Old 08-10-2002, 06:39 AM   #1
mild_se7en
Member#: 22688
97 Impreza L Coupe
2.2T
Default idle air control valve, after a turbo mod
i am currently in the process of turbo charging my 97 ImprezaL. i am concerned of problems arising from the stock idle air control valve (IAC). how will the AIC operate after the manifold is pressurized? should i move the inlet hose to the pressurized piping, cap it, or remove the unit all together.
any input is welcome.
mild_se7en is offline   Reply With Quote
Old 08-10-2002, 07:45 AM   #2
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Pressure
You don't have to worry about it being pressurized. The IAC will go before the turbo and right after the MAF, so even under boost it doesn't see positive pressure. You cannot remove the IAC unless you go with a programable ECU since the ECU on an MY97 needs the IAC inorder for the car to idle. That being said the car will have idle problems that are worsened by the install of a lightened flywheel. The lighter the flywheel the harder it is for the IAC to control and recover the car's idle. A fuel computer will be able to lessen the problems if properly adjusted.
Joshua
yebokmj is offline   Reply With Quote
P0508 and the Idle Air Control Valve Chigliakus Service & Maintenance 11 01-30-2007 08:28 PM
Idle Air Control valve??? NavyRSt Normally Aspirated Powertrain 13 11-28-2006 06:37 AM
TX idle air control valve wanted styleandspeed Private 'Wanted' Classifieds 0 05-15-2004 01:16 PM
Idle air control valve circuit Hawk296 Service & Maintenance 20 03-08-2004 12:37 AM
WRX Idle/Air control valve djerickd Private 'Wanted' Classifieds 11 12-02-2003 11:37 AM
