Old 08-10-2002, 05:48 PM   #1
2.5racer
Member#: 12482
2000 RS w/ej20 & e85
94 RX-7 1/2bridge w/meth
Default no cat. how get rid of cel
I am making a 2.5" track pipe. I don't want the cel to come on cause at the track I would rather it came on with a real problem. the pipe bolts from the header and goes all the way back (I might add a muffler cause I don't want to get pulled over on the way to the track (300 mile drive). We don't have smog laws but noise laws do come into effect. ummm oh yea does anyone know if a straight 2.5" will have enough back pressure cause I heard that na motors need some back pressure.
also I want to make a daily driven pipe and I wan't a deep boxer sound what would create this (not a raspy "thhhhh" rice sound) i've heard a 3" n/a (he just added a turbo) and it made a deep sound but it had wierd pulses (this was on an eclipse) I want a deep solid sound.
sorry I tend to type alot.
thanks for any help.
2.5racer is offline   Reply With Quote
Old 08-10-2002, 07:35 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Default Re: no cat. how get rid of cel
Sure you do, it's called Federal Law. Your state might not have an emissions testing program, but you are still required by Federal Law to have a fully functioning emissions system on your car. My guess is you'll pick up a grand total of 2 or 3hp over what you would get if you just used a hi-flow cat in place of the restrictive stock cats.
If this is for a real track (in other words, a road course) then you don't need to worry about any loss of low end torque you might experience as a result of the reduced backpressure. You'll be at high RPMs all the time, and at those RPMs the extra breathing ability of the more open exhaust will be a good thing.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 08-10-2002, 07:44 PM   #3
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
That's a bit of a Myth. Backpressure itself is bad. Exhaust velocity is good. If you get too large of a pipe, you can lose some of the exhaust velocity which helps in "sucking" out the exhaust from the motor. With a good exhaust, you can feel it from about 2feet behind the car with the car idleing.
Almost forgot. You can get rid of the CEL if you get some sort of MIL eliminator. Do a search on google and you'll come up with a few.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 08-10-2002, 07:58 PM   #4
2.5racer
Member#: 12482
thanks for clearing up some things (I might just get a hiflow cat and not worry about the cel thing) but does anyone know how to get a deep rumble I don't want raspy, if you know what I mean.
and it's for drag track although there are a few auto-x that take place near here, and I am planning on visiting my friend and hitting laguna seca later this summer.
CEL! How to get rid of it? WRXfoME Newbies & FAQs 8 09-21-2005 05:18 PM
P0170 CEL How do I get rid of it? Pi7467mp Normally Aspirated with bolt-on Forced Induction Powertrain 14 05-29-2004 02:57 PM
How to get rid of a cat? <serious only> 4x4GGG Off-Topic 38 10-23-2003 08:59 PM
How do you reset the ECU to get rid of a CEL? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-19-2002 01:54 PM
So what is the best way to get rid of those damned Cats without triggering CEL? IncubusDude Newbies & FAQs 9 04-18-2002 02:11 PM
