Old 12-09-2011, 12:09 AM   #1
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
Default Swapping an FA or FB engine?
Anyone know anything about the FB/FA engines? or how they differ from the EJs?
I'm mostly curious about the bellhousing. If an FB or FA engine could be bolted to an EJ trans, or vice versa.
Here's an FB16 on display.....bellhousing LOOKS very EJish:
Numbchux is offline   Reply With Quote
Old 12-10-2011, 12:25 PM   #2
kheff46
Member#: 66739
2002 WRX wagon
same bellhousing/bolt pattern as EJ.
--keith
kheff46 is offline   Reply With Quote
Old 12-10-2011, 06:23 PM   #3
pocketdrummer
Member#: 197301
2005 WRX STI
W R Blue (02C)
what's the difference between the FA and FB engines?
pocketdrummer is offline   Reply With Quote
Old 12-10-2011, 07:06 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the big issue will be the EM
Old 12-12-2011, 02:19 PM   #5
kheff46
Member#: 66739
2002 WRX wagon
i know FB's are timing chain engines designed like the EZ 6 cyl's, and have the oil filter up top where you fill up the EJ's oil(kinda neat imo). they have a distinct noise upon startup before the hydraulic tensioners are fully actuated, unlike EJ's.
EM is always the BIG issue it seems going from older to newer versions.
but tranny mount is same, the 5mt is still in use behind it when you opt for the manual trans instead of CVT.
--keith
Old 12-12-2011, 03:44 PM   #6
Numbchux
Member#: 71658
'84 Brat
yep, timing chain and asymmetrical rods like the ez36.
I'm sure they are CANBUS systems, so standalone EM would be necessary. but I'm really happy to hear that it would bolt in place of an EJ.
Old 12-13-2011, 11:05 AM   #7
kheff46
Member#: 66739
2002 WRX wagon
i believe its all going that way(assym rods), but not sure about diesel rods. i would suspect "normal" rods for strength there, but who knows, they could be like older VW i4's... can switch from gas to diesel with a head swap(except EM)!?! that would be kinda sweet.
--keith
Old 12-13-2011, 01:28 PM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
The Diesel rods are also asymetrical (which, by the way, does in no way influence the stroke or capacity of the engine, just makes installtion easier as they can be assembled with the piston already attached).
Marnix is offline   Reply With Quote
Old 12-15-2011, 11:30 AM   #9
kheff46
Member#: 66739
2002 WRX wagon
good to know Marnix! and you're correct, its just for speedy assy purposes.
do we know if the diesel rods are the same exact rod as the gas(diesel 2.0 and gas FB2.0)? or just assym.?
--keith
Old 11-15-2014, 12:51 PM   #10
elcuerno
Member#: 406369
2012 impreza
How about engine mounts? I would think a new fb engine in an older impreza 5 speed would get 40 mpg easy.
elcuerno is offline   Reply With Quote
Swap an EJ257 or not? PHilly02WRX Subaru Conversions 5 02-21-2010 05:05 PM
Swapping an EJ257 STI engine into an RS or possibly WRX Audioexcels Subaru Conversions 0 04-27-2009 12:31 AM
Bought an '06 STi and now I want to swap an EVO engine!!!!! WhatSti Off-Topic 61 11-30-2005 09:16 AM
Pros and cons - WRX engine/tranny swap to an RS or buy a WRX Snoopy Off-Topic 40 10-15-2004 10:38 AM
Engine swap a L or just get an RS? FlatEngines Normally Aspirated Powertrain 7 10-10-2002 12:47 PM
