 09:08 PM
Where to connect tactrix cable on 2006 WRX? eggeegg Newbies & FAQs 12 02-10-2007 07:39 PM
Need help with bizzaar engine failure while driving on the freeway asianwebmaster101 General Community 15 11-01-2005 02:41 PM
Message Board Statistics All times are GMT -4. The time now is 09:45 AM.
