Old 12-12-2011, 05:47 PM   #1
pr8er
Member#: 300858
Default 98 jdm ej20 short block with usdm heads
i have a 02 wrx and im thinking of buying a jdm motor I can get a 95-98 ej20 for like $450 what im asking is can i use my ej20 usdm heads on that short block and will my sensors go into that block any help would be great or does any one know were to get a new longblock ej20 usdm for under $3500
pr8er is offline   Reply With Quote
Old 12-12-2011, 05:56 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Yes it will work. Is this to fix a problem?
~Josh~
Old 12-13-2011, 01:31 PM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Will work but not with the stock USDM EJ205 WRX gaskets (0.8 mm thickness). The earlier EJ20G pistons protrude the deck by 0.3 mm which is why you need gaskets at least 1.0 mm thick (original is 1.4 mm).
Marnix is offline   Reply With Quote
HELP car wont start 2.0 jdm block with Usdm heads trinistyles Pre-2002 Factory Turbo Powertrain 15 12-24-2011 10:40 PM
JDM V7 Short Block with WRX Heads = smog legal? ilgdrummer Built Motor Discussion 4 01-13-2010 02:47 AM
ej257 short block with ej205 heads - Hybrid Setup 007WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-27-2009 02:53 PM
Anyone running a V7 short block with USDM STI heads? Trevor723 Built Motor Discussion 3 06-26-2007 09:48 PM
04 sti short block with 02 heads? wrxtuner02 Subaru Conversions 13 11-26-2003 08:38 PM
