Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 12-07-2011, 04:31 AM   #1
tad_07
Member#: 235873
Default AP1 Connection Issue/ Trying to revert to stock for AP2
I have an AP1 part#AE-STI-Port-04, Serial# 02004U0323. I bought my 04 STI that came with the AP1 that has already been custom tuned, but is now only on a stage 2, 93oct tune cobb ap1 tune. I can not connect to the ecu to put it back to stock so I can send the ap1 into cobb to get the discount on the ap2. I notice that the ap1 connector uses obd pins 1,3,8,12 & 15. According to the fsm, my cars harness & 04 sti harness I have for a swap car the pins are as follows: 1-Power, 3-Blank, 8- fsm says for "Line end signal 2" but it is Blank on both of my harness's, 12-Ground, 15-Blank
According to the fsm pin 10 is for the subaru ecu monitor with I have confirmed a good signal with my fluke. I have also used my fluke to check the power & grounds. I don't know why there are pins in the ap1 that are supposed to be blank in the obd connector??? I can't even read cel, boost or anything related to connecting to the ecu. I have never tried to connect the ap1 before but I have only had the car a couple of months and haven't really driven it but I'm ready to now after getting it the way I like it. Anyway to confirm if my ecu even has the tune from the ap1 on it?
tad_07 is offline   Reply With Quote
Old 12-07-2011, 11:09 AM   #2
Cobb Tuning
Member#: 4803
You're in luck! There's no need to uninstall the AP v1 in order to take advantage of our trade-in credit towards purchase of AP v2. We will take your AP v1 whether it is installed or not and even if it is not working. Also, the AP v2 will have no problems overwriting the old AP v1 install.
Here's the link to the AP v1 trade-in program details:
http://cobbtuning.com/info/?id=3846
Bill
Old 12-07-2011, 09:02 PM   #3
tad_07
Member#: 235873
Bill
I say that info. but curious if the ap2 is the same way (pins in the connector) or if it is a firmware (more or less) fix the the ap v2 has over the v1. I know the v1 aren't supported anymore & just trying to make sure I'm not going to have any issues with the v2
Old 12-08-2011, 11:45 AM   #4
Cobb Tuning
Member#: 4803
There's no reason that the AP v1 itself wouldn't connect to the ECU in question unless there's a problem with the unit itself or cable. An ECU with an Ecutek tune on it could prevent the AP v1 from connecting. Other than that, you could have an issue with your obdii wiring (since it is a swap). You can trace the pins on the obd cable to see which are actually used and make sure you have those pins wired correctly.
Bill
Old 12-09-2011, 12:53 AM   #5
tad_07
Member#: 235873
This is not the swap. Its an orignal 04 sti, I just stated that I happen to have a 04 harness that I can verify my harness with. This is why I was asking what the pins that are blank yet the AP has a pin for?
Old 12-09-2011, 11:25 AM   #6
Cobb Tuning
Member#: 4803
Not all the pins on the connector are used. I do not have a diagram handy, but you can use a multimeter on the cable to trace which pins are used. But, if you are planning to get an AP v2 anyway, I would just go ahead and trade the AP v1 in as it may be a problem with the unit or cable. The AP v2 will overwrite the AP v1 without an issue. I wouldn't jump to the conclusion that there is something wrong with the obdii port/wiring unless you have a reason to believe that it has been messed with before.
Bill
Old 12-15-2011, 09:44 PM   #7
tad_07
Member#: 235873
Thanks for the help Bill, sent my v1 in & my V2 is on the way
Old 12-16-2011, 10:41 AM   #8
Cobb Tuning
Member#: 4803
Sweet. Let me know how it turns out.
Bill
power issue after reverting to stock snowcrzy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-27-2008 10:36 AM
Reverting back to flashed map in Cobb AP2 Question tfoster2501 Engine Management & Tuning 4 01-12-2007 11:05 AM
Administrative Assistant needs to revert to Spanish more often when polyps involved! Asinine Off-Topic 1 05-08-2006 02:59 PM
Gun guys- site to buy tatical stocks for a rem700? rhdude Off-Topic 20 04-02-2004 10:25 AM
I Propose That Anyone Who Receives a TO Reverts to "Newbie" Status SubEd Off-Topic 22 02-20-2003 08:51 PM
