Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 02-07-2012, 11:19 AM   #51
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
If you stayed 205/207 it could rev to 8.5k would turbo still be making power that high up in rpm? If so then you'd probably have a bigger power band on 2.0
slava from goshen is offline   Reply With Quote
Old 02-07-2012, 11:32 AM   #52
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
it should i have a s200sx-56 ( original 7670) and im easily still making power at 9k on my 207
seanathanq83 is offline   Reply With Quote
Old 02-07-2012, 02:28 PM   #53
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Here are my calculations...
Maxed out tune, reving to 7k rpm....
http://www.turbodriven.com//performa...6_wrsin=92044&
Maxed out tune, reving to 9k rpm....
Spinning out to 9k certainly could be an option on a 2.0L...
thefoos is offline   Reply With Quote
Old 02-07-2012, 04:45 PM   #54
seanathanq83
Member#: 173241
something looks off with how low the torque is dropping off way to much
Old 02-07-2012, 09:27 PM   #55
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Looks right to me...its a VE/pumping issue. The turbo can only push so much air, and the pressure ratio across the motor takes a real nose dive. It'd probably be a shade better up top with a larger turbine housing, but the turbo looks fairly well matched....
Old 02-16-2012, 05:03 PM   #56
PrecisionCustom
Member#: 207830
2002 Precision Built
BOOM GOES THE DYNAMITE l!!!!!!!
PrecisionCustom is offline   Reply With Quote
Old 02-19-2012, 08:51 AM   #57
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Minor detour from the turbo kit....
Header and uppipe are done. They are also wrapped, but I didn't get a pic of that yet...
I made some steady and solid progress yesterday.
1) Ran new crackcase ventilation lines.
2) Made block off plate for the 2011 STi TMIC recirc valve flange.
3) Drilled intake for NPT weld bungs.
4) Ported out uppipe
5) Replaced broken sway bar end link.
6) Bolted motor back in.
7) Wrapped header and uppipe
8) Picked up Brembos.
All in a 1/2 day's time...lol....
Old 02-19-2012, 11:18 AM   #58
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Header and uppipe wrapped...
Old 02-19-2012, 05:04 PM   #59
PrecisionCustom
Member#: 207830
Sexy!!!!!
Old 02-19-2012, 08:39 PM   #60
a10secstreetcar
Member#: 310819
Nice build.
a10secstreetcar is offline   Reply With Quote
Old 02-19-2012, 10:31 PM   #61
Layvon
Member#: 195711
STi 04/05/06/07
4) Pol....
Number 3...
Meth injection? 1, 2 or 4 nozzles?
Looks good!
Layvon is offline   Reply With Quote
Old 02-20-2012, 08:55 AM   #62
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Originally Posted by Layvon View Post
Number 3...
Looks good!
Sorry, no, just vac connections for bcs, purge, and crankcase vent....
This car has been on E85 for 3 years and I'm not looking back. No need for meth injection....
Old 02-20-2012, 09:01 AM   #63
Layvon
Member#: 195711
STi 04/05/06/07
Okay makes sense, I just curious.
I agree if you're running e 85 no need, I'm gonna be doing the same thing!
Old 02-21-2012, 08:13 AM   #64
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
On the home stretch. Oil supply fittings are shipped (ordered them in November, I don't know what takes so long). Ran the turbo coolant lines last night. Milled .040 off the power steering line fitting to make it fit right.
Fitted the header and uppipe. I used this "Gasket Eliminator" stuff from SPA. I don't know if I like it. Its a putty thats hard to apply, and squeezed out of the flange (and I assume into the pipe). I think I'm going to take it back apart because I don't want that stuff going into the turbine. Probably will just go with the standard copper rtv...
Old 02-21-2012, 11:47 PM   #65
seanathanq83
Member#: 173241
Why not juat order the correct twin scroll gasket from iaperformance, and the t4 gaskets from lots of places???
Old 02-22-2012, 08:40 AM   #66
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
^I have the proper ts gasket, but it is used. I hate paying $5 shipping for a $8 part...lol
The gasket eliminator stuff looked interesting so I figured I would give it a try....
Fab'd up the IC brackets last night. I'll have to get pics in the next couple of days. Hope to have this thing on the road this weekend.
Old 02-23-2012, 08:30 PM   #67
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Dangerously close to firing this thing up...
Need to double check everything, finish up some work on the downpipe, and reflash....then its time to start...
Old 02-23-2012, 08:34 PM   #68
PrecisionCustom
Member#: 207830
Looks like everything is fitting nice. Killer!!!
Old 02-24-2012, 06:13 AM   #69
Layvon
Member#: 195711
STi 04/05/06/07
Interesting piping work. (Not harassing the welds)
How long do you plan on running w/ this setup on stock motor.
I hope you get to drive er this weekend!
Levon
Old 02-24-2012, 08:06 AM   #70
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
^Probably until it shows some sort of failure. There are varying opinions of what these motors can take. I personally want to know the limits.
Glad you find the pipe work interesting The EFR is a tough fit. Or perhaps you don't like the pie cut methods. Its the cheapest / easiest method to prototype something....
Old 02-24-2012, 09:19 AM   #71
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
I think your welds look pretty decent! I hope you post a clip of this thing when it fires up and then maybe one of it ripping through a gear or two
BlackJavaPearl04 is offline   Reply With Quote
Old 02-24-2012, 09:47 AM   #72
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Thank you. I have to give my buddy Joe (Precisioncustom on nasioc) the credit for most of the welding you see in these pictures. I've done all of the bracket work and some of the stainless tubing, but he has done all of the aluminum and the tough pipe work. When I run out of talent, he fills in...
Old 02-24-2012, 01:27 PM   #73
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Can I hint that if you have the time, go back and regap the rings on the factory cast pistons...hint hint
I say this as you don't seem to mind turning a wrench and it'll extend that engine's life.
Old 02-24-2012, 04:04 PM   #74
Layvon
Member#: 195711
STi 04/05/06/07
No I wasn't making funny well the doc, I was just intrigued by how you managed to fit the efr in there. Very creative to say the least, because these are some long turbo that's for sure
Old 02-24-2012, 07:54 PM   #75
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Awesome, thanks for the tip. I honestly won't do it, but I'm in the process of understanding the specifics of these engines, and your input is respected. You know your way around these engines far better than I.
What do you gap your rings at if not to factory spec? Do you go looser I assume?
I figured you weren't. Its a hard fit. I had to be very careful with placement. Fitting a Garrett is way easier, but then you have to deal with the gates. I really wanted one of the smaller frame models (6758), but then they scrapped the TS IWG launch on those....
2004 STi EFR 7670 Build Layvon Proven Power Bragging 869 02-10-2014 04:45 PM
Bilyk WRX BW S374 Rotated Build [email protected] AWHP Bilyk WRX Proven Power Bragging 279 08-21-2012 12:17 AM
Hydra Base Map and Boost control for BW EFR iheartwrxSTI Other Engine Management 0 02-28-2011 10:34 AM
EFR 7064/7670 and 8374 picture previews armyssoldierboy General Community 2 12-29-2010 10:38 AM
EFR 7064/7670 and 8374 picture previews armyssoldierboy News & Rumors 2 12-29-2010 09:08 AM
