Old 12-10-2011, 10:56 AM   #1
ftarhooks
Member#: 300664
Rally blue
Post turbo surge after new turbo inlet hose was installed
Hi I replaced my stock turbo inlet on my 02 bug eye with an after market one now I'm experiencing turbo surge turned down the boost and still getting it plz help Ide greatly appreciate it
02 wrx
Greddy : front mount intercooler, bov ,manual boost controller,turbo back exhaust ,
Aftermarket turbo inlet hose , uppipe (no cats)
ftarhooks is offline   Reply With Quote
Old 12-10-2011, 01:07 PM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
1. I'm sorry, you "turned down the boost?" How?
If you did what I think you did, and adjusted your boost controller without any other sort of compensation from your ECU, then I think you need to stop right now before you blow your ****ing car up.
2. Please type in coherent English.
XanRules is offline   Reply With Quote
Old 12-10-2011, 02:47 PM   #3
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
quote worthy
vien is offline   Reply With Quote
Old 12-11-2011, 12:02 AM   #4
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Yeah, if you are turning up and or down your boost, you better have a way to control your fuel as well, or you'll be driving yourself to disaster. The inlet pipe is going to flow more air anyway, and that in itself wouldn't HAVE to be tuned for on an ;02, but with your other mods, if you haven't had the car tuned, I would say you could be running dangerously lean. Do you have a wideband? Any way to datalog? How much boost were you running before the install, and what did it go to after? It may not be the end of the road, but I wouldn't push it hard until you know more about what's going on inside the motor.
p.s. Your BOV isn't exactly helping matters, since your stock EM has no idea what to do with it.
nevin95 LSi is offline   Reply With Quote
Old 12-11-2011, 01:04 AM   #5
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
The inlet shouldn't affect the way it runs. The MAF pipe is still the same size.
mrjcotten is offline   Reply With Quote
Old 12-11-2011, 01:07 AM   #6
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Then why would someone do it at all?
Old 12-11-2011, 01:33 AM   #7
TwoFifty
Member#: 261764
2003 Impreza WRX
Generally people upgrade their inlet hose for the increased/smoothed air flow to the turbo. If you look at, for example, the Perrin turbo inlet hose it is a decent amount larger then the stock inlet hose, thus increasing air flow. This could most definitely affect the way the vehicle runs.
TwoFifty is offline   Reply With Quote
Old 12-11-2011, 01:45 PM   #8
mrjcotten
Member#: 241953
02 hybrid/6speed
01 2.5 RS sedan
Yeah it is less restrictive, but it should not change the a/f ratios because it is not Altering any parameter that affects the tune. To get the most benefit from it, tuning is needed.
Yes it is less restrictive, so it will help air flow to the turbo.
Old 12-11-2011, 05:32 PM   #9
ftarhooks
Member#: 300664
Rally blue
Ok well the car does have some of a tune don't know what tune or whartit has done to the ecu the car was boosting 20 lbs noww its at 15 lbs I bought the car like that with all the mods about 2 years ago it has 82k miles on it boosting that much its ran like that for 2 years allready up untill this winter when I replaced the turbo inlet cause the oem was torn I have turned down the boost when I go out of town and experience nothing like this like I said I bought the car like this and its hella fast . I bought it boosting 20lbs
Old 12-11-2011, 10:05 PM   #10
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Well, when you say turbo surge, what do you mean exactly? was your boost spiking up and down erratically? Was the turbo making funny noises? Both? Was the engine making an funny noises?
Old 12-11-2011, 10:13 PM   #11
Coo hwhip
Member#: 290126
2003 subaru wrx
blue
check your bov make sure its all intact, when i had installed my 2.4 gimmick inlet hose in my 03 wrx, i took it for a test drive and while driving got a huge turbo surge because i forgot to secure a hose clamp on my bov. so mayb its that mayb its not
Coo hwhip is offline   Reply With Quote
Old 12-11-2011, 10:45 PM   #12
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Simplest thing.......recheck your work.
FuJi K is offline   Reply With Quote
Old 12-12-2011, 10:52 AM   #13
ftarhooks
Member#: 300664
Rally blue
Yea I've triple checked all the hoses everything what I mean by turbo surge is it has the fluttering sound kinda sounds like a turkey blow off it sounds as if its coming from my intake cone others suggested that I adjust the bov
Old 12-12-2011, 11:41 AM   #14
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
omguhavecompressersurge!!!!!!!! adjust your bov. they require proper maintenance and adjustment. carry on.
jayman4312 is offline   Reply With Quote
Old 12-12-2011, 11:43 AM   #15
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
Fluttering when you lift the throttle is compressor surge. The bov is 100% to blame for this. Go back to stock and your problem is gone. Easy as that.
evan_impreza is offline   Reply With Quote
Old 12-12-2011, 11:45 AM   #16
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Put the hose back onto your BOV.
Go back over everything that you touched while replacing the inlet.
Not if he's tuned for the front mount/bov.
It's also possible that this has been happening since day one and you're just hearing it now due to the inlet.
Psychoreo is offline   Reply With Quote
Old 12-12-2011, 12:11 PM   #17
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
Lol you can't tune the ECU to get rid of compressor surge if the bov spring is too tight. Cannot.
Old 12-12-2011, 12:12 PM   #18
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
You could "tune" the bov by loosening the spring a bit, but then it may leak at idle. That's about all he can do.
Old 12-12-2011, 12:15 PM   #19
Psychoreo
Member#: 79643
2015 WRX STI
Didn't say you could.
But you CAN tune a car in speed density to account for a BOV as opposed to a BPV.
Judging by the op's post, anything can be possible and shouldn't be swapping parts around all Willy-billy until you know exactly what's on the car and has been tuned for.
Old 12-12-2011, 12:18 PM   #20
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
Speed density won't help the compressor surge at all. It will stop the rich swing in AFRs but not the surge.
Old 12-12-2011, 12:20 PM   #21
ftarhooks
Member#: 300664
Rally blue
What I'm going to do is adjust the boost back to 20lbs how its been at and adjust the bov. Now the question is how do I adjust the bov its a Greddy bov
Old 12-12-2011, 12:25 PM   #22
Psychoreo
Member#: 79643
2015 WRX STI
Exactly.
And if it's tuned in speed density to account for an atmospheric bov and you replace it with a BPV?
Potential leanbeen happening since day one but the inlet is allowing it to be heard.
Step 1 is rechecking your work.
Old 12-12-2011, 12:27 PM   #23
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
There is a nut on the top of the valve with "soft" and "hard" labeled for which way you should turn it. Make it softer, or CCW. And easy with that MBC. Just cranking on a MBC is NOT the proper way to raise the boost on these cars.
Old 12-12-2011, 12:31 PM   #24
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
Originally Posted by Psychoreo View Post
Exactly.
What?
Old 12-12-2011, 12:45 PM   #25
Psychoreo
Member#: 79643
2015 WRX STI
What?
Install bov.
Gain rich condition during shifts.
Get tuned speed density.
No more rich condition during shifts.
Install bpv while maintaining same tune.
Air gets dumped back into inlet instead of the engine bay.
Potential lean condition.
(unless my vague understanding of speed density is wrong, which is completely possible.)
Regardless, if the condition began after installing the inlet, the inlet is the first place to start.
"hey my car started getting a vibration after I installed new wheels/tires"
Which is the proper step one?
A: check your tie rod ends
B: verify that the new wheels/tires are balanced/straight/not bent.
Weird turkey o noise when i boost after new turbo inlet install ftarhooks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-28-2011 05:00 PM
2009 STI Hesitation and Bucking/Surging After Dealer Turbo Replacement Anexos Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 02-17-2011 07:51 PM
After new turbo install, feels like fuel cut-off at 7psi.... WRXfoME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-19-2007 02:43 PM
Smoke After New turbo Install dlewis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-21-2005 08:14 PM
how much est. horses...after new turbo and IC install SWEETWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-29-2002 03:45 PM
