Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 12-06-2011, 04:39 PM   #1
luka
Member#: 194742
1993 Impreza WRX JDM
Default What USDM Springs/Struts Will Fit a JDM '94 GC8?
I've searched the net for a bit and it looks like '99 and older GC8 is the only thing that fits? the wagon's seem to have different bolt locations and anything newer different top hat? if anyone can verify or let me know what will fit my car I'd greatly appreciate it.
Thanks again,
-Luka
luka is offline   Reply With Quote
Old 12-06-2011, 07:59 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
93-01 Impreza fits. 02 + stuff will sit too high, the rear tophats are different and the camber will be off.
Old 12-07-2011, 09:39 AM   #3
luka
Member#: 194742
Thanks duder, what about just the springs? since I have an issue with ride height I'm assuming that's a blown spring not strut. so if I could save a few bucks just getting springs that would be awesome.
Old 12-07-2011, 09:47 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
93-01 impreza springs will fit. You can use 02-03 GD impreza springs but it will sit higher.
Old 12-07-2011, 11:13 AM   #5
luka
Member#: 194742
Thanks again I appreciate the quick response. I've got a blown spring and really want to get my suspension/alignment ready for the winter... snows already started falling :S
Old 12-08-2011, 12:50 PM   #6
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
This is as much an answer as a question but wouldnt just about any spring/struts/coilovers for a 2.5RS fit? Isnt it the same gc8-gf8 chassis?
TommyAtomic is offline   Reply With Quote
Old 12-08-2011, 01:16 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes..
Old 12-08-2011, 02:54 PM   #8
luka
Member#: 194742
according to these guys the GF8 stuff is different... or am I reading it wrong? http://forums.nasioc.com/forums/showthread.php?t=857305
Old 12-08-2011, 03:04 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
You're reading it wrong.
GD stuff will throw the camber off on a GC. The GD track width is wider.
GF, GC and GG (02-07 wagon) have the same track width.
GF rear springs are a bit stronger than GC for the extra weight, but not much.
Old 12-08-2011, 03:04 PM   #10
luka
Member#: 194742
here's a solid thread about getting GD onto GC, doesn't seem like it's worth the trouble.
http://forums.nasioc.com/forums/show....php?t=1145898
Old 01-18-2012, 04:01 PM   #11
pur3lusion
Member#: 147504
2007 Impreza WRX STI
I just wanted to add and ask to this i have a 93 impreza.. I was just given a set
Off 02 oem struts m springs.. As off right now the rims off set i got is +40 and my tire size is 50 im rubbing like hell.. But thats all i got right now.. Since you said it will sit high will it clear my rims n tires then
pur3lusion is offline   Reply With Quote
Old 01-18-2012, 09:32 PM   #12
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
So, this thread and the linked one are kind of jumpy. but here's what I've taken from it
02 spring on a GC fit, but are too tall
02 struts on a GC fit, but change camber (corrected with camber bolts or GC top hats)
04+ will not fit unless modified
Is that right
we will need more info than that. What are the rest of your tire dimensions and how wide are your "rims" (wheels around here). Also, are you lowered any?
Millhouse_5 is offline   Reply With Quote
Old 01-19-2012, 07:18 AM   #13
pur3lusion
Member#: 147504
As off right now they are 215/50r17 +40 and nah im not lowered at all
Old 01-19-2012, 10:34 AM   #14
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Well your tires are a little taller than stock so this is not helping your rubbing situation. And I'm going to guess you have either a 7 or 7.5 inch wheel as you still didn't state what it was. That size tire on that low ish offset wheel you will likely need a fender roll so your tires clear the fender.
Ideally you should be running a proper sized tire with a more appropriate offset. Something like a 205/50/17 instead of your current 215/50/17. This new size will be shorter and skinnier likely eliminating the rub. You should look up a bit on tire sizes as you seem to be a little new at it.
So, I'd advise a fender roll before you start lifting up your car. A roll just moves the inside of the fender away so you have more clearance for your tires.
Edit: agree with below, but its still alive, so why not
Old 01-19-2012, 11:53 AM   #15
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
Not to rain on the party, but doesn't this thread belong in the Suspension forum, not pre-2002 turbo powertrain?
gpshumway is offline   Reply With Quote
Old 01-19-2012, 01:11 PM   #16
pur3lusion
Member#: 147504
Well i understand about my offset i got my fender rolled already!! When someone suggested on another forum got it done yesterday... Now the question still once i installed the 02 struts n spring as you guys stated it will ride high!!! Will my wheels be fine since i got fender rolled! I didnt start the topic just happend to be here n i had a few xtra questions about it
Old 01-19-2012, 03:04 PM   #17
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Here are two links that will help you. Read the first posts in each, and you should get all the info you need about making springs and struts from various subaru cars work on your car. As for ride height and strut mounting bolt patterns, that's addressed in those links too.
http://bbs.legacycentral.org/viewtopic.php?t=2153
http://bbs.legacycentral.org/viewtopic.php?t=22419
Dominator is offline   Reply With Quote
WTB: Struts/Springs that will fit 01 Legacy Outback lord1234 NESIC Private Classifieds 8 08-26-2009 05:13 PM
What year of STI strut and spring combo will fit in a 2002 WRX Wagon LIGHTspd Brakes, Steering & Suspension 2 02-25-2009 02:08 PM
WTB: Any lowering springs that will fit a 01 GC8 Idahoreza Private 'Wanted' Classifieds 1 04-17-2007 10:17 PM
what HID kit will fit 02 JDM headlights wrxburton Electrical & Lighting 12 01-11-2007 01:07 AM
springs/struts 04 fit gc8? Dfish Brakes, Steering & Suspension 2 06-19-2005 11:43 PM
