Old 12-08-2011, 07:11 PM   #1
gf8love
Member#: 300591
Default loss of boost
So finished putting the car together it running decent but when boosting as soon as I get into the higher rpms (usually around 3) there is a loss of power and a noise that sounds some what like a whine kicks in...the only thing different setup wise on the engine from how it originally was on my old car is that it has a fmic now.
gf8love is offline   Reply With Quote
Old 12-08-2011, 08:54 PM   #2
cmyles
Member#: 275572
2007 Built STi
how are the coilpacks?(most likely not the issue)
what all was taken apart, replaced ect?
vacuum lines are all on correctly ect.
cmyles is offline   Reply With Quote
Old 12-09-2011, 12:47 PM   #3
Aphex28
Member#: 11506
2015 WRX
you have a boost and or up pipe leak
Aphex28 is offline   Reply With Quote
Old 12-09-2011, 03:56 PM   #4
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
I'd check your charge pipes on your FMIC setup.
omahasubaru is offline   Reply With Quote
Old 12-09-2011, 09:37 PM   #5
gf8love
Member#: 300591
Wouldn't an uppipe leak have a exhaust leak noise? And it could be the charge pipes. Could also be possible that those symptons could be coming from from the bov because the fitting for that is poor and the rubber pipe to the ic pipe has a kremps in it.
help loss of boost... dumps boost at 4.5 rpm freerider42 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-02-2010 06:25 PM
Loss of Boost Please help BIGRYE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-21-2004 12:29 AM
Loss of Boost scoobyimprza Normally Aspirated with bolt-on Forced Induction Powertrain 2 09-28-2003 09:29 PM
Is this a problem?.......Loss of Boost Blue_dragon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-26-2003 05:38 PM
Loss of boost on Vishnu Stage zero WFO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-14-2002 12:22 AM
