Old 12-04-2011, 12:15 PM   #1
DreksSTI
Member#: 287573
2007 WRX STI
CGM
Default Does anyone actually know the Proper steps to a boost leak test?
I hate to beat a dead horse here, But I have been searching and reading the threads here about Boost testing and just about every thread says or does something different.
I know I need to Block off the 4 lines including the Purge valve so I dont get the Buzzing sound. But what about the oil cap? does that need to removed so the cam seals are not toasted. And some guys says to pressurize to 5-10psi max, some say do 15+psi but no more than 20psi. Can you guys please help me out with a more straight forward answer, I am trying to get this done today since my car is running lean at WOT.
Thanks in advanced, Its really appreciated!
DreksSTI is offline   Reply With Quote
Old 12-04-2011, 01:29 PM   #2
DreksSTI
Member#: 287573
2007 WRX STI
CGM
bump it up
Old 12-04-2011, 02:28 PM   #3
DreksSTI
Member#: 287573
2007 WRX STI
CGM
Bump it up
Old 12-04-2011, 06:17 PM   #4
DreksSTI
Member#: 287573
2007 WRX STI
CGM
Where is my Purge Valve Because I sure as hell couldnt find it today while attempting the test?
And is this the PCV hose? If so, How do you remove it, Arent those the permanent style clamps?
Old 12-04-2011, 08:08 PM   #5
DreksSTI
Member#: 287573
2007 WRX STI
CGM
Anyone?
Old 12-05-2011, 12:20 AM   #6
DreksSTI
Member#: 287573
2007 WRX STI
CGM
night bump
Old 12-05-2011, 07:17 AM   #7
blame
Member#: 226359
2006 WRX
obp
in the first pic, purge valve line comes off that shiny curved nipple just to the left of the alternator, line goes to purge valve, then continues to the turbo inlet. remove both lines (from intake mani and from turbo inlet) and cap them.
in the second pic, yes that's your PCV hose and yes, that's a permanent clamp (oetiker clamp). look a little left of that clamp to where the rubber hose connects to the plastic piece, that plastic piece can be removed from the turbo inlet nipple (has a press button to release thing like a wiring harness connector). remove it and you can cap the plastic nipple deal on the turbo inlet (needs a pretty big cap, can't remember the exact diameter).
removing the oil cap: some say do it, some say it's not necessary. it takes 3 seconds, just do it.
basically, remove all the hoses that go to the turbo inlet and cap them, cap the purge valve nipple on the intake mani as well, remove oil cap, and giv'er.
personal opinion: checking for leaks at 5-10 psi is pointless. i wouldn't try to push 40 psi in there, but my tune has me running 18psi so if my setup can't hold 15-20, i wanna know about it while i have my head under the hood, not while i'm driving
hope that helped
-sean
blame is offline   Reply With Quote
Old 12-05-2011, 08:55 AM   #8
DreksSTI
Member#: 287573
2007 WRX STI
CGM
hope that helped
-sean
Thanks alot my friend, That helped me out. If anyone else has any input, they are more than welcome to chime in. Thanks
Old 12-05-2011, 03:39 PM   #9
maxplanck
Member#: 255498
WRX specific, but perhaps useful: http://www.3gwrx.com/forum/index.php?topic=20671.0
maxplanck is offline   Reply With Quote
Old 12-05-2011, 03:59 PM   #10
DreksSTI
Member#: 287573
2007 WRX STI
CGM
That link was one of the links I had been lookin at. Just needed some things clarified. thanks tho
Old 12-05-2011, 07:30 PM   #11
DreksSTI
Member#: 287573
2007 WRX STI
CGM
Anyone else have any input?
Old 12-05-2011, 08:16 PM   #12
SkateAndDestroy
Member#: 133893
JBP 04 Forester XT
PSM 02 WRX Wagon
What are you using to pressure the inlet? I bought a 5 gallon air tank for like $25 which works well. All the cheap air compressors would either not be strong enough to pressurize, or they would keep cycling making it hard to hear the leaks. It was cheaper for me just to buy the air tank than an a larger compressor.
What kind of boost leak tester do you have, does it have a pressure gauge to see how much is in the turbo inlet?
SkateAndDestroy is offline   Reply With Quote
Old 12-05-2011, 09:19 PM   #13
DreksSTI
Member#: 287573
2007 WRX STI
CGM
I am using a Smallish compressor and tank that has a regulator on it. I have a valve attached to a PVC cap.
Old 12-05-2011, 09:57 PM   #14
WRX 2002
Member#: 11211
2004 STi
Rally Blue
You should spray soapy water on all the joints on the air intake and see if you can see bubbles. This way you can see even minor leaks, trying to hear leaks will only work for large leaks. its amazing how many small leaks you might find on a highly modified intake system sometimes.
WRX 2002 is offline   Reply With Quote
Old 12-05-2011, 10:25 PM   #15
DreksSTI
Member#: 287573
2007 WRX STI
CGM
will be sure to spray soapy water. My intake is stock.
Old 12-06-2011, 01:28 AM   #16
blame
Member#: 226359
2006 WRX
obp
+1 on the soapy water, lets you use your eyes to check for leaks as well as your ears
Old 12-06-2011, 08:13 AM   #17
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
2gnt2wrx is offline   Reply With Quote
Old 12-06-2011, 08:57 AM   #18
DreksSTI
Member#: 287573
2007 WRX STI
CGM
^^thanks for that link. Thats helps me feel a lot better
Old 12-06-2011, 09:19 AM   #19
guygettnby
Member#: 298231
2011 WRX
theres some good info in this thread. thanks to the people who posted links. i need to do one myself and wasnt 100% sure wich lines needed to be capped off and if i could do it from the intake pipe.
now does anybody know the exact size caps needed for this? i am not sure if my old testers will fit on this car or not and i would just prefer to buy some new parts to make a new setup anyhow. mine are pretty old and probably just need to be replaced anyhow.
guygettnby is offline   Reply With Quote
Old 12-06-2011, 06:44 PM   #20
DreksSTI
Member#: 287573
2007 WRX STI
CGM
Well this is interesting, Been talking with [email protected] and he says they leave everything plugged in when they run their pressure test. If you remove the lines from the inlet hose then how will you know if one of lines has a leak or not? Makes since. So now I am back to being unsure lol
Old 12-06-2011, 09:07 PM   #21
DreksSTI
Member#: 287573
2007 WRX STI
CGM
Also he said if your lines on the inlet hose are popping off with only 5-10psi then they dont have a very good connection and need to be connected better.
Old 12-06-2011, 09:18 PM   #22
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I'm pretty sure Chris misunderstood you!
If you leave them all connected it won't work, You will shoot pressurized air straight into your crankcase, and if your oil cap is off it will just blow out the filler neck. I have done this test on two of my cars, a WRX and an STI, like 100 times and it works very well. You are just plugging the crankcase breather, the tube that goes to the breather that splits to the heads and to the "kazoo" which is part of the fuel vapor line.
The lines to the boost controler will stay connected.
Just an idea/hint.... Get long bolts, the kind that have a smooth area between the head and the threads, Cut them down and use them to plug the hoses. You will need a couple different sizes that fit your lines along with hose clamps to keep them from shooting out.
Keep in mind you will want everything you are plugging to be tight! You need to be very careful, 15psi can really hurt if something goes wrong. I've destroyed a tester by it flying out of the inlet tube and exploding against the fender. So like I said BE CAREFUL!! I tested my sti up to 25psi when I was running E85, You should shoot for a couple psi above what you plan on running for boost.
Old 12-06-2011, 09:31 PM   #23
DreksSTI
Member#: 287573
2007 WRX STI
CGM
Thanks for your info.
I am pretty sure Chris didnt misunderstand me tho, since he was the one who told me to do the pressure test.
This is straight from Chris
"Sorry for not getting back to you yesterday, you will actually want to leave all of the spigots installed on the inlet hose when you do the pressure test. Taking them off will mask problems with the stock inlet hose if there is a leak there. Just leave everything the way it is, put the plug at the end of the inlet hose, and pressurize the system. "
And I replied what about the lines popping off and what about capping the PCV valve and this was his response,
"They should stay on if they have a good connection. If they pop off, then they're need a better connection. The PCV doesn't need to be capped off either. 20 psi isn't enough to cause any damage. We've done this on a lot of cars in the past."
Old 12-06-2011, 09:32 PM   #24
Shef
Member#: 283310
2004 Forester XT E85
2014 Forester 2.0XT SWP
EIDT: Nevermind, misunderstood "Boost leak" to mean only testing the pressurized side of the intake tract ignore below text becuase I'm stupid.
Pretty sure if you're running lean you don't have a boost leak. A boost leak will cause you to run rich. A boost leak means air that has been metered by the MAF is leaking out, therefore the ecu is putting in the fuel required for the all the metered air, yet some of the metered air is leaking, hence too much fuel for the actual am ount of air thats getting into the motor. Rich = slower but *somewhat* safe.
On the other hand a leak between your MAF and turbo inlet will cause you to run lean but this section of tract is under vaccum. In this case you're sucking in air in addition to what was metered so the ecu is not adding any fuel to compensate for the additional air hence you will run lean = dangerous.
Check all the connections between your MAF and inlet, stock inlet ends tend to rip if you've taken the turbo out/replaced it. Mine did, as did my friends during turbo swaps.
Shef is offline   Reply With Quote
Old 12-06-2011, 09:40 PM   #25
DreksSTI
Member#: 287573
2007 WRX STI
CGM
I meant a Vac/boost leak. Wasnt sure which it might be. And I am hoping that its somewhere on the inlet. Thanks for your input. All good man.
Anyone in SD know how to do boost leak test? somaguchi Southern California Impreza Club Forum -- SCIC 2 01-25-2010 03:29 PM
Does anyone actually watch the IndyCar series? meebs Motorsports 10 05-15-2005 10:34 PM
Does anyone here know the answer to this CEL FIX resistor question?(LINK) Rick G Tri-State Area Forum 1 09-25-2002 10:21 AM
Does anyone actually have the MRT header back exhaust? Robmat Normally Aspirated Powertrain 15 05-04-2001 10:35 AM
