Old 12-06-2011, 11:12 AM   #1
JazzyJake
Member#: 153476
2005 VF39 6spd FXT
Default New swap, no starter or fuel pump cycling
Hey folks,
My fuel pump and start are not cycling/engaging on my swap.
Everything else appears to work, stereo, lighting, (inside and out,) cluster, etc.
However, when i put the key in start, my fuel pump does not cycle, and my starter does not engage.
04 WRX Wagon, with the WRX body harness, 04 STi EJ257, VF39, and such up front, with the accompanying 04 STi harness.
Any thoughts on this one?
Thanks!
Jake
JazzyJake is offline   Reply With Quote
Old 12-06-2011, 01:03 PM   #2
RallyBlue
Member#: 69323
2004 WRX
82 BRAT
I remember something like this when doing a clutch job for a friend. Turns out he used the wrong bolt when bolting up the trans. The 2 longer bolts of the 6 trans bolts go on the top most holes. One is the top starter bolt and has the ground attached to it. He used a smaller bolt and his car wouldn't start. Once the correct bolt was swapped no more problem.
RallyBlue is offline   Reply With Quote
Old 12-06-2011, 08:01 PM   #3
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Yea check all them grounds, those DBW models are picky!
sense of nature is offline   Reply With Quote
2.0-2.5 swap problems, STARTER & FUEL INJECTOR STUCK ON??? aarongivey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-31-2010 02:16 AM
Flashing CEL on Key ON, fans and fuel pump cycles (before starting) Geek Guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-12-2009 04:35 PM
WRX Starter and Fuel Pump simpreza2 Tri-State Area Private Classifieds 2 09-18-2008 07:19 PM
Fuel pump cycles when car is off? tekgnosis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-15-2007 09:08 PM
EJ22 Swap - No Spark... no ground for fuel pump relay?? Subarutex Subaru Conversions 5 01-22-2007 12:14 PM
