Old 12-05-2011, 06:21 PM   #1
Kai_Viktor
Member#: 133301
Question 96 Legacy 2.2 swap to 2.5 DOHC
Looking into swapping my tried 2.2 Impreza motor out of the Legacy and replacing with a 2.5 DOHC. Donor car is 96 legacy outback.
1. Is it worth doing, meaning will the electrical plug and play?
2. Would I have to remove the 2.5 harness from the donor car?
3. Read about phase 1 and phase 2, what is that and would that
have a part in what I am trying to do?
4. Thanks for any advice or help.
JOHN
MN rallytime!
SidewaysMotorsports
Kai_Viktor is offline   Reply With Quote
Old 12-05-2011, 06:51 PM   #2
JoshP
Member#: 94350
Its plug and play. Use 2.5 complete, intake manifold w/ harness.
JoshP is offline   Reply With Quote
Old 12-06-2011, 12:55 PM   #3
RallyBlue
Member#: 69323
2004 WRX
82 BRAT
RallyBlue is offline   Reply With Quote
Old 12-12-2011, 07:25 PM   #4
Kai_Viktor
Member#: 133301
Thanks all. so far no hic-ups! 12 hour deal PEACE
Old 12-12-2011, 08:32 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Really? I thought you had to swap over the EJ22 harness onto the EJ25D manifold, maybe I should stop thinking...
I guess it wouldn't be hard to figure out, plug it in, if it runs and doesn't throw codes, good to go.
~Josh~
Old 12-12-2011, 09:48 PM   #6
WoodsWagon
Member#: 180769
lots of junkers
95-98 2.2's and 2.5l's are interchangable. You need the engine being swapped in to match the EGR status of the car. All 2.5's had EGR, only automatic trans 2.2's did.
96+ 2.2's had single port exhaust, so you need the Y-pipe to match.
Swapping a 95 auto 2.2l into a 96-98 2.5l outback with blown headgaskets is a very common bolt in plug in and go conversion. Blown headgaskets are a very common affliction of EJ25d's.
The intake manifold harnesses are the same. The ECU doesn't seem to care which engine it's running. It's MAF based so it just adjusts for the differing airflow.
If swapping into an auto trans car, use the flexplate that matches the transmission. 2.2l torque converters are smaller, so the flexplate has a deeper dish than the 2.5l one.
99 2.5l's were still DOHC ej25d's, but had the 8 bolt bellhousing. 4 bolt bellhousing motors will work but you will need to fix the missing lower starter bolt.
WoodsWagon is offline   Reply With Quote
99 2.5 sohc swap with 00'2.5 dohc AlaskanProtege Normally Aspirated Powertrain 5 10-31-2010 04:18 PM
impreza 2.2 clutch swap to 2.5 clutch kit options oooo Transmission (AT/MT) & Driveline 1 10-02-2008 07:10 AM
2.5 DOHC swap to 2.2 SOHC compatibility? suby53 Normally Aspirated Powertrain 9 01-30-2008 06:28 PM
2.0 swap to 2.5 Assami Built Motor Discussion 1 01-05-2007 10:08 AM
?'s about best 2.0 swap to 2.5 slida Subaru Conversions 4 01-12-2005 03:01 AM
