Old 12-10-2011, 01:56 PM   #1
some dude
Member#: 100300
06 WRX
CGM
Default Is it time to increase my oil weight?
I have a 2006 WRX with 110,000 miles on the odometer. I have been using mobil 1 5W-30 since the beginning (basically). It currently consumes no oil, but I am thinking about switching to a thicker oil as the car ages. Rotella-T comes to mind, but I worry about 15 weight on cold starts in Michigan. The only option with Rotella is 15W-40 right? Should I switch oil if I don't have any problems? I pretty much drive like a grampa 98% of the time, with the occasional pull to readline. Any other suggestions are welcome.
some dude is offline   Reply With Quote
Old 12-10-2011, 02:06 PM   #2
VVagonFTW
Member#: 259139
04 WRX Wagon
JBP
if its not burning oil, i wouldnt worry about it. your oil needs to be able to flow and the higher weight oils will not flow in cold temps.
when the engine is warm 10w-30 and 5w-30 are the same thing (thats the 30 weight part). i wouldnt put 15w-40 in the car, specially in michigan.
if youre dying to do something, in the warmer months you could run 10w-30. but stick with the 5w-30 in michigan when its cold
VVagonFTW is offline   Reply With Quote
Old 12-10-2011, 02:09 PM   #3
sc00by4life
Member#: 97135
Do you throw your oil on a scale before you put it in your car?
Oil is not measured in "weights".
Old 12-10-2011, 02:14 PM   #4
VVagonFTW
Member#: 259139
04 WRX Wagon
JBP
fine, dynamic viscocity rating of 5w-30 is good for all temps, specially cold temps in michigan
Old 12-10-2011, 02:18 PM   #5
sc00by4life
Member#: 97135
Sorry, but it seriously bugs me. This isn't fast and the furious. There is nothing having to do with "weight" in any oil rating.
Old 12-10-2011, 02:32 PM   #6
VVagonFTW
Member#: 259139
04 WRX Wagon
JBP
i understand the rating is a viscosity rating but the units that viscosity is measured in are too complicated for most people to understand when looking at a bottle.
im not sure where the 'weight' term came from, but its been accepted as the term most people use for oil. while its not correct, many people call an engine a 'motor' but we all know what they are talking about.
Old 12-10-2011, 02:35 PM   #7
mexicanzero
Member#: 167820
2003 WRX wagon
ej207 + 6 speed
rotella is available as 5w40 as well and many run that ( i run it in the summer)
if your car is stock or close to stock and you drive "normally" then 5w30 is fine as it is whats recommended by subaru... however mobil 1 5w30 has been known to shear to 5w20 so i personally would run another more trusted brand
mexicanzero is offline   Reply With Quote
Old 12-10-2011, 02:47 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the 15w40 rotella isnt synthetic.....the 5w40 IS
Old 12-10-2011, 02:50 PM   #9
schochwave
Member#: 253456
2005 WRX STi/Baja tu
black/gray,silver
I use royal purple 10w-30
schochwave is offline   Reply With Quote
Old 12-10-2011, 03:44 PM   #10
That guy in Maine
Member#: 256642
I use 10w-40 in my car...I live in Maine...no problems so far.
That guy in Maine is offline   Reply With Quote
Old 12-10-2011, 03:48 PM   #11
Malachoz
Member#: 226411
2011 Subaru
STi SWP Hatch
Rotella T-6 Full Synthetic 5w-40
Been running it in my last three subies and 0 problems with them thus far.
Almost all my friends use the same oil.
Shell Rotella---http://www.amazon.com/dp/B004TXU4I2/ref=asc_df_B004TXU4I21815791?smid=ATVPDKIKX0DER&ta g=hyprod-20&linkCode=asn&creative=395093&creativeASIN=B004T XU4I2
Malachoz is offline   Reply With Quote
Old 12-10-2011, 06:35 PM   #12
ebolamonk3y
Member#: 303131
If it doesn't burn oil don't change it. Change the oil weight depending on the operating temperature not car age.
ebolamonk3y is offline   Reply With Quote
Old 12-10-2011, 10:06 PM   #13
J_mythsuby
Member#: 292113
'15 cwp rex
'12 DGM rex sold
We use 15w40 in army vehicles. That crap sucks when the temperatures drop pretty low out of nowhere and it makes starting everything harder.
In my legacy I ran 5W30. On negative days, it took a good few tries to get it running in the mornings. After a half hour of so (short commute here on base) the idle would level out and it wouldn't run so hard. For especially cold times, some people go 0w30.
As far as "weight" goes, its a term a lot of people use. In differentials we run 80W90 and its really tells people that's some heavy friggin oil. Because, honestly, you wouldn't want that grade of oil in anything other than diff's. I know a few people who run it on their civilian vehicles.
J_mythsuby is offline   Reply With Quote
Old 12-10-2011, 11:03 PM   #14
bluesubie
Member#: 767
04 FXT
The proper term is grade, but even some oil companies use the term weight on their web sites.
To the OP, it's usually a good idea to stick with what works although the Mobil1 High Mileage 5W-30 has a more robust additive pack and a thicker viscosity at 100C than the regular stuff. It also has additional seal swellers if you have leaks. A used oil analysis would be a good starting point to help you make your decision.
-Dennis
Old 12-10-2011, 11:38 PM   #15
VVagonFTW
Member#: 259139
04 WRX Wagon
JBP
-Dennis
i did an oil analysis and they will check for coolant in your oil and some will do flashpoint checks to find fuel in your oil. they are helpful, but your oil filter will filter out a lot of metals and stuff so it still makes it difficult to pin point the condition of bearings and such. i did an oil analysis and everything was great cause my Purolator PureOne filter cleaned the oil so well, i spun a bearing a couple weeks later.
i dont mean to devalue the info an oil analysis gives you, its great info, but how you have treated the car makes the biggest difference.
i would run Valvoline synthetic or Valvoline high mileage 5w-30 if you drive your car normally 95% of the time, as you say you do.
Old 12-11-2011, 03:33 PM   #16
some dude
Member#: 100300
06 WRX
CGM
I like that Rotella has a 5W-40 option. I had a UOA done at about 70k and it came back perfect. I like thin cold oil so just wondering if I should switch to a thicker oil at operating temp as the engine wears and tolerences (increase?). But, if its not burning any oil right now and I don't have any problems then maybe there is no need to switch? What harm could come if I did switch even though it appears my current oil works just fine?
Old 12-17-2011, 01:19 AM   #17
VVagonFTW
Member#: 259139
04 WRX Wagon
JBP
thicker oil flows slower. if anything did happen, you could starve parts of the engine for oil while running. it wont make a huge difference, but the engine was designed to run with the 5w-30.
if it doesnt burn oil, keep it the way it is
Old 12-17-2011, 02:22 AM   #18
rkramer
Member#: 118209
2015 WRX Limitec
Please crack open your manual and read it... 5w-30 of ANY oil is about the worst choice you can make.
Old 12-17-2011, 08:35 AM   #19
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
This this this this this.
Especially Mobil 1 5w30 which probably has the worst reputation out of all other 5w30 on this forums from what I have seen.
As for cold starts with Rotella 15w40... I am running Rotella 15w40 in my Legacy, and I live up in Connecticut. Cold starts are not a problem, it just builds oil pressure up a little slower with a cold start, but the pressure is still there so there should not be an issue. I have HLAs, if there was a pressure issue, they would tap away and I would know. Starts up in 10* weather, cranks slower, but starts.
Jessekrs123 is offline   Reply With Quote
Old 12-17-2011, 12:48 PM   #20
some dude
Member#: 100300
06 WRX
CGM
^ So really, Rotella 5w-40 would be better for you. Especially in the winter. What would it mean to my engine to run a 40W oil at running temp? It will be the same viscosity as my current oil as both Rotella and Mobil 1 have 5 'weight' for cold temp. Since the engine is aging, I would think that having 40 might be a little better. Plus there is now issue of oil starvation on cold starts.
Old 12-17-2011, 07:47 PM   #21
bugeyetex
Member#: 283815
2003 psm wrx wagon
Built Fuji Tough
The 'W' means winter, not weight. Not kidding, look it up.
bugeyetex is offline   Reply With Quote
Old 12-18-2011, 10:49 AM   #22
bluesubie
Member#: 767
04 FXT
Actually, "W" doesn't mean winter or weight according to the SAE. It's just used to show a multi-grade oil and doesn't stand for anything. http://www.bobistheoilguy.com/motor-oil-107/ Even some oil web sites state that "w" means winter so it's very common to think that. But just because an oil is a 5W, doesn't mean that all 5W's are the same viscosity in all "cold" temps. A 5W's cold cranking results are measured at -30C/-22F. http://www.pqiamerica.com/coldcrank.htm
Before a 5W-30 and 5W-40 get down to -22F, the 5W-40 will be thicker in most temps. You can get a better idea of an oil's viscosity at various temps by plugging the 40C and 100C results into a viscosity calculator. http://widman.biz/English/Calculators/Graph.html At 0C/32F, RT6 has a viscosity of 756.8 cSt's and M1 5W-30 has a viscosity of 490.
-Dennis
Old 12-18-2011, 10:14 PM   #23
some dude
Member#: 100300
06 WRX
CGM
-Dennis
Very interesting. And to confirm, is RT6 = Rotella 5W-40?
edit: a small search confirmed ^ yes
Old 12-21-2011, 11:23 PM   #24
VVagonFTW
Member#: 259139
04 WRX Wagon
JBP
the manual says 5w30?
a little confused if im looking at the right things or not but the manual calls for 5w-30.
Old 12-22-2011, 07:55 AM   #25
bluesubie
Member#: 767
04 FXT
Yor manual advises that 5W-30 is preferred for the best FUEL ECONOMY and that thicker viscosities (10W-30 isn't necessarily thicker) are required in higher temps and recommended in severe conditions. If it doesn't say this, you have the wrong manual. Stand by for a picture of this from Uncle Scotty.
-Dennis
Is it possible to increase the PM mail box size? cueballsi General Community 19 04-09-2011 12:01 PM
What time is it? Time to stock up on Microfiber Towels DetailersDomain Car Care & Detailing 2 10-06-2010 09:01 PM
so is it time to start shaving my head? *going bald issues & photo included* INFIDEL Off-Topic 51 09-25-2007 09:17 PM
Is it possible to increase radio reception? TrunkMonk Car Audio, Video & Security 3 01-24-2003 03:12 AM
When is it time to change to sinthetic? Ebarb01 Newbies & FAQs 9 10-23-2001 10:44 PM
