#1 |
Member#: 284753
Vehicle:2004 WRX STI World Rally Blue |
So call me paranoid, but I like to see as much of the "parameters" of my engine as possible. I like to know if and when anything is out of the ordinary so that I can catch a potential problem before it becomes catastrophic. With that said, I currently have just the boost gauge, my aquamist meth flow gauge, and a useless innovate wideband gauge. But I would like to pick up an oil temp and oil pressure gauge at the very least in the near future. At that point I will have a total of 5 gauges. Right now my boost and aquamist gauges are in the instrument cluster dual pod and the wideband is just loose for now because I can't think of what I want to do. I'm not a huge fan of the instrument cluster pod.. I don't like the fitment of it, and I don't like how it sits.
On to the next part of this. As dumb as it sounds, I'm constantly using my center clock (the clock on my radio is tiny and I hate searching for it when I want to know the time. So I really don't want to go with a gauge cluster either. And my last prefabricated option is an a-pillar pod... which I can't stand either because you'll never find one that is a perfect match (color and texture) to the factory. So that leaves me with only one option... custom pod. Here is where it gets interesting and where i need your opinions. I layed it out with just the wideband and it seems like it will be a perfect fit. With my current steering wheel setup, which is how I keep it all the time, the top of the steering wheel matches the curve of the dash above the cluster perfectly and is eye-line to the top of the dash. So I was thinking of doing a custom pod to hold however many gauges I chose along that top curve of the dash. With the quick fit-up I did with the single gauge it seems like the custom pod would cover up just enough of the view that the stock scoop does already... so there would be no loss of vision out the windshield. Another plus side to it would be that everything would be front and center and there wouldn't be any need to change my sight direction from directly in front of me. Which seems like it is a perfect setup. So what are your opinions??? 1) are having gauges rice??? I personally think they are useful and worth it, especially on a modified vehicle, but some people may not agree... 2) What are your thoughts on the custom pod idea and if anyone has something similar pictures would be great so I can possibly visualize it further than just setting a single gauge up there. Thanks and sorry for the long post... lol
#2 |
Member#: 184554
SCIC
Vehicle:02 ghettoFABness bugeye rolling. |
#3 |
Member#: 261764
Vehicle:2003 Impreza WRX Blue |
I wouldn't be so worried about not being able to see over them i'd be more worried about the amount of light they would be producing at night, blinding you from seeing the road.
#4 |
Member#: 141373
E. Canada
Vehicle:2008 2.5i-hatch - now with a HID retrofit |
What car do you have? Fill in your profile
![]() Also, quite a few gauges can be replaced by an OBDII gauge tool. Keep this in mind as well, but a new mounting idea/setup is always welcome. |
#5 | ||
Member#: 284753
![]() I've really thought about the OBDII gauge tools... especially since the price of one would come out to be about the same as getting some decent higher end gauges. But mounting that would prove to be another issue... and I would like to find one that would show multiple displays since when driving, you don't really want to be fumbling around with buttons to check through everything. A little more background on myself and the car, it is fully set up for autocrossing but at the moment it is mostly just a DD that I have some fun with once in a while. I would eventually like to get into autocrossing, but not until I have a 2nd mode of transportation besides my bike (just in case something were to go wrong). But even for daily driving I like to keep an eye on the aspects of my engine. Especially being an almost completely stock block (only a mild tune so its not a ton of stress on it, but still its enough) |
#6 | |
Member#: 284753
#7 |
Member#: 270910
South East
Vehicle:2006 WRX Tr WRB |
This may be way off base but I'm trying to think outside of the box. What if you deleted the LH sunvisor and made an overhead style pod? All the way to the glass and slightly slanted downward type of thing... just a thought.
My main concern with your idea is simply the light output. My clockpod's pretty bright. Granted I have green gauges that emit tons of light. |
#8 |
Member#: 141373
E. Canada
the clock pod is IDEAL for a scangauge II. Yes you give up the clock... but you end up with a constant display of 4 OBD parameters. Consider it...
#9 |
Member#: 284753
I don't mind if I give up the clock as long as I can put an analog 52mm clock somewhere visible (or a digital 52mm clock but I have yet to find one). I'll have to look into that scangauge.
#10 |
Member#: 284753
looking at that scangauge, what type of system do the Subarus have?? trying to figure out exactly what parameters I'll have with the scangauge. I have an OBDLink right now that I can watch on my laptop, but thats not ideal for normal driving.
#11 |
Member#: 303138
yup, that's not too good for normal driving.
#12 |
Member#: 261764
How many gauges are you looking to have? You could always do the center dash pod that replaces the clock then by a 52mm clock and put it where the left side air vent is. I've seen this done before, if done right it looks extremely clean and is well within vision.
Like this |
#13 |
Member#: 284753
If I add up what I have now and what I want to add I'll have at least 5 (plus the 52mm clock) which is more than the center pod can hold. I would like to stick away from the vents also. My ideal would be to keep them all together for nice easy viewing and prevent having to keep turning my head in multiple directions.
#14 |
Member#: 284753
I may try to find a banged up dash that was in a wreck or something and is no good so I can try out some different ideas. Anyone know of anything... trying to keep it as cheap as possible.
#15 |
Member#: 302674
Damn that looks awesome with all those gauges like a cockpit on a plane...Love it
#16 |
Member#: 286115
Vehicle:2003 WRX - sold PSM |
#17 |
Member#: 284753
yea, but from what I've found, they only have it in blue and amber. I'd like to keep everything red if I can.... even though my aquamist isn't red either.... lol.
I am picking up a broken dash that I can help use as a template / practice piece and I will hopefully start getting to work on the pod in the near future. I'll make sure to take lots of pics and try to keep you all updated on the progress. I'm really hoping this turns out well. The only thing that I will have to take into account is the possibility of glare, so I may need to creat some sort of small "hood" over the gauges. Not really sure though since they will be fairly far forward... Edit: The close I look at the picture... the amber may actually be pretty damn close to the red I have now. I'll keep it in mind. |
#18 |
Member#: 103068
SCIC
Vehicle:11 STI sedan SWP |
I had the same dilemma, I decided on HKS Camp2 to keep things clean.
#19 |
Member#: 284753
As nice as that is, its way over my budget, and it still doesn't fix the issue of abnormal viewing.
#20 |
Member#: 103068
SCIC
Ah, just noticed you have an 04. It was a little low for me in my 06 as well.
I think you could buy something like the Greddy Informeter and custom it into a Subaru clock gauge pod. |
#21 |
Member#: 303250
do ittttt
#22 |
Member#: 229527
Vehicle:2009 Subaru WRX WR Blue |
what about the a- pillar one, but then just paint both sides black or a similar color to what it is now that would look ok. not sure if it would look great but then they would match.
#23 |
Member#: 284753
The A-Pillar would be my other option as it is the next best visual location. But I think I'm going to give this a go first and see how it comes out. I'm really hoping it comes out as nice as I picture it. lol
#24 |
Member#: 245106
Vehicle:2004 WRX Wagon San Remo |
would a scan-gauge work for you? its fairly small and can display multiple data sets.
http://www.scangauge.com/products/scangaugeii/ |
#25 |
Member#: 301093
Vehicle:2006 Wrx Blue |
You can look into the ashtray delete cluster. Just did mine tonight..fits 2 52mm gauges and the cigarette lighter perfectly
| Thread Tools | |
| Display Modes | |
| White face gauge, yay or nay? | illegal2.2 | Legacy Forum | 13 | 01-08-2008 10:21 AM |
| Group N tops with SPT pinks or Prodrives... yay or nay? | Davemeister | Brakes, Steering & Suspension | 2 | 08-12-2005 10:07 AM |
| Ok, guys, yay or nay this wedding idea (need man opinions.) | Sharkbait | Off-Topic | 57 | 07-31-2005 02:09 AM |
| An idea. yay or nay. IBpoll | rites | Off-Topic | 7 | 06-22-2005 01:15 PM |
| Autometer Boost Gauge. Yay or Nay? | wrX-RTD | Electrical & Lighting | 9 | 04-15-2005 11:10 PM |
