Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 12-05-2011, 07:09 AM   #1
silvercookie
Member Sales Rating: (63)
Member#: 180033
2005 WRX
Default Silvercookie's garage/garage attic sale.
Got way to much stuff. Bought stuff and forgot i had other stuff. Need to sell it all.
I have pics of everything just post or pm me what you want and i can send you a pic of it. too many pics to post.
Tires/Wheels
Set of RE92's. Have MAYBE 1k miles on them.
Tire size is 215/45/17. 500 obo for the set. sold
Set of Yokohama AVS Winter tires 225/55/17. 2 have a little camber wear and the other 2 are good. about 70% life left. 300 obo for the set. sold
I have 2 Prodrive P1 18's by O.Z. Racing. i believe they are 18x8 or 18x8.5. Not sure of the offset but it looks fairly higher. Definitely above +46. They are pretty beat up. would make good spares or to replace a bent rim in your set. 150 obo per rim. not seperating tires. they are kumhos. still have decent life left. sold
I have one EDM wrx 17" rim. it is 17x7 iirc and offset should be usual +52 or +53.
Has a decent bend in it but could be fixed. other then that it is mint. Perfect to use as a full size spare if repaired. asking 100 obo.
Intake/engine bay/misc pars.
Wiper fluid bottle from a impreza wagon. Includes both pumps. 30 obo.
Gates and FHI accessory belts. Im pretty sure theFHI is the A/c and the Gates is the alternator etc. 15 each.
2 Stock WRX air boxes - 30 each obo. 1 gone
Stock alternator cover - 15 obo - broken
Stock fusebox cover - 10 obo - used
DIY snorkus CAI - offer.
Stock intake box scoops - 20 obo each.
OEM afta maf hose - 25 obo. - sold
Stock 02-05 wrx TMIC includes all hoses. 70 obo
Stock coolant overflow. - 15 obo
Perrin big MAF tube. - 75 obo.
Some EBCS. not sure what it is from but it is brand new. 50 obo.
A single APS tgv delete. includes motor, sensor, etc etc. - 100 obo.
Brand new knock sensor. - 45 obo
And i have 2 intercooler pipes. 1 has a tial 50 v-band flange welded on. and the other one not sure where it goes. 50 obo for the one with the flange and 30 obo for the other.
Exhaust Parts
I have 2 sets of Bugeye Headers. Asking 35 each. - both sets sold.
Have a OEM wrx up-pipe from 02-05 wrx. not sure on miles but it is in pretty good condition. asking 40. no sensor.
A OEM 04 wrx midpipe. still hast the resonator on it. its 2.75 or 2.5" not sure whatever the stock is. asking 25.
And last i have a OEM 05 WRX axel back. it still has half of the oem mid pipe on it because i cut off
the resonator because i was going to weld in a straight pipe but that didnt happen. I have a 05 limited
so im not sure if the Axel back is different. Tip has some scratches from being moved around. Open to offers. not sure if i want to sell it or not.
Body Parts
PSM Bugeye grill end piece things. The fronts are 100% mint but the sides are a bit weathered. - 50 obo
Bugeye bumper beam - offer. - sold
Front bumper beam from a 04-05. looks like it was cut for a fmic. - offer.
Passenger side CGM sti foglight cover a few scratches here and there but otherwise good condtion. - 40
GTspec S203 carbon replica. Its meant for peanut's but can obviously be used on any year.
It does have a small crack but some black paint and a steady hand will make it look good as new.
it doesn't use the stock wrx mounting holes so new holes will have to be drilled. Perfect if you have a carbon
or wingless trunk. comes with brackets obviously. asking 275 obo. they were ~500 new from gtspec. - sold
MRT Performance 22b replica wing. fits all GD trunks. uses stock mounting location + you can drill
2 holes in the center but i dont think its needed. The spoiler is fiberglass and definitely needs some work.
they were discontinued a while back so they are hard to find but im letting it go for cheap. 100 obo <------
Interior Parts
Stock mirror. - 15 obo
Pair of Cloth mirrors/visors - 40 obo.
Stock cluster bezel. - 15 obo
Bugeye drivers door switches. - 20 obo.
Bugeye hvac/trim/vents. - 50obo for all of it. I also have the whole center piece and armrest piece etc for a bug eye. 60 obo for that. ill get pics if interest. 100 for the whole setup.
Stock clock pod - 20 obo - sold
Stock 02-04 wrx rear door cards. - 50 obo.
3 rear mats. 2 are oem and 1 is the all weather. 5 each.
Coinholder/ inside fuse cover - 10 obo.
silvercookie is offline   Reply With Quote
Old 12-05-2011, 11:41 PM   #2
silvercookie
Member#: 180033
2005 WRX
up for the night crew. need this stuff gone.
Old 12-06-2011, 07:51 AM   #3
LatentWagen
Member Sales Rating: (76)
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
I'll take the stock clock pod if it comes with a working clock.
LatentWagen is offline   Reply With Quote
Old 12-06-2011, 09:50 AM   #4
silvercookie
Member#: 180033
2005 WRX
Yes the clock works but it does have a tiny crack on the bottom left of the screen. it also has one of those non-slip grip pads on it but i can take it off.
Old 12-07-2011, 11:37 PM   #5
silvercookie
Member#: 180033
2005 WRX
up to the top.
Old 12-09-2011, 01:49 AM   #6
silvercookie
Member#: 180033
2005 WRX
bump yokohama's gone
Old 12-11-2011, 02:29 PM   #7
silvercookie
Member#: 180033
2005 WRX
bumpski.
Old 12-12-2011, 06:25 PM   #8
DevinMosca
Member Sales Rating: (4)
Member#: 244277
PM pics of bugeye bumper beam and the grill end pieces please
DevinMosca is offline   Reply With Quote
Old 12-12-2011, 07:55 PM   #9
silvercookie
Member#: 180033
2005 WRX
Pm'ed.
Old 12-12-2011, 09:13 PM   #10
cummlns
Member Sales Rating: (9)
Member#: 261222
WRX Wagon
PM sent.
cummlns is offline   Reply With Quote
Old 12-13-2011, 10:15 PM   #11
silvercookie
Member#: 180033
2005 WRX
Bump.
Old 12-15-2011, 03:46 PM   #12
silvercookie
Member#: 180033
2005 WRX
bump.
Old 12-20-2011, 01:33 AM   #13
silvercookie
Member#: 180033
2005 WRX
bump.
Old 12-21-2011, 02:16 PM   #14
silvercookie
Member#: 180033
2005 WRX
Got a speeding ticket today. Need this stuff gone asap.
Send offers on anything and everything.
Old 12-30-2011, 12:13 PM   #15
silvercookie
Member#: 180033
2005 WRX
bump.
Old 01-04-2012, 02:27 AM   #16
Skrane
Member#: 296352
Can you send a pic of the wheels
Skrane is offline   Reply With Quote
Old 01-04-2012, 11:44 AM   #17
silvercookie
Member#: 180033
2005 WRX
Which ones
Old 01-12-2012, 07:20 PM   #18
silvercookie
Member#: 180033
2005 WRX
bump.
Old 01-16-2012, 05:31 PM   #19
silvercookie
Member#: 180033
2005 WRX
bump.
Old 01-20-2012, 11:55 AM   #20
silvercookie
Member#: 180033
2005 WRX
bump.
Old 01-26-2012, 07:57 PM   #21
silvercookie
Member#: 180033
2005 WRX
bump.
Old 01-27-2012, 02:15 AM   #22
itwillboost
Member Sales Rating: (1)
Member#: 289693
2013 BRZ
Sterling Silver Met.
Pm me a price for the oem turbo parts.
itwillboost is offline   Reply With Quote
Old 01-31-2012, 03:29 PM   #23
silvercookie
Member#: 180033
2005 WRX
bump.
Old 02-03-2012, 05:23 PM   #24
silvercookie
Member#: 180033
2005 WRX
bump.
Old 02-04-2012, 06:45 AM   #25
Rallyboy5254
Member#: 308406
2002 WRX Wagon
Interested in the intake scoops. Where Are you located?
Rallyboy5254 is offline   Reply With Quote
REI Attic Sale zoltan Off-Topic 10 03-14-2016 12:11 PM
My garage clearing out sale Groove1797 Private 'For Sale' Classifieds 25 03-01-2004 12:08 AM
cleaning garage, tires for sale lndbrusr Bay Area Impreza Club Forum -- BAIC 0 05-08-2002 09:31 PM
Last Minute Garage/Parking Lot Sale @ KAMINARI MEET? clsmooth71 Southern California Impreza Club Forum -- SCIC 3 04-26-2002 03:36 PM
