Old 12-10-2011, 10:23 AM   #1
kenratboy
Member#: 34304
2008 Impreza Wagon
Default What types of PS fluid can I use in my '08 Impreza?
I know what the manual says, but I am wondering if someone can give me a bit more insight on what types work best, what to avoid (as in, what can harm the system), or any other details.
Steering is a bit heavy, and getting some noise (especially when cold). Thinking this could be a quick, easy first pass to see if I can improve things.
Thanks!
Ken
kenratboy is offline   Reply With Quote
Old 12-10-2011, 10:43 AM   #2
68Cadillac
Member#: 95901
I use
Mobil 1 Synthetic ATF. Yes ATF. Automatic Transmission Fluid. It's rating is better than the DEXRON III Suburu calls for as a minimum.
It's red and smells bad.
68Cadillac is offline   Reply With Quote
Old 12-10-2011, 01:26 PM   #3
Cinna696
Member#: 185769
2008 WRX
Grey
Originally Posted by 68Cadillac View Post
I use
I use this as well, there are a few DIY around and I recommend disconnecting the resevoir hose so you can flush it through.
Cinna696 is offline   Reply With Quote
Old 12-10-2011, 03:55 PM   #4
kenratboy
Member#: 34304
2008 Impreza Wagon
OK to mix some of the old and new? Obviously the more you flush the better, but no issue mixing two different fluids?
Old 12-10-2011, 10:36 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
none......drain the reservoir....refill...drive...repeat
What year MAF can I use in my 04 WRX? iRide Newbies & FAQs 2 05-09-2009 11:57 PM
04 WRX owners, what kind of tranny fluid are you using????? shamrock 05 Transmission (AT/MT) & Driveline 14 12-11-2008 04:58 PM
What kind of PS fluid? 83Rabbit Normally Aspirated Powertrain 2 10-23-2005 11:16 PM
what can i use in my LSi(struts)? stant093@ Brakes, Steering & Suspension 3 01-08-2003 08:40 PM
What kind of diff. fluid should be use? Nanase Transmission (AT/MT) & Driveline 3 10-30-2001 11:08 AM
