Old 12-12-2011, 01:30 PM   #1
Laio
Member#: 172903
Default Problem with my ej20k ver.4
Hello, I'm from Chile and my english is poor, sorry for this.
I swaped my 1.6 Impreza to 1997 ver.4 STI and i have problem's. The light of check engine turn on and the car don't pass the 5000 rpm.
Here a video of the problem
http://www.youtube.com/watch?v=6zBY7...ature=youtu.be
Laio is offline   Reply With Quote
Old 12-12-2011, 01:44 PM   #2
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
I swaped my 1.6 Impreza to 1997 ver.4 STI and i have problem's. The light off check engine turn on and the car don't pass the 5000 rpm.
Hi,
If I am understanding you correctly your check engine light is stuck on and the engine wont exceed 5000rpm. Assuming that your ecu is from the same donor as the engine; it sounds like some kind of limp mode thing. If this is an 1997 ecu the wiring harness should have an OBD2 port or at the very least an ssi1 port that you should be able to plug into that should be able to tell you which sensor isnt plugged in or has failed.
I'd be betting on MAF, CAM or O2.
Without seeing or knowing anything else about your swap that seems like a safe bet.
TommyAtomic is offline   Reply With Quote
Old 12-12-2011, 11:24 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
Mi epanol is malo tambien
connectar los conectores para leer al codigo
esta pagina le ayudara
http://www.scoobypedia.co.uk/index.p...eadingECUCodes
obtener el codero y le ayuderemos
Old 12-13-2011, 07:23 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
I would say speed sensor is not hooked up.
Marnix is offline   Reply With Quote
WTB : Wtb ej20k ver. 4 Wiring harness Ralph509 Private 'Wanted' Classifieds 3 10-12-2011 10:18 PM
Problems with my stage 4 setup. emsmap UTEC 3 03-16-2009 12:27 PM
Diagnose my problem with my 2nd gear FraudulentNeon Transmission (AT/MT) & Driveline 6 05-11-2004 06:29 PM
