Old 12-10-2011, 10:50 PM   #1
04pageSTI
Member#: 303569
Default JDM Spec-C Type RA-R swap HELP!!!
Here's the story:
04 STI Engine was blown, so my mechanic which is a master tech for Ford, order an engine online. When we recieved the engine we realized it was the JDM spec C-type RA-R with the twinscroll turbo (not the engine we bought). The company only allowed a 7-day return policy therefore we ended up keeping the engine.
Here's the problem:
04 STI US engine used the electronic throttle through the ecu, where the JDM uses a throttle body cable. The CAM position sensors are different also.
We were considering using a wrx engine harness which we think would solve the CAM position sensor problem, but are unsure of this solution.
Please anyone help! If you've done a JDM swap into an STI or WRX.
Any help would be appreciated.
Thanks!
04pageSTI is offline   Reply With Quote
Old 12-11-2011, 12:17 PM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
So u bought a Jdm Spec C Long Block & need a USDM STI motor...?
I'll trade you ..
Seriously ?.. Sounds like a troll
sense of nature is offline   Reply With Quote
Old 12-11-2011, 02:07 PM   #3
Badler
Member#: 133597
Pretty sure you'll need the JDM ecu or a standalone.
Badler is online now   Reply With Quote
Old 12-11-2011, 02:15 PM   #4
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
The JDM motor will run on a US ecu.
I'm not sure, but can you not swap throttle bodies?
Kris.is.awesome is offline   Reply With Quote
Old 12-11-2011, 04:09 PM   #5
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
A RA-R would be a '07.
Post a picture of this, so we can better help you.
This should come with engine harness and ECU. Do you have these?
With these you would have to convert to throttle by cable, to do everything right.
If you have the engine harness that comes with it, you should be able to do the swap, once you do the conversion.
Cobtact IAP to purchase the wiring diagram of your engine and download the wiring diagram of the Sti from the net.
Old 12-11-2011, 07:31 PM   #6
sense of nature
Member#: 112759
SexyRP
Worst case , swap the IMw/ rails & engine harness
Old 12-12-2011, 04:07 AM   #7
04pageSTI
Member#: 303569
almost positive its the RA-R
i'll post pics as soon as I can, but yes it came with the wiring harness and ecu. I think we have come to the conclusion that we are gonna have to switch to the throttle body cable.
And we originally just wanted the USDM but they shipped us the JDM instead, and no sorry not lookin to trade
Old 12-12-2011, 12:19 PM   #8
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
Trust me if you do it right the JDM is so much better!!
02 Scoob-TN is offline   Reply With Quote
Old 12-12-2011, 01:56 PM   #9
durania717
Member#: 153468
Wow, I am anxious to see the picture. If it is RA-R, you got a gem.
durania717 is offline   Reply With Quote
Old 12-12-2011, 03:49 PM   #10
jzk25
Member#: 179120
If it's a reluctor type rear cam sensor you can convert these to hall effect with an electronic box.
You would be better to use an aftermarket ecu or factory RA-R ecu to get the best out of the engine. If it's really an RA engine it'll be handbuilt and have around 230kw factory. Also has VF36 turbo, one piece inlet manifold, larger headers, hard intake pipe etc.
jzk25 is offline   Reply With Quote
Old 12-14-2011, 06:32 PM   #11
04pageSTI
Member#: 303569
Anyone know where I can get a full wiring diagram for this JDM engine?
Old 12-14-2011, 07:53 PM   #12
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
http://www.iaperformance.com/
Send them an email or call them and ask for the wiring diagram, it's not cheap and it's in Japanese.
Even so, it's easy to figure out, when you put it side-by-side with the USDM diagram in English.
Old 12-14-2011, 08:56 PM   #13
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's probably a version 8 sti engine.
Get an 02 or 03 usdm wrx harness, add in the couple extra wires for the avcs and run it on a jdm verison 8 ecu. Get a cable gas pedal.
It's not really a big deal.
Old 12-23-2011, 06:58 PM   #14
sense of nature
Member#: 112759
SexyRP
^This....
Old 01-01-2012, 05:17 PM   #15
KingKoopa
Member#: 189066
2007 sti
black
you can find an adapter plate to mount your stock dbw tb to that manifold. if not find a 02-03 wrx part out on here or else where and buy the throttle cable/ pedal assy. and like he said use the wrx engine harness and add wires for avcs. <- i wish i had thought of that after i bought a v8 ej207 for my 07 sti. biggest problem i ran into was the difference in ecu, the usdm ecu's are 32 bit and the jdm are 16. my biggest concern was about the rest of the body harness communicating. now that i look back i think it wouldnt have been as hard as i thought but im happy with what i have now.
KingKoopa is offline   Reply With Quote
Old 01-02-2012, 08:07 AM   #16
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
For this type of situation, 32bit/drive by wire, I hope someone decides to do a V10 swap and then we'll know how that goes.
At the time I bought my V9, JDMracingmotors did have a V10 in stock.
Old 01-04-2012, 03:08 PM   #17
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
post up some part numbers
murrdogg24 is offline   Reply With Quote
Old 01-16-2012, 12:04 AM   #18
KingKoopa
Member#: 189066
2007 sti
black
any progress?
Old 02-26-2012, 06:49 AM   #19
kyran013
Member#: 311390
how's it going now?
kyran013 is offline   Reply With Quote
Old 03-02-2012, 07:46 PM   #20
Tanktheory
Member#: 239981
01 SF5 Ver 8 swap
Blu
I'm gonna go out on a limb and say it is a Spec-C motor judging by that turbo inlet. Those are the Spec-C ones.
Tanktheory is offline   Reply With Quote
Old 03-02-2012, 08:34 PM   #21
waylouderthanyou
Member#: 266168
2007 WRX STI
Satin White Pearl
i dont think that pic is of his motor. post pics of the motor ^op.
waylouderthanyou is offline   Reply With Quote
Old 03-03-2012, 05:58 AM   #22
yaser71180
Member#: 302100
2000 JDM WRX STI
you are really lucky, JDM much much better than USDM
in middle east we have USDM cars, but we used to bring JDM engines from Japan and people are doing the swap either from 2.5 STI or even from 2.0 injections to JDM 2.0 STI
but the problem that my friend is having the wiring diagram in his mind, I will ask him if he know any site or document for JDM wiring diagram
yaser71180 is offline   Reply With Quote
Old 03-15-2012, 03:18 PM   #23
uv_blue
Member#: 282723
Easy fix, send me your motor and everything I send you a usdm sti motor drop it in and go lol
uv_blue is online now   Reply With Quote
Old 06-06-2012, 10:25 PM   #24
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
There is hope for those who search, but seriously its not that hard. And the RA-R comes with a VF42, the Spec-c RA comes with the VF36. The 42 is a basically a VF48 compressor and a special turbine wheel in the standard TS exhaust housing with the VF36 roller bearing CHRA. I have been looking to make one from my VF36 but cannot find the special turbine wheel.
http://importsnc.com/forums/motionla...-295ftlbs.html
lukeskywrx is offline   Reply With Quote
Where to buy JDM WRX/STI Type RA-R 6-pot calipers and rotors? chrisarella Private 'Wanted' Classifieds 12 09-19-2015 03:24 AM
FS : OEM Sub, Cargo Net, JDM Clockspring, wheel lock, STi lic. plate, JDM Type RA-R Wheels jrodela06 Interior/Dressup/Audio & Security 4 07-23-2011 02:32 PM
07 STI SPEC-C Type RA-R zero-d General Community 11 10-05-2007 05:31 PM
FS: JDM Spec C type RA-R Black Carpet kookaburrabomb Interior/Dressup/Audio & Security 18 07-29-2007 10:17 PM
FS: (SC) JDM Spec C Type RA-R Shift Knob 6 speed sti-06 Interior/Dressup/Audio & Security 4 05-20-2007 09:54 PM
