Old 08-09-2002, 10:12 PM   #1
pio!pio!
Member#: 4190
2008 Impreza WRX STi
Default Are all lug nuts the same size?
Across different makes and models, are all lug nuts the same size?
pio!pio! is offline   Reply With Quote
Old 08-09-2002, 10:28 PM   #2
CDTOYS
Member#: 8549
2002 WRX Wagon
No they are not.
Although most Japanese and U.S. built cars use lug nuts, the thread size and head size of the lugs can be different. Many cars from Europe use lug bolts and they also vary in thread size and the head size. The seat of the lug nuts or bolts can also vary. The most common style seat is a 60 degree taper, however there are several other types (flat seat or radius seat) used by different manufacturers.
Always be careful to use the proper type of lug hardware for the type of wheel and car that they are being installed on.
CDTOYS is offline   Reply With Quote
Old 08-09-2002, 10:29 PM   #3
Gonz
Member#: 18642
2005 Impreza WRX STi
ummmmmm........... NO.
some common sizes are 17mm, 19mm, 22mm, 13/16", 3/4"
there all also different thread pitches and different diameters of the wheels studs such as 3/8" or 1/2" etc.
GP
Gonz is offline   Reply With Quote
Are 05 STi AXLES the same size as Late 04 STi? MattD87 Transmission (AT/MT) & Driveline 1 06-04-2009 06:22 PM
Are all Impreza OEM lug nuts the same? MF-DIF Tire & Wheel 2 02-16-2009 06:18 PM
Are all sway bars the same? Antonios Kintos Brakes, Steering & Suspension 13 02-23-2005 12:42 PM
Are all grounding cables the same? V6 Normally Aspirated Powertrain 2 09-09-2002 08:14 PM
Are all uppipes really the same? GDB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-29-2002 12:05 PM
