Old 12-08-2011, 05:01 PM   #1
extremeSTI
Member#: 301521
black
Default 03 bug eye with 05 sti swap
Im doing my swap and about 80% done so I turned on the ignition switch and the rear lights stay on could that be because the computer isnt plugged up or is there something wrong? my computer wont be in till tomorrow but it just got me curious.
extremeSTI is offline   Reply With Quote
Old 12-08-2011, 05:08 PM   #2
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
Lightbulb Stop!!
The last thing you want to do is power your electrical system up without having all connections made,checked and verify all grounds are good. you need to have patience or you'll toast something before you know what you've done and have to track down a problem that you could of avoided.
On every swap Ive done, the last step was powering up and checking for fuel pump activity and pressure. Without the ECU in your just wasting time and possibly causing a big problem. Get it 100%, check it all over again, then turn the key.
02 Scoob-TN is offline   Reply With Quote
Old 12-08-2011, 10:40 PM   #3
extremeSTI
Member#: 301521
black
I feel you, just can't wait but the ecu should be in tomorrow and everything should be complete.
Old 12-08-2011, 11:13 PM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Is your dash all together?
Are your headlights turned on 1/2way?
Column control not plugged in?
dangerousatom is offline   Reply With Quote
Old 12-10-2011, 09:20 PM   #5
extremeSTI
Member#: 301521
black
dash is all together computer plugged up and shes cranking but no start, I noticed where the fuse panel is theres an plug that looks like some kind of modual or box goes there but wont know till my friend comes thru with his STI
Old 12-10-2011, 10:52 PM   #6
extremeSTI
Member#: 301521
black
I figured out what it is, its the keyless entry modual plug, but i still can't figure out why the rear tail lights stay on and now the windshield wipers just come on by their self. anyone have these problems with an swap?
Old 12-11-2011, 03:44 PM   #7
extremeSTI
Member#: 301521
black
ok I figured out the no start problem, to much time on this car and needed to clear my head so I waited till today and went back in and noticed one of the ECU plugs was'nt all the way in so now the next issue is that she will start but quickly die out and the check engine light is flashing also if you leave the ignition switch on you hear a relay clicking and the fuel pump is cycling off and on, Im thinking it could be I may have crossed the fuel lines? and is that possible?
Old 12-11-2011, 03:52 PM   #8
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
Period. Find out where it is.
Sounds like the car is in test mode.
Un-plug the green connectors.
What ecu is in the car?
Also for your tails- the switch on top of the steering column.
Kris.is.awesome is offline   Reply With Quote
Old 12-11-2011, 04:27 PM   #9
extremeSTI
Member#: 301521
black
feel real stupid about the tail lights
and the ecu thats in the car is the one that came with the car and its a B9 if that helps also what green connectors are you refering to
Old 12-11-2011, 06:38 PM   #10
extremeSTI
Member#: 301521
black
how do you tell which one is the supply and return fuel lines from the car side and the engine side. and why are there 3 lines for the fuel system? I know the bottom from the car side is the supply line but I lost on which is the return of the other 2
Old 12-11-2011, 07:07 PM   #11
extremeSTI
Member#: 301521
black
Any Help
Old 12-11-2011, 07:29 PM   #12
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
Haha, was the switch on the column keeping the lights on?
Under the dash there are two green plugs, you only connect them to put the car in test mode.
You will need an sti ecu at some point.
Old 12-11-2011, 07:47 PM   #13
extremeSTI
Member#: 301521
black
I do have an STI ecu, at least i think I do
Old 12-11-2011, 07:55 PM   #14
extremeSTI
Member#: 301521
black
I dont know where your at but if I ever see you I owe you big time, its running
Old 12-11-2011, 10:15 PM   #15
dangerousatom
Member#: 70710
Is your Fuel filter in tank???
The green plugs are under the dash near the clutch peddle
The wipers...you will most likely have to repin the plug going into the wiper motor. In my swap 02 rs with04 STi the STi ECU tells the stock RS and I believe WRX to run high and only high only due to 2 wires being indifferent positions.......its fairly obvious when looking at the wiring diagrams STi vs WRX.
Flashing ECU is engine problems happening actively AKA right then and there. This could be the ECU or something sensor to ECU not being normal for the ECU your currently running.
Fuel lines are:
TOP = RETURN
MIDDLE = VAC
BOTTOM = FEED
Old 12-12-2011, 01:26 PM   #16
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
Glad I could help!
FS/FT : CA: Socal, 03 wrx to complete 05 sti swap project b3nj4m1n SCIC Private Classifieds 18 11-27-2010 09:24 PM
FS/FT : CA: Socal, 03 wrx to complete 05 sti swap project b3nj4m1n Private Vehicle 'For Sale' Classifieds 11 11-15-2010 03:25 AM
02 bug eye with 2.5l hybrid swap quarter mile flon3y Proven Power Bragging 11 01-03-2007 05:13 PM
bug eye with 04 sti wheels. anyone???? TurboInside Interior & Exterior Modification 9 05-11-2006 12:09 AM
what to do with DBW with 05 sti swap into 02 wrx? bustaman Subaru Conversions 7 11-16-2005 02:11 AM
