Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 12-06-2011, 10:02 PM   #1
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Rspc block, GT30, 272s
Default Four's 2006 Wingless CGM STI
I have spent the majority of my time on my local board and on IWSTI for my build. Purchased the car in February of 2006 and it has been my money pit ever since.
I thought I might start a journal here as well as few had suggested to me on IWSTI.
If you really want to read the story from the beginning, I suggest you start here: http://www.iwsti.com/forums/gd-membe...y-rolling.html
Stock, stock, stock
The car has gone through many stages and changes. Rather than post the explicit details of every stage I decided to just list them.
Stage 2 - OTS Cobb with Cobb TBE
Protune - Cobb TBE, Maddad header, APS CAI - road tuned no numbers
Failed Maddad header, switched to Grimmspeed PnP header setup
Coolingmist meth kit - 280whp/319ftlbs **link
Big turbo build - ATP3076, APS DR525, all supporting w/Coolingmist - 346whp/319ftlbs **link
Failed coolingmist kit - Stock motor/piston #4 goes boom!
..Then the rebuild started from the bottom up
I started with a Rallispec Street block, Innovative Tuning in Buffalo built the heads with Kelford 272 cams. Most of the power mods remained the same with some small changes. I ditched the meth kit after having issues with it from day 1 of the install and decided to set a goal to make similar power or exceed the previous power on just 93oct.
I decided to have the car tuned at EFI logics this time around. however, the IWG of the ATP3076 was sticking and not performing like I wanted. This set up is pre-EFI logics Turbo and EWG build and retune. Note that this is also a Mustang dyno as the last tuner, however it reads a bit higher than my previous shop. Resulted in 388whp/323whp **link
..on to the current stage of the car
fourseasonsandles is offline   Reply With Quote
Old 12-06-2011, 10:02 PM   #2
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
The Current setup
2006 SUBARU STI / CRYSTAL GRAY METALLIC / SILVER BBS
FACTORY OPTIONS:
* STI "shorter" short shifter
* Upgraded security system
* Wheel locks
* STi blue factory floor mats
Interior
*07 Limited 3rd brake light
*07 Limited Red Hazard Button
*Forester Din Pocket
*Evo IX MR Recaros
*Wedge Engineering custom seat brackets
*Black 2005 WRX rear seat
*AEM UEGO wideband
*AEM Boost Gauge
*Autometer Dual Gauge Pillar Pod
*2007 STI Limited Door Cards
*Blacked out Pillars
*Blacked out headliner
*Blacked out visors
*Black STI floor mats
*Black WRX carpet
*10th St JDM/JPM Coachworks Alcantera Shift Boot and E-brake boot
*Autospeed aluminum dead pedal
*Sony CDX-MP80 CD/Mp3 Player
*iPod video 30g/iPhone 4 16g
*Infinity Reference 6012si 6.5" Speakers - Front Doors
*Polk Audio DXi400 4" Coaxial Speakers - Rear Doors
*Bazooka BTA8100 BT Series 8-Inch 100-Watt Sub
Exterior
*50% Tint
*DRL delete
*APR carbon fiber lip
*Pass side fog light bezel inlet
*Custom front license plate mount and cover
*Fog light cover de-badge
*Grillcraft upper and lower grills
*2008 GR STI front and rear badge
*Wingless trunk de-badged
*Blue Batmobile side marker overlays
*Subtle Solutions license plate delete
*Litespeed rear bumper beam
*Dzus latches for the front bumper
Driveline
*Kartboy short shifter
*TiC shift linkage bushings
*Kartboy rear stay bushing
*Kartboy front stay bushing
*Motul Gear300 75w90 in the trans
*Motul 90PA LSD in the rear diff
*ACT XTSS clutch
*2005 STI modified slave cylinder
*Clutch delay valve delete
*Stainless steel braided clutch line
*ATE Super Blue
*18x8.5 Gramlights 57 Maximums
*Falken Azenis 615K 225/40 18"
*McGard chrome/blue tip lugs
Suspension/Brakes
*Tanabe GF210 springs
*Whiteline STi 24mm adj. front swaybar set to 26mm
*Whiteline STi 24mm adj. rear swaybar set to 24mm
*Kartboy rear end links
*Kartboy front end Links
*Perrin subframe lockdown kit
*Hawk HPS pads
Engine
*Cobb APv2 - EFI logics Tuned 392whp/345ftlbs
*Rallispec street series shortblock 704 casting - 7600rpm redline
-Manley 4340 steel H-beam rods
-Cosworth forged pistons
-ACL rod bearings
-Factory nitrided crankshaft
*2008 11mm oil pump
*Innovative Tuning beefed up oil pickup
*Gates kevlar reinforced timing belt
*NGK 1 step colder Iridium plugs
*Cobb lightweight crank pulley
*Deatschwerks 850cc injectors
*Walbro 255 fuel pump
*Heads built and machined by Innovative Tuning
*Kelford 272 R-199-C Camshaft 272/268
*Ferrea endurance spec dual valve springs
*Ferrea titanium retainers
*Ferrea valve spring seat locators
*ARP head studs
*ATP3076r EWG turbo
*Tial 44mm EWG routed back into the DP
*APS DR525 FMIC
*APS hard inlet
*Grimmspeed A/O separator
*KSTech 73mm MAF CAI
*KSTech weldless TGV Kit
*PTP T3 turbo blanket
*Thermotech Heat wrap on DP and UP
*Ported stock header elbows
*Perrin up pipe
*Cobb catless TBE Full 3" - 2.5" section removed
*Kartboy exhaust hangers
*Hallman MBC
*Gimmick upper/lower radiator hose
*Odyssey PC680 small battery kit
*Innovative Tuning radiator shroud
*Subtle Solutions alternator cover
*Paranoid Fabrications 02-07 Impreza dress up kit
Weight Reduction
*U-brace w/ plastic trim -25.0 lbs
*Middle rear seat belt -5.0 lbs
*COBB downpipe w/ O2 sensor -11.5 lbs (11.75 vs. 23.25)
*COBB cat back -2.0 lbs (19.0 vs 21.0)
*COBB midpipe -2.0 lbs (9.0 vs 11.0)
*COBB crank pulley -4.5 lbs (1.25 vs 5.75)
*Spare tire -30.25 lbs
*Spare tire bolt and cap -0.25 lbs
*Jack extension handle located under spare tire cover -0.75 lbs
*Jack -4.0 lbs
*Tools w/ carry case -1.5 lbs
*Spoiler -17.0 lbs
*LH and RH "packing" plates under rear seat -3 lbs
*Guard pipe complete-rear floor under rear seat -7lbs
**18x8.5 Gramlights 57 Maximums +8 lbs for all 4 over stock BBS
*Falken Azenis 615 225/40 18" -12 lbs for all over over stock RE070s
**APS DR525 after removing front bumper beam, TMIC etc +27.25 lbs
*Hood liner -1.0 lb
*Front grab handles -1.0 lbs (0.5 x 2)
*Rear grab handles -1.0 lbs (0.5 x 2)
*Child seat anchors (all 3) -2.0 lbs
*under dash metal bracket -1lb
*TMIC Air splitter -1lb
*Evo 8 Recaro Driver front seat (reclinable) -8.22 lbs (32.78.0 + 6.0 (bracket) vs 47.0)
*Evo 8 Recaro Passenger front seat (reclinable) -3.22 lbs (32.78 + 6.0 (bracket) vs 42.0)
*Sony Xplod CDX-MP80 Radio -2.5lbs (3.5lbs vs 6lbs stock radio)
*Odyssey PC680 Small battery kit -16.6 lbs (15.4 vs 32.0)
*Rear bumper beam replaced with Litespeed bumper beam -22.25 lbs (6.25 vs 28.5)
Total Approx = 148.79lbs
Future plans
*UEL Litespeed header - Ordered/Delivered
*Grimmspeed solenoid - Ordered/Delivered
*EFI retune - scheduled for April 20
*Powder coated IC pipes and manifold
Old 12-06-2011, 10:02 PM   #3
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Some other notable changes. Pictures do a better job explaining:
Evo 8 Recaros
Always hated the blue, so I decided to upgrade to Evo 9 Recaros and some other interior work
Old 12-06-2011, 10:03 PM   #4
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Stage 2 and meth before the tear down
Big turbo build time
Ran for a month on this setup
After the kaboom!
Swapped the IWG for an EWG and ditched the Cobb taper in the DP/catback
Rebuilt!
Old 12-06-2011, 10:04 PM   #5
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Current upgrade plans
I received my litespeed header. Looking forward to my attempt to break 400whp and pick up some more torque. Other changes will be a Grimmspeed EBCS to replace my MBC and a retune by EFI logics.
I will update more as time goes on. Since building the engine and purchasing a house, my mod plans have slowed as I have been enjoying the car more than wrenching on it. Not to mention the mortgage takes away from the fun a bit.
Thanks for looking!
Old 12-06-2011, 11:00 PM   #6
PD5015
Member#: 198372
2006 WRX TR VF43
WRB Camo
Nice build!
PD5015 is offline   Reply With Quote
Old 12-07-2011, 09:18 AM   #7
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Where she sits for now
Pic in Oct before I put it away for winter
Old 12-10-2011, 09:31 PM   #8
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Grimmspeed EBCS came in yesterday. Thanks to Import Image for having a sale and free shipping.. woot!
Last on the list for the tune this spring is getting the header coated and new gaskets. Also have to set an appointment for EFI.
Old 12-13-2011, 12:49 PM   #9
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Appointment set at EFI for a retune April 20th!
Yes I scheduled it super early because I have a lot on my plate now and getting things done as they come.
Old 12-13-2011, 04:29 PM   #10
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Originally Posted by fourseasonsandles View Post
You might find it hard to reach your power goals with that large cat on the exhaust manifold...
jigga is offline   Reply With Quote
Old 12-13-2011, 04:34 PM   #11
DjMuzz
Member#: 179990
'06 STi - WRB
'03 Ninja 636
^^^ hahahaha
Car is really coming along man, good work!
DjMuzz is offline   Reply With Quote
Old 12-13-2011, 05:09 PM   #12
altima04
Member#: 104134
2006 STI
dude i am diggin that beautiful interior man! Where u get that shift boot suede wit red stiching?!
altima04 is offline   Reply With Quote
Old 12-13-2011, 07:21 PM   #13
B03scooby
Member#: 102929
200_ 07STi,03,07 STi
SWP/ WRB/UGM#239
looks good, I think I need to get some evo 9 recaros
B03scooby is offline   Reply With Quote
Old 12-13-2011, 10:25 PM   #14
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Was only temporary!
Originally Posted by DjMuzz View Post
^^^ hahahaha
Thank you!
They do some quality work! Ask for Alex!
http://www.jpmcoachworks.com/jpm/
I want to get my visors done, but other things take priority right now
I love them! I am 6'2" 225 right now and they fit me perfect. Fit well when I was a bit heavier as well. I stuck with the Evo Recaros because I knew I already liked them from the first set I had. HUGE difference between them and the stock seats. Also good on a budget!
Old 12-29-2011, 10:41 PM   #15
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Got my gaskets for the header today. For free! Well, in trade anyway. But trade for parts that I dont need or use anymore, so in my book.. that is free!
Old 02-03-2012, 05:24 PM   #16
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Just dropped my Litespeed header off here:
Pick it up in about 3 weeks. Tear down of the car will probably start in March sometime when it gets a bit warmer.
Old 02-11-2012, 01:39 PM   #17
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
I own this b*tch outright! Just made my last payment
Old 02-11-2012, 03:23 PM   #18
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
^ Congrats!! I paid mine off in October!
I had until May tho.
96accord is offline   Reply With Quote
Old 02-22-2012, 10:02 PM   #19
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Picked up my header from Swaintech today. Coating looks and feels awesome. I put some Never seize on the slip joint and put it back together. Installed the EGT plug as well.
No coating, for comparison
Probably wont start install just yet, but soon. Im excited to get out to EFI Logics in a couple months!
Old 02-23-2012, 12:41 AM   #20
r12rex
Member#: 77894
2006 WRX STi
OBP 301WHP & 358FT/LB
Awesome build...how loud is the ewg being dumped back into the DP? I've always wanted to go EWG, but I wouldn't be able to stand the noise...your dyno videos make it seem no louder than it would be with an exhaust.
Kind Regards,
Ryan
BTW can't believe you still have those 57Maximums! I don't know if you remember, but you commented my thread a long time ago when I sold mine. :P
r12rex is offline   Reply With Quote
Old 02-23-2012, 09:03 AM   #21
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
Yep, still have them. I think the only way I'd ditch them is if I pick up a set of TE37s.
The EWG isn't any louder than an IWG the way I have it routed. Which is exactly what I wanted.
Old 02-23-2012, 09:21 AM   #22
csugden
Member#: 154959
04 JDM STI
Have you noticed any handling problems with this removed, or did you install some other lighter brace ?
csugden is offline   Reply With Quote
Old 02-23-2012, 10:13 AM   #23
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
No handling changes, but I dont track my car or do autoX. I did some research on here and IWSTI. There is a member on IWSTI that tracks there car on a regular basis and stated he notice no different using stock, no brace or a lighter brace.
Per the things I have read, it is only there to cradle the engine in case of an accident. It serves no structural purpose. Also, the JDM versions do not have this brace.
I have no info to absolutely confirm this info, but I am not having any issues without the brace.
Old 02-23-2012, 10:43 AM   #24
freefree84
Member#: 311255
this whip is SICK.
freefree84 is offline   Reply With Quote
Old 02-23-2012, 11:15 AM   #25
CatfaceType-R
Member#: 81102
Looking good man
Carmi
CatfaceType-R is online now   Reply With Quote
my 2006 wingless CGM trunk for YOUR 2006 STI CGM Trunk! deezy1987 SCIC Private Classifieds 12 10-16-2008 04:22 PM
WTT: 2006 CGM STi Wing/Trunk for Wingless Jbwrx06 Private 'Wanted' Classifieds 3 08-17-2008 09:39 AM
FS: 2006 Wingless OBP STI redheat86 RMIC Private Classifieds 5 11-04-2007 12:03 AM
Fs: 2006 wingless OBP STI $26500 (UT) redheat86 Private Vehicle 'For Sale' Classifieds 3 10-11-2007 12:53 AM
My cgm sti hood for your 2.5rs cgm hood, and my cgm sti wing for 2.5rs wingless NYC Sti_ck_IT Private 'Wanted' Classifieds 15 08-16-2007 11:42 PM
