Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 08-09-2002, 08:43 PM   #1
Member#: 16736
2002 WRX Sedan
Question Does tire pressure matter in 1/4 mile
I know our car is AWD and gets good traction, but is it better to lower the tire pressure to get a better time? What should be the PSI for best time?
beefcake6681 is offline   Reply With Quote
Old 08-09-2002, 09:48 PM   #2
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
I ran my best 1/4 miles with 40 lbs PSI on the stock 16" wheels. I got that from another i-club member and it worked for me too.
Good Luck.
Sordid Philosopher is offline   Reply With Quote
Old 08-10-2002, 01:11 PM   #3
Member#: 8335
96 Impreza L 2.2t
99 Impreza L Wagon
its a trade off you see,
Lower pressure improves traction on the line, but adds rolling resistance down track.
Higher pressure may take a little traction away, but decreases rolling resistance.
with my skill level and lack of consistency on the launch, I haven't been able to decide which is better, but I have heard everything from 25 to 40 psi.
Elwood is offline   Reply With Quote
Old 08-10-2002, 01:35 PM   #4
Member#: 10794
2002 Impreza WRX
13.47 @ 98.98MPH
40PSI here
SubyRex is offline   Reply With Quote
Old 08-10-2002, 09:55 PM   #5
Member#: 14141
2002 Impreza WRX
Default higher is better
I've found pressures above 35 psi are best for a stock setup. I have run both 35 and 40 and not found a lot of difference, but dropping to 26 psi cost me nearly a full second.
I think for the big power guys the traction gained at the starting line is more important than the increased rolling resistance, as they have the power to pull the increased rolling drag.
For those of us making near stock power we lose more to increased rolling resistance, as we can only spin the tires for a couple feet off the line, so gain very little ET by increasing the off the line traction.
hotrod is offline   Reply With Quote
Old 08-12-2002, 01:14 AM   #6
Member#: 18123
2013 Evolution X GSR
I'm 13.8 almost no matter what I do, but since the front dif is open and prone to wheelspin, I like 30 front/ 40 rear on the 1320 track. I can virtually guarantee 1.8s like that.
Noize is offline   Reply With Quote
Old 08-12-2002, 01:55 AM   #7
Member#: 14141
2002 Impreza WRX
Default Very interesting observation
Interesting observation. I have not juggled tire pressures front / rear yet, all my runs were equal pressure all around.
Lower front certainly makes sense and is worth a few passes to check out. Controlling front wheel spin is one issue I plan on addressing as I sort things out.
Old 08-12-2002, 06:58 AM   #8
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default What works!
25psi front, 40psi in the rear
This is what worked for my OBS Wagon the best. Here's why!
1) I experienced really bad and severe wheel hop due to high tire pressures in the front tires. I was forced to reduce tire pressure,
2) Traction improved with reduced tire pressures in front. I believe the auto/AWD has a 90/10 torque split. With a torque split like that, you want good traction up front or else time is lost for that fraction of a second trying to get traction. The wheel hop bouncing the tires off the ground was another reason traction was lost as well.
The rear tires where put to 40psi because it prevents the weight from shifting to the rear. Had it been say, 25psi or so, you would see the weight compress the rear tire. The stiffer the rear, the better it helps prevent weight from shifting to it. Shorter sidewalls and spring spacers would help too but isn't necessary. Oh yeah, and the 40psi helps with rolling resistance as well.
Kevin Thomas is offline   Reply With Quote
Old 08-14-2002, 04:36 AM   #9
Easy Street WRX
Default things to think about
there are alot of factors that should be considered , here are some that might help
sidewall integrity of tire, soft, slick style sidewall, lower pressure works better
weight of car
hp delivered to wheels
stick or auto, auto preloads, stickshifts snaps
size of tire,
compound, suspension, track condition, etc,
what best works for me is testing different psi and seeing how the car reacts, just try do change one thing at a atime and see if it works better, keep every other variable the same and just change psi by a few pounds. Once you feel the neck snapping launch you'll know. ali
What Turbo Does the Legacy GT Have? 1/4 mile times? Turbo20VJetta Legacy Forum 13 09-23-2004 01:50 PM
Effects of tire/wheel weight on 1/4 mile times??? B-Kerr Brakes, Steering & Suspension 0 02-17-2003 02:15 AM
Tire weight effects on 1/4 mile times? Tronner Brakes, Steering & Suspension 1 10-11-2002 06:26 PM
3/16 connector mod worth 4/10s sec in 1/4 mile TubeDriver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-13-2002 02:33 PM
fastest svx in 1/4 mile KEVINL SVX Forum Archive 2 03-22-2001 09:56 PM
