Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC > RMIC Vendor Classifieds
Closed Thread
Old 12-08-2011, 11:13 AM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default $99.00, TANABE NF210 Springs WRX 2002-2003! SPECIAL OFFER PRICING!
Special Pricing While Supplies Last: $99.00.
SOLD OUT!
The NF210 coil spring features a tasteful drop, and produces the best overall ride quality and comfort for a performance lowering spring. The lowered stance of the NF210 gives the car an elegant pose, while the spring rates, which are only slightly raised, retain factory ride quality settings.
This coil spring is extremely popular with luxury tuned vehicles, as well as those with larger diameter wheels that want to eliminate fender gap, but maintain excellent drivability while reducing the risk of damage to wheels that is associated with stiffer suspensions.
For those who demand the best comfort from a lowering spring.
Country of Origin: Japan
Drop Height Front : 1.5in
Drop Height Rear : 1.0in
Drop Height Front Metric : 38mm
Drop Height Rear Metric : 25mm
Spring Rate Front : 140lbs/in
Spring Rate Rear : 112bs/in
Spring Rate Front Metric : 2.5Kg/mm
Spring Rate Rear Metric : 2.0Kg/mm
__________________
RallySport Direct is offline
Old 12-12-2011, 01:44 PM   #2
RallySport Direct
Member#: 33174
We are Open Late!
BuMp!
__________________
Old 12-20-2011, 06:03 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
Fatty deal!
__________________
Old 01-17-2012, 02:58 PM   #4
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 01-30-2012, 05:35 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 02-01-2012, 08:13 PM   #6
DLC
out back
Member Sales Rating: (21)
Member#: 1964
05 OB XT LTD
Silver/Gray
Are these lower rates than what the 06 WRX has? Are these sedan-specific?
DLC is offline
Old 02-02-2012, 01:05 AM   #7
RallySport Direct
Member#: 33174
We are Open Late!
Unfortunately Tanabe does not make the NF210 for the 05-07 WRX/STi, but comparing these to the DF210's for the 06 WRX, the NF210's will be quite a bit softer, more of a comfort spring.
DF210 spec for 05-07 WRX/STi
Drop Height Front: 1.0in
Drop Height Rear: 0.5in
Drop Height Front Metric: 25mm
Drop Height Rear Metric: 13mm
Spring Rate Front: 325lbs/in
Spring Rate Rear: 246lbs/in
Spring Rate Front Metric: 5.8Kg/mm
Spring Rate Rear Metric: 4.4Kg/mm
NF210 for 02-03 WRX
Drop Height Front: 1.5in
Drop Height Rear: 1.0in
Drop Height Front Metric: 38mm
Drop Height Rear Metric: 25mm
Spring Rate Front: 140lbs/in
Spring Rate Rear: 112bs/in
Spring Rate Front Metric: 2.5Kg/mm
Spring Rate Rear Metric: 2.0Kg/mm
Let me know if you have any questions or concerns.
Thanks,
Rick
__________________
Old 02-03-2012, 12:29 AM   #8
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
My 97 Outback has 06 or so WRX springs, and they're a bit stiff, so it would be nice to possibly soften them up a little. I need to double-check to see which year they are.
DLC is offline
Old 02-03-2012, 03:28 PM   #9
RallySport Direct
Member#: 33174
We are Open Late!
These will be a little stiffer then the OEM springs
__________________
Old 03-05-2012, 05:55 PM   #10
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 03-08-2012, 03:23 PM   #11
RallySport Direct
Member#: 33174
We are Open Late!
Sold Out
__________________
Closed Thread
