Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Closed Thread
Old 12-10-2011, 02:05 PM   #1
speedmonkey
Member Sales Rating: (40)
Member#: 97652
Default Bridgestone Potenza RE050A Pole Position Tires 245/40R18
For Sale are a used set (4) of Bridgestone Potenza RE050A Pole Position Tires that have a lot of life in them and still have a tread depth of 7/32".
This set of tires are very clean and in excellent condition as they were only used during the summer months on public roads.
The tires were on a dedicated summer wheel and have only been mounted and dismounted once and have no damage and/ or repairs such as plugs etc.
Tire Specs;
93Y
Tread Depth: 7/32"
The Potenza RE050A is a Max Performance Summer tire designed to complement the performance of sports cars, sports coupes and sport sedans. While the Potenza RE050 is used as Original Equipment on the supercharged Mercedes-Benz S55 AMG sedan, a Potenza RE050A Scuderia version is used on the 12-cylinder Enzo Ferrari supercar, and a Run Flat version is used on the BMW Z4 sports cars and 5-Series sedans. The Potenza RE050A was developed to provide good traction along with responsive and predictable dry and wet road handling. It is not intended to be driven in near-freezing temperatures, through snow or on ice.
On the outside, the Potenza RE050A features a high grip tread compound molded into an asymmetric tread design. A continuous center rib, large tread blocks and stable shoulder elements provide responsive handling, high-speed stability and traction on dry roads, while circumferential and lateral tread grooves are aimed to pump water out from under the tire's footprint to minimize hydroplaning and aid wet traction. A continuous circumferential rib adjacent to the inside shoulder blocks enhances wear quality to help reduce noise throughout the life of the tire, especially on cars with alignment settings that specify negative camber. Internally, the Potenza RE050A features twin steel belts reinforced by spiral-wrapped nylon to stabilize the tread area and enhance handling, high speed capability and ride quality while minimizing weight. The fabric cord body and hard rubber sidewall filler help blend uniform ride quality with steering response and lateral stability.
These are available for local pickup/ meet only! Sorry I cannot ship!
I am located in Bucks County, PA.
$500 for the set. Cash or Paypal + fees.
Please send me a PM if interested. Thanks!
speedmonkey is offline
Old 12-11-2011, 08:41 AM   #2
speedmonkey
Member#: 97652
Bump!
Old 12-12-2011, 09:00 PM   #3
speedmonkey
Member#: 97652
Bump!
Old 12-16-2011, 09:29 PM   #4
speedmonkey
Member#: 97652
Bump!
Closed Thread
FS Baltimore – 2004 STI BBS 5X100 w/ Bridgestone Potenza RE050A Pole Positions Psybin MAIC Private Classifieds 21 11-14-2008 10:44 AM
FS Baltimore – 2004 STI BBS 5X100 w/ Bridgestone Potenza RE050A Pole Positions Psybin Wheels/Tires 26 11-13-2008 03:59 PM
FS: Rota Tarmac3 18x8 w/ Potenza RE050A Pole Position Tires Gray_Scale Wheels/Tires 17 11-05-2008 05:58 AM
FEELER: Rota Tarmac3 18x8 w/ Potenza RE050A Pole Position Tires Gray_Scale NWIC Private Classifieds 11 11-03-2008 07:16 PM
Bridgestone Potenza RE050A Pole Position Tread Life? -AliasMunky3- Tire & Wheel 0 10-29-2006 10:09 PM
Message Board Statistics All times are GMT -4. The time now is 02:03 PM.
