Old 12-12-2011, 03:30 AM   #1
matt2WRX
Member#: 299863
Default AccessPort Help
Hey guys,
I picked up my 2011 WRX a couple of months ago and added a Perring Cat-Back exhuast.
Next was to be Stage 1 but after reading this: http://forums.nasioc.com/forums/show....php?t=1982882 is the AP going to work with the Perring CBE?
Also im 3000 + or - where I live. Will this change anything with the tune or cause any problems?
Ive also been told that the Cobb stage 1 tune is better for your car then the factory tune, is this true?
Ive seen many post there logs on here and Cobb takes a look and helps out, thats promising.
Any other comments or info will help with my decision so dont hold back.
Thank you in advance for all your help.
matt2WRX is offline   Reply With Quote
Old 12-12-2011, 11:15 AM   #2
Cobb Tuning
Member#: 4803
Originally Posted by matt2WRX View Post
Hey guys,
A catback exhaust is perfectly acceptable for our stage 1 maps. There can be a lot of variation from car-to-car when it comes to boost control. For your car, we do have different level wastegate maps you can use if you are overboosting or underboosting (low wastegate or high wastegate maps). You can download them at our map repository:
http://www.cobbtuning.com/info/?ID=3061
The stock mapping on the later Subarus has what some would consider a "dangerous" lean condition well into boost due to an extended closed loop to open loop fueling delay. The Cobb maps eliminate this behavior, so, in that respect it is safer. Keep in mind, that any significant increase in performance puts more stress on the drivetrain. It is important to make sure you are using quality gas, that your maintenance is kept up-to-date and that you promptly fix any mechanical issues (which is also important even with the factory mapping).
Bill
Dealer/Accessport Help needed Goofy's WRX Engine Management & Tuning 28 01-14-2005 12:44 PM
Cobb AccessPORT Help WrxTream Tri-State Area Forum 4 12-02-2004 11:33 PM
Accessport HELP! GHST Engine Management & Tuning 13 10-24-2004 03:07 PM
Unable to Communicate with accessport HELP bren wrx Engine Management & Tuning 2 10-04-2004 05:20 PM
computer/accessport help needed carsnrockmusic Mid Atlantic Impreza Club -- MAIC 14 09-12-2004 07:19 PM
