Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 12-09-2011, 02:16 PM   #1
efiniluvr
Member#: 107170
2002 ver 7 EJ207 WRX
Default 02 Bugeye 2.0L to 2.5L; what is needed?
Hi everyone,
I'm looking to swap out the 2.0L out of the Bugeye for a replacement. At this point, I'm still undecided on a few of my options. If I choose to go with a 2.5L, what is needed and what can I keep? Secondly, can you purchase a new longblock somewhere? If you have personally purchased a new long block, please provide seller info and pricing.
This is for a daily driver. so I really don't want to play with Sti swaps.
Here is a list of my options:
1)Replace old 2.0L with a low mileage 2.0L longblock
2)Replace old 2.0L with a NEW 2.0L longblock
3)Replace old 2.0L with a low mileage 2.5L longblock
4)Replace old 2.0L with a NEW 2.5L longblock
5)Other options??
Thanks
-Jeff
efiniluvr is offline   Reply With Quote
Old 12-09-2011, 03:24 PM   #2
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Deep pockets?
wrxlaunch is offline   Reply With Quote
Old 12-09-2011, 03:34 PM   #3
efiniluvr
Member#: 107170
No deep pockets here, but I do have a set budget. If the price of the options are within 10% of each other, then I'll definitely consider the one with best long term reliability.
Mods: Thanks for moving this thread.
-Jeff
Old 12-09-2011, 03:42 PM   #4
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Should be able to get a new shortblock for ~$2k. If it were me... I'd get the 2.5, tune and call it a day
Old 12-09-2011, 04:05 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Not me, I would rebuild (or pay to get rebuilt) an EJ22 and throw that it under your stock heads. But of course you haven't told us about potential power levels or goals yet...
~Josh~
Old 12-09-2011, 04:12 PM   #6
biodude
Member#: 271720
state your budget, so there is less guessing
biodude is offline   Reply With Quote
Old 12-09-2011, 04:41 PM   #7
efiniluvr
Member#: 107170
$3500 max. Again, this is for a daily driver, so no hybrids, or Sti swaps (unless they fall within my budget). I prefer a longblock because I've never had any good luck with motors that I've had to put together. Playing with Honda B-Series, it never fails that the headgasket either leaks, or the piston rings weren't gapped correctly (not done by me). I would just prefer to have an assembled longblock (or an entire motor) that is ready for drop in. That's why I asked about longblocks, whether they can be purchased assembled.
At most, I'm only looking at a Stage 2 power level.
-Jeff
Old 12-09-2011, 10:25 PM   #8
Ruvim555
Member#: 247724
2002 WRX WRB Stage 2
2007 CBR 600RR
ej207?
Ruvim555 is offline   Reply With Quote
Old 12-10-2011, 08:35 PM   #9
ballitch
Member#: 74907
98 cam'd EJ251
^^ probably more than $3500.
If you're looking for someone to hand you a motor, you might want to think about raising your budget. Unless you know someone in your area that you can have build it for you as a part time side job once you gather all the pieces. An EJ257 block eats up a fair chunk of that budget.
~Josh~
Old 12-10-2011, 09:09 PM   #10
psychorunner
Member#: 226568
2002 Bugeye STI
Keep an eye out for a totalled STI...If you have the time you might be able to find one for cheap. I got one for $4500, then sold a bunch of parts, basically came out even on the whole swap. Maybe I just got lucky though
psychorunner is offline   Reply With Quote
Old 12-12-2011, 12:27 PM   #11
efiniluvr
Member#: 107170
I was thinking of pulling a stock 02-04 motor from a wreck and do a straight forward swap. No messing with tear downs, wiring, or headaches. If I decided to get a 2.5L, do I just need the ECU?
Old 12-12-2011, 12:32 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the 2.5 short block is a straight swap ...but I'd get the heads cut to match the bores and be done
MOST of the 'hybrid' issues are the heads not matching the block...but that's easy
the only other thing would be arranging the breathers...but that is minutes not hours
this is not a complicated or expensive thing to do
Old 12-12-2011, 01:56 PM   #13
efiniluvr
Member#: 107170
Thanks Uncle Scotty,
What I meant, was I was going to swap over the entire 2.5L motor, not the EJ257 route. Just ECU and done?
Old 12-12-2011, 10:03 PM   #14
WoodsWagon
Member#: 180769
lots of junkers
The EJ25's will have variable cam timing, which the EJ20 doesn't and the bugeye's computer won't support. That's why people swap an EJ25 shortblock under the EJ20 heads. Machining the combustion chambers in the EJ20 heads to EJ25 specifications is highly recommended. Then have the EJ20's computer tuned to the bigger engine.
If you do a longblock swap to an EJ25, then you will have to splice the harness and convert over to a matching ECU.
A pre-assembled EJ257 shortblock is $2,100 brand new from Subaru.
WoodsWagon is offline   Reply With Quote
Old 12-13-2011, 01:04 PM   #15
efiniluvr
Member#: 107170
Thanks to everyone's input. It seems alot of you advocate the hybrid route. I think for now, I will go with a EJ20 engine pulled from the yard. If and when I have the time and money, I will built up the hybrid motor using the heads from the old motor. There is a reputable local tuner that does the head matching.
-Jeff
2.0l to 2.5l swap, and what AVCS means to you keaniegenie Built Motor Discussion 56 04-05-2011 05:11 PM
2.0L to 2.5L Swap in progress. Motor/trans at same time? uberspeed Subaru Conversions 6 12-10-2010 10:27 PM
2.0L to 2.5L short setup: Dyno session questions? MarylandEcstasy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 07-01-2006 11:54 PM
2.0L to 2.5 02blkwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-22-2006 06:06 PM
2.0L to 2.5L Wrx Szm426 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-08-2002 09:42 PM
